Re: What should be changed in the ISO 9001:2014 Standard?
You're redefining the requirements. The QM, according to 4.2.2, must include "...a description of the interaction between the processes of the quality management system." (Emphasis added.) Nothing there about managementsystem processes. Purchasing and design/development are quality system processes, and simply rewording the requirement doesn't get you off the hook. If you have auxiliary or referenced diagrams that do show these interactions, then the top-level document isn't doing what you're claiming it does.
Jim,
Thanks for persisting with me on this...
The details of processes such as design, development and purchasing are also in the flow charts of those processes. Again, this is the view from 30,000 meters. It is not intended to capture all the intricacies of each process.
4.1.a and b don't ask for the sequence and interface of subordinate processes, only of the MANAGEMENT SYSTEM processes.
The sequence of the Purchasing or Design process are all captured within the flow charts, as is their interface with other processes. I attached the Internal Audit process as an example. All 12 of the key processes are mapped out in a similar way.
I can forward another to you if you like.
Patricia
Patricia
Thanks Jim.
