What PPAP level would you use for a part provided by a distributor?
jrubio
What PPAP level would you request for a production part provided by a distributor?
When I worked at anyTier 2 important company, we used to raise Purchase Orders to distributor when we run out of parts of the main manufacturer.
The P.O was raised but I think no PPAP was needed,
Is this not outside procedure?. :mg:
It seems that all the PPAPl procedure is focused on manufacturers but what´s up with distributors, they have also processes and legal responsability.
They stockage the product in their warehouses, they transport the product at what condition?, they sell us the product. :argue:
Couriously I have seen many problem due to these practices, when we were going to stop a tier 1 customer, we went to the market to buy the run out product, but sometimes this component was damaged due to the stock conditions. :mad:
I do not know if PPAP manual has an special level for these people?. :eek:
Whether not I think a procedure must be raise from AITF
i.e
Special PSW, process flow, AMFE, Special final SPC, Not MSA???
Your opinnion would be much apreciated
Regards.
It depends on the risk involved and the end customer's requirements. For catalog parts that represent minimal risk, Level 1 might be appropriate. In other instances, such as fasteners with critical structural requirements, you would probably want to see more data. Of course, the PPAP level addresses only the elements that must be submitted, and doesn't relieve the supplier of having all of the relevant PPAP documentation, unless the requirements have been explicitly waived.
Howard Atkins
Forum Administrator
We discussed some thing like this in the past.
As Jim says the question is not the level but rather the content.
The distributor has several activities which are basically storage, packaging, labelling and delivery.
You should be getting a PPAP based on the producers certification and the rest of the documents refering to the distributors activities.
Szacinski
PPAP (PSW) Level 3 - Warrant with product samples and complete supporting data submitted to customer should be appropriate.
This means that the distributor needs to send you certificates, samples and a complete measurment of the part in question and of cause a process flow chart. This should be enough. I would not recommend to go above level 3.
Because I know the problems with level 5 :(
In the US, "certificates" have no intrinisic legal value; by accepting a purchase order and shipping against it, the supplier is tacitly (and legally) "certifying" that the specifications have been met. In any case, the PPAP requirement is for material test reports, and whether they're submitted or not doesn't alter the fact that they are required.
PPAP submission levels are not serially augmentive; there is no "above" or "below" in terms of documentation submission requirements. For example, a Level 4 PPAP might require more or less documentation than a Level 3. And Level 5 is the carries the same requirements as Level 3, the only difference being that the documentation is reviewed at the supplier's location.
Szacinski
In the world I live in there is no level 1-2 and 4. There is only 3 and 5.(Phased PPAP). And thus we require that same from our suppliers. Im damaged :mg:.
Yes, its true that level 5 is the same as level 3, but costumer should be on site for both capabillity verification and capacity verification on Level 5. This takes alot of time away from you. That is why I dont recommend it.
As long as you fullfill the PPAP checklist (19 point to fullfill?) there should not be any problems.
There is no standard requirement wrt Level 5 for the customer to be present for capability or capacity verification; the latter is generally referred to as "run at rate" and happens after PPAP approval. Mind you, I'm referring to default AIAG PPAP requirements, which may be different with your customer(s).
Szacinski
That is true for AIAG PPAP. Ford terms (PHASED) a "Run at Rate" is done before Capacity verification,and it is called PHASE 0 (No PSW). Where supplier runs a limited batch to show costumer that they are close. Phase 1, Quality Verification, Phase 2 Production Verification and then the last one Capacity Verifcation which is phase 3.
The three latter are PPAP PSW submission level.
Phase 1,2 and 3 may be done at the same time. Phase 2 is not necessary if you one have one product stream/line.
(And then you also have in mind that the review is dependent on Site status).
Im sorry for this, but as I said, I am from the world of Phased PPAP :bonk:
And I am still suggesting Level 3! ;)
J Part submission warrant for Level 1 PPAP APQP and PPAP 1
J PPAP (Production Part Approval Process) Submission Level Differences - Forms attached APQP and PPAP 17
M Level 3 PPAP submission of intentional defective parts APQP and PPAP 4
eule del ayre List of Level 3 PPAP requirements for automotive suppliers APQP and PPAP 20
N How to resolve discrepancies in Level 3 PPAP supplier dimensional reports? APQP and PPAP 11
J What level PPAP for 5 critical parts? APQP and PPAP 8
P Automotive Supplier PPAP Level Requirements Supplier Quality Assurance and other Supplier Issues 12
Y Customer Specific PPAP Level 3/4 Requirements - Fastener Manufacturer APQP and PPAP 2
Q PPAP - How to determine the "Design Record Change Level" APQP and PPAP 2
B PPAP Level 3 Process Submission Capability, Accuracy and Stability - Processes, Machines, etc. 5
V What Ford Phase PPAP Level should DV testing be submitted? APQP and PPAP 1
S Guidance to prepare and submit a Level 3 PPAP to a Customer APQP and PPAP 6
V Issue: Suppliers charge for complete Level III PPAP package - Heat Treated Parts APQP and PPAP 16
Q Level of PPAP - Bulk Chemicals Supplier Requirements APQP and PPAP 2
1 Revision Level of Print vs. PPAP Document Control Systems, Procedures, Forms and Templates 4
K Key differences between a Level 2 and a Level 4 PPAP APQP and PPAP 4
V Mandatory to send to the Customers FMEA in a PPAP level 3 - Doubt IATF 16949 - Automotive Quality Systems Standard 36
K Supplier PPAP Requirements - Level 3 or Level 4 APQP and PPAP 6
E Help with PPAP Level 3 for a small company! Machined parts APQP and PPAP 5
D Outsourced Material - Customer who is asking us for a level 3 PPAP APQP and PPAP 8
D AIAG Level 3 PPAP (100% dimensional measurement or just significant characteristics)? APQP and PPAP 2
D Level 3 PPAP for Customer - We are outsourcing the processing FMEA and Control Plans 6
R What is a Level III (Level 3) PPAP? APQP and PPAP 22
D What sort of information can I furnish for a Level 2 PPAP? IATF 16949 - Automotive Quality Systems Standard 1
J What MSA studies do you include in PPAP level 3? APQP and PPAP 2
K PPAP for Truck Industry - What is involved with a Level 3 PPAP APQP and PPAP 2
J FMEA as a Confidential Document - PPAP Level 3 - Can the FMEA be hidden? FMEA and Control Plans 32
E Level 3 PPAP with only a few of the required documents? APQP and PPAP 3
P To PPAP or not to PPAP - Level 2 - No in-house processing APQP and PPAP 13
B When I have to create PPAP Level 1, what data should be updated? APQP and PPAP 8
B PPAP Level 4 vs. PPAP Level 5 - What's the difference? APQP and PPAP 10
M how to decide the submission level for PPAP APQP and PPAP 2
G Need level 3 PPAP Forms APQP and PPAP 6
P What is Level 2 in the PPAP (GM)? APQP and PPAP 10
A Technical Documentation Records - Customer drawing, Revision Level, PPAP, etc. Document Control Systems, Procedures, Forms and Templates 1
D What is a Level 3 PPAP? Blueprint says "Level 3 PPAP is required" APQP and PPAP 10
M QS-9000 level 3 PPAP - Can anyone inform me on the process? APQP and PPAP 7
Q Level of PPAP submission for Subcontractor APQP and PPAP 3
B PPAP submission level classification - One dimension on print is changed APQP and PPAP 16
1 Capability Study for Level 3 PPAP - They are asking for a 100 peice capability study APQP and PPAP 4
B Need to submit level 3 PPAP - New or Multiple Presses - Injection Molding QS-9000 - American Automotive Manufacturers Standard 4
J Supplier not responding to PPAP request APQP and PPAP 5
B Toyota PPAP Process - Three Questions APQP and PPAP 3
G Supplier delivered recent PPAP, should he deliver yearly layout inspection? IATF 16949 - Automotive Quality Systems Standard 4
F How to submit a PPAP when a subcontractor is the sole manufacturer IATF 16949 - Automotive Quality Systems Standard 2
P PPAP samples retention time IATF 16949 - Automotive Quality Systems Standard 5
K Updated MSA with the Annual PPAP validations APQP and PPAP 8
P Managing How PPAP Requirements are Communicated in the Manufacturing Process and to Suppliers APQP and PPAP 5
E Annual PPAP+ deviation request ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
