What SPC (Statistical Process Control) software is your company using?
jager
Our metal stamping company would like to invest in new SPC software for use in the manufacturing areas. We have about 50 machines running at a time and most jobs require X bar and R charts. We have used the same software for around 12 years. It's not bad, but has some drawbacks. What are you using? We need to print histograms with Cpk, Cp and Ppk, and also the charts and data. I'm doing some checking around for management. Thanks!
arios
Re: What SPC software is your company using?
On a former job Minitab was common, and on older times used to use StatGraphics, but that was a while ago.
bobdoering
Stop X-bar/R Madness!!
We use InfinityQS on the shop floor in an primarily assembly application. But, I am not sure if X-bar-R or Cpk calculations are really applicable to stamping, especially if your variation is only affected by tool wear and material variation. It would be applicable for very low precision stamping and equipment with low maintenance requirements. Many software packages can do X-bar/R but few can do the correct charting methodology. I would hate to see you make an investment that would not meet your real needs.
sixsigmais
Minitab is good enough, it is much better than my company, we are using the manual SPC software made by our own
jager
We do chart a lot of variable dimensions such as say...leg height at +/- .005", every 15 or 30 minutes and at the end of the run, approx. 15 subgroups, we print the chart to send to the customer as requested. It has Cp, Cpk, PPM or other info.
Isn't Minitab tough to use on the shop floor where an operator needs to see his on-going average and range, Cpk or Ppk and make machine adjustments accordingly? I have Minitab at my QA Lab desk for a few customers' PPAP submissions, but we use Datalizer 9000 on the floor now. It is ok, but is a dos program. You can't copy and paste, or email charts or any of that handy stuff!
bobdoering
.... use on the shop floor where an operator needs to see his on-going average and range, Cpk or Ppk and make machine adjustments accordingly?
What kind of adjustments are the operators doing on the shop floor with this data? It still sounds suspicious that it may be the incorrect methodology for your process.
Statisticale
JMP - best for you to download the free trial & see if it meets your requirements. Cheers.
jager
Bob, our customers require SPC with shipments of parts. If the operator is running a machine and measuring a feature 3pcs every 15 minutes and typing caliper or micrometer readings into their computer SPC software, the x-bar and r chart shows if the dimensions they typed in are, for instance, getting close to the upper or lower spec, or control limits, and he will stop the machine, make an adjustment and remeasure. It is simple to do and they can see that their subgroup averages are staying the about same or varying all over.
That's why we use the charts...customers just have us send them.
Marc Steve Prevette's Statistical Process Control (SPC) "Library" Statistical Analysis Tools, Techniques and SPC 0
S SPC (Statistical Process Control) for Unilateral Tolerance - Questions Statistical Analysis Tools, Techniques and SPC 6
O Is SPC (Statistical Process Control) always required? Statistical Analysis Tools, Techniques and SPC 4
M SPC (Statistical Process Control) Book Recommendations wanted Book, Video, Blog and Web Site Reviews and Recommendations 1
I How to use Statistical Process Control (SPC)? Statistical Analysis Tools, Techniques and SPC 8
J Definition Control - Definition of Control in SPC (Statistical Process Control) Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 8
T Recommend books on SPC (Statistical Process Control) Statistical Analysis Tools, Techniques and SPC 3
S SPC (Statistical Process Control) books - Suggestions and reviews please Book, Video, Blog and Web Site Reviews and Recommendations 3
O SPC Statistical Process Control with All data Using Minitab Software 4
T Touch Screen Capable Software suggestions for SPC (Statistical Process Control) Quality Assurance and Compliance Software Tools and Solutions 4
H Getting A Supplier to use SPC (Statistical Process Control) Supplier Quality Assurance and other Supplier Issues 5
P ISO 9001 requirement for SPC (Statistical Process Control) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
Batguy SPC (Statistical Process Control) on Go/No-Go Checks Statistical Analysis Tools, Techniques and SPC 18
M SPC (Statistical Process Control) analysis and status on two manufacturing plants Statistical Analysis Tools, Techniques and SPC 4
V Statistical Process Control (SPC) for Clean Room Environments ISO 13485:2016 - Medical Device Quality Management Systems 6
V SPC (Statistical Process Control) for Medical Device Company Statistical Analysis Tools, Techniques and SPC 4
J Learning Statistical Process Control - I need a crash course in SPC Statistical Analysis Tools, Techniques and SPC 8
C Starting a Small Lot SPC (Statistical Process Control) program Statistical Analysis Tools, Techniques and SPC 8
I SPC (Statistical Process Control) and SQC (Statistical Quality Control) - Difference? Statistical Analysis Tools, Techniques and SPC 1
R SPC (Statistical Process Control) for Unilateral Tolerance Statistical Analysis Tools, Techniques and SPC 10
S SPC (Statistical Process Control) - I have data, now what? Statistical Analysis Tools, Techniques and SPC 14
S Reaction Plan for SPC (Statistical Process Control) Chart Statistical Analysis Tools, Techniques and SPC 4
M Is SPC (Statistical Process Control) useful? Statistical Analysis Tools, Techniques and SPC 72
C SPC (Statistical Process Control) software recommendations Quality Assurance and Compliance Software Tools and Solutions 23
J User Friendly SPC (statistical process control) Software Quality Assurance and Compliance Software Tools and Solutions 14
Tim Folkerts Is it Time for New Rules for SPC (Statistical Process Control)? Statistical Analysis Tools, Techniques and SPC 22
C SPC (Statistical Process Control) for Management Reports Statistical Analysis Tools, Techniques and SPC 2
Marc Definition Statistical Process Control (aka SPC) - Definition Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 0
Q AIAG Releases the 2nd Edition of their SPC (Statistical Process Control) Manual Statistical Analysis Tools, Techniques and SPC 19
J ISO 9001:2000 - SPC (Statistical Process Control) requirements Statistical Analysis Tools, Techniques and SPC 4
Steve Prevette SPC (Statistical Process Control) Overview Statistical Analysis Tools, Techniques and SPC 101
L Defining Pre-Control Zones - Statistical Process Control (SPC) Statistical Analysis Tools, Techniques and SPC 1
S AIAG Statistical Process Control (SPC) Manual - Page 81 Statistical Analysis Tools, Techniques and SPC 4
M Predictive Maintenance vs SPC (Statistical Process Control) Data Misc. Quality Assurance and Business Systems Related Topics 3
D ISO 11462-1 Guidelines for implementation of Statistical Process Control (SPC) Statistical Analysis Tools, Techniques and SPC 4
T I need an add-in for excel that I can use for SPC (Statistical Process Control) Excel .xls Spreadsheet Templates and Tools 4
Raffy Statistical Process Control - ISO 11462-2:2001 Key elements of an SPC System Statistical Analysis Tools, Techniques and SPC 1
K SPC (Statistical Process Control) Training and Courses - Seeking suggestions Training - Internal, External, Online and Distance Learning 2
Marc SPC (statistical process control) charts and SD (System Dynamics) models Preventive Action and Continuous Improvement 18
J Statistical Significance and SPC Control Chart Reports Statistical Analysis Tools, Techniques and SPC 9
I SPC Statistical Analysis in Metrology General Measurement Device and Calibration Topics 2
V Which Statistical Tool for Pressing Components other than SPC Statistical Analysis Tools, Techniques and SPC 5
A P & F value in Minitab Statistical Studies (SPC) and the 8 points rule Using Minitab Software 7
A SPC Training - I want to develop my knowledge in statistical tools Statistical Analysis Tools, Techniques and SPC 5
B Statistical Analysis SPC Trend explanation needed Statistical Analysis Tools, Techniques and SPC 4
I Statistical Tools outside of SPC Statistical Analysis Tools, Techniques and SPC 2
W SPC all the time? Does QS9000 require statistical control on all processes? QS-9000 - American Automotive Manufacturers Standard 3
C Buying Minitab / other SPC or Statistical software Quality Tools, Improvement and Analysis 8
J Best Practices for Choosing In-process Inspection Dimensions & SPC Dimensions Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
PQ Systems 10 Ways to Improve Your SPC System Using SQCpack Software 0
