F
The only time equipment needs to be calibrated under 7.6 is if it is used for the basis of acceptance or rejection. Do you use it to say yes or no with?
The other things that might need to be calibrated are process equipment used for special processes, or those requiring vaildation. If you use the temperature say in a plating process to ensure the bath is at a specific temp to ensure proper plating, then the temp. gauge would need calibration in that it is enuring a special process meets required results.
Does your process need validation? Is that why that gauge is there? To show you the temp. since it is a required process parameter? Is this temp called out in a work instruction? Chances are if you have a temp. on a peice of process equipment, it falls under the guidelines in 7.5.2, not 7.6
