What should be measurement method in control plan if you are defining Control method as work instruction.
Mirza Abrar
I am working on control plan where i am defining product specification as "mixing epoxy correctly by folding method" which is define in control method as work instruction. my question is what measurement method will be. because at this point i am not able to measure the operator follows to SOP or not
You don’t measure the operator. You measure the strength of the epoxy.
Mirza Abrar
What I should write if I doesn’t have any way to measure strength.
still the control for failure should been in control plan
Not all controls (or mitigations of failure modes) are measurements. Many are procedures that prevent or substantially reduce the frequency of failure. A specific method of mixing epoxy is a mitigation for failure due to improper mixing. Write the work instruction to be specific about the method just as you would include limits on any input factor such as time, temperature, pressure or dimensions n a feature or property of a material. Train the operators in the method and include why it is important. The process should also be designed to allow for enough time to properly perform the operation; supervisors are responsible for ensuring that operators are performing the process correctly - not as fast as possible.
John Broomfield
Gluing is a special process. The manufacturer of the epoxy will have designed the process and specified the mixing and curing method. That specifies the controls sufficient to be assured of the required joint strength.
John Broomfield
Laying in my hospital bed after my surgeon replaced by left hip joint I gave my reply some further advice.
You may still need to validate the suitability of the epoxy and its proces spec for your particular application.
You may, of course, have already done this while selecting and before purchasing the epoxy.
D Which Measurement System Analysis should I use? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
G Should Serial # of all Measurement Instruments (Calipers,etc) be in Control Plans? FMEA and Control Plans 7
J What Device Should I use for Gage Study? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
T What should be considered or asked to certified body auditors before selecting them for AS9100 Audit? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
U How should we build the FDA inspection preparedness team for FDA inspections at factories? General Auditing Discussions 0
MaHoDie How deep should be risk control tracebility IEC 62304 - Medical Device Software Life Cycle Processes 3
K Departmental KPI not met - should the Auditor raise a NC for it IATF 16949 - Automotive Quality Systems Standard 10
DuncanGibbons How to determine process stability for a process whose outputs should be steadily increasing? Capability, Accuracy and Stability - Processes, Machines, etc. 4
A CE mark symbol should be on the package? EU Medical Device Regulations 1
T Should PMS and PMCF plans be 2 separate documents? EU Medical Device Regulations 8
C When should I take endotoxin testing? EU Medical Device Regulations 3
Dazzur Difficulty in determining who should be addressing NCRs Nonconformance and Corrective Action 9
M Should DoC be updated every time Technical Documentation is revised? EU Medical Device Regulations 2
F How often should Gage R&R's be updated? Is there a recommended time-frame? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
A Which certificate should I start with from ASQ, CQIA or CQE? (or should I take something else) Professional Certifications and Degrees 4
E Please help! ! I AM FRASTRATED SO MUCH! Should inactive ingredient be included in the unit formula if it is removed during the manufacturing process? US Food and Drug Administration (FDA) 0
I IEC 60812 or ISO 14971 for PFMEA? What should we use? ISO 14971 - Medical Device Risk Management 3
qualprod Do sum of results of quality objectives should met a high level goal? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
F Should I perform several Gage R&R for every caliper to cover all specs range of use? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
E Opening meeting for Third-Party Audit--Who should say what? General Auditing Discussions 22
8 MSA--Should I Use Parts or Gage Pins? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
B Should I buy IEC 62304:2006, IEC 62304:2006/AMD 1:2015 or both? EU Medical Device Regulations 1
W "Accurate to ±2%" means "64% of measurements should be within 2% of the actual value"? US Medical Device Regulations 4
H Should we stop inspecting a part if its never been rejected? Reliability Analysis - Predictions, Testing and Standards 6
D What distributor requirement should we (manufacturer) require from the Distributor? EU Medical Device Regulations 4
M Should there be another column in the Optimization section (step 6) of AIAG-VDA DFMEA form? FMEA and Control Plans 1
C By when should harmonized standards be complied with? EU Medical Device Regulations 5
W Strategy for determining which components from a system should be "ME EQUIPMENT" -- home healthcare environment IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
B Documented information - Should be controlled? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
Q Is engineering a process and should it have its own process turtle? IATF 16949 - Automotive Quality Systems Standard 7
P Which MDCG Document should I use for PMS Plan and PSUR? EU Medical Device Regulations 2
M Who should quality representative report to? ISO 13485:2016 - Medical Device Quality Management Systems 5
H When should the first PSUR be issued? EU Medical Device Regulations 5
I If i do not want to be an initial importer should i register with FDA? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
O Should a Covid vaccine and testing policy be included as part of ISO9001 or AS9100 risk management? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
B UKRP to what level should you audit Class I Technical Documentation? UK Medical Device Regulations 0
C When should you quit programming? Job Openings, Consulting and Employment Opportunities 9
C Should resolution be included in uncertainty budget for digital caliper or micrometer calibration? Measurement Uncertainty (MU) 5
Ed Panek External Standards List - Should this document include previously revised standards? ISO 13485:2016 - Medical Device Quality Management Systems 4
T How should I approach REACH, CM, etc. as a job shop? RoHS, REACH, ELV, IMDS and Restricted Substances 18
A Should we assign the PRRC before the date of application of MDR (26 May 2021)? EU Medical Device Regulations 0
J UDI-DI how should we interpret Device version or model to determine if a new UDI-DI is needed? EU Medical Device Regulations 0
Sidney Vianna Interesting Discussion Should ISO 9004 be changed from a guidance document to a requirements standard? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
S Which Sampling Plan(s) Should I Use? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 13
