What specifically must be calibrated per ISO 9001:2000?
F
freelovefest
#53
I guess one thing is clear, and that is that if a good chunk of us posting are lead auditors, the same that are coming in and out of everyone's facilities, and we can't really define what needs to be calibrated, or definitely agree, that should tell you something.
Every auditor is different and each has a different interpretation and application of the various ISO standards. So as I always tell people when an auditor asks them to do something they disagree with, like calibratiing various instruments, to examine the request.
Does the request make sense?
Is it helping your business needs, or customer's needs to be met?
If the answer is no, then usually the auditor is beating up on you. ISO requirements make sense, and if applied correctly help you run an effective efficient business operation, so just remember that when dealing with your auditors and their various requests.
Q
qualitytrec
#54
Slightly Off Topic: But I disagree
I do not necessarily agree that the auditor is beating up on you. We just might see it differently. I have found that a clear explaination of why we have chosen what ever method we are using and then showing that it is wroking within reson to prevent what ever NC the auditor is concerned about works. If it is something that you have not concidered before then take it into consideration and decide if it is going to be of benifit as you have said, otherwise in your corrective action to the auditor explain why you disagree and the proof that the system is working as is.
Yes there is disagreement among auditors and companies about what should and shouldn't be calibrated, monitored, measured and almost any other conceivable thing in the standards. But the real questions are, is it working the way we have it now or not and does it apear that it will continue to work in the future, and can we make it better.
Mark
CottonS
#55
Here is one for you guys.
If have a scale on the press line for measuring load weights is it need to be calibrated? The load weight is called out in the SMP, but the weight is to make sure that the part fills out properly in the press.
You don't right down the weight, so do you need to calibrate it or is it for "Reference only"
If they are only using the calipers on the line to verify but not write down, does it need calibrated?
Me, I believe, if you call out a size and you are using any measuring device to make sure that the part conforms, then it should be calibrated. Auditors are that way too.
If you have an oven that is not calibrated an auditor or customer will ask how you know that is the write temp, at some point you have to have a tool to verify the oven's temp and that will need to be calibrated, or just have the oven calibrated.
Hershal
Metrologist-Auditor
#56
Very simple question on this.
What if that measurement is not made, will it matter?
If not, then make it reference only, or get rid of that measurement from your process.
If yes, calibrate the instrument(s) involved.
CottonS
#57
I work in a rubber facility. We use scales to weigh out the material before we load it into the mold. If we don't weigh to make sure we have enough material then you can have under fills, but if you stuff too much into the mold then you can over load a mold and possibly put the closure dimension out of tolerance.
So I say we need the calibration, but you know you can always have that one (son of the company owner) who tries to argue. Of course he has never had any training and has no clue.
Helmut Jilling
Auditor / Consultant
#58
The requirement in cl 7.6 is to calibrate gages where accurate results are required. So, if you want the scale to provide accurate results, it should be verified/calibrated. If it does not matter if the results are accurate, then maybe it does not need it.
If he is not sure, cover the readout of the scale, so you can't see it. If that is still ok to use, then maybe it does not need to be calibrated. :cool:
Also, be aware, you can verify yourself if you buy some scale weights and just verify it internally. No cost.
Marc
#59
Things haven't changed much over the years. :notme: Unless I'm missing something, of course... :confused:
Tyler C
#60
I realize this post is about 4 years old, but it brings up a point I would like to ask about.
For example, material is cut at area 1 and final inspection is at area 10. It is important to have specified dimensions so according to the standard, anything at area 1 should be calibrated/verified.
Is it acceptable to have rulers, tapes, etc., at area 1 be listed as 'reference only', and then the rulers, tapes, etc., at area 10 be calibrated/verified?
The tools at area 10 are what will determine if the product is accepted or rejected, and this will help ensure customers get what they are asking for.
Let me know your thoughts.
M Labelling - Is there a guidance or regulations that specifically defines the 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
D Question regarding ECO process, specifically for Life Science products and defining form fit and function ISO 13485:2016 - Medical Device Quality Management Systems 1
N ISO 22716 Cosmetics - Hygiene (hair restraints specifically) Other ISO and International Standards and European Regulations 2
G Procedure Creation specifically for dimensional (caliper, micrometer, dti) Document Control Systems, Procedures, Forms and Templates 8
X Customer Service FMEA - Specifically Customer Care / Severity Rankings Service Industry Specific Topics 3
Q NADCAP NDT (specifically RT) - Calibration of eye loupe reticle & optical comparator AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
Q NADCAP NDT (specifically RT) - Checklist AC7114 Rev. K, section 8.1.3 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
B Plating Shop - Forums specifically related to the plating / metal finishing industry ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
D UV Absorption Test - What is it's purpose and what specifically is it looking for? Other Medical Device Related Standards 9
T Specifically calling out the use of lower level documents in higher ones. IATF 16949 - Automotive Quality Systems Standard 16
P Electronic Record Control (Specifically editable records not fixed documents!) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
A Help needed for Fighting a specifically identified Organism found during Dose Audit Miscellaneous Environmental Standards and EMS Related Discussions 2
D ISO 13485 Help - Determining what processes I specifically need to document ISO 13485:2016 - Medical Device Quality Management Systems 9
N Customer Property Logs - Tracking customer property, specifically production tooling IATF 16949 - Automotive Quality Systems Standard 5
Q Are there any threads specifically concerned with designing with AutoCAD? Design and Development of Products and Processes 1
C Documentation of training and retraining procedures, specifically how training should Document Control Systems, Procedures, Forms and Templates 6
G AMS 2750 - Tell me what troubles, specifically, you have had with AMS 2750 Various Other Specifications, Standards, and related Requirements 4
S Method Validation for qualitative tests (specifically Absence/Presence) General Measurement Device and Calibration Topics 2
T Non-Conformance Reports - Does the standard specifically say what an NCR is called? Nonconformance and Corrective Action 28
Tim Folkerts NCAA football polls, BCS, etc - Specifically the USA Today Coaches Poll Coffee Break and Water Cooler Discussions 8
CarolX Does ISO 9001:2000 Specifically Require Process Maps? Process Maps, Process Mapping and Turtle Diagrams 19
S Corrective Actions - Specifically closing out and verifying effectiveness Nonconformance and Corrective Action 30
D Gage R & R - Do we specifically have to do Gage R&R on every gauge? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
A What must be recorded? (ISO 9001:2015, subclause 10.2) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
John C. Abnet Must COPQ always be quantified as a monetary ($) amount? IATF 16949 - Automotive Quality Systems Standard 2
T What does AS9100 mean when it says you must establish a process to do X? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 24
B IATF16949 audit requirement - Auditor request UCL and LCL must be show Xbar-R, IATF 16949 - Automotive Quality Systems Standard 7
A Read instruction manual - What Graphic Symbol must I use? US Food and Drug Administration (FDA) 7
M What kind of instrument that must be calibrated? General Measurement Device and Calibration Topics 3
Q Must product name be listed the same name in FURLS, UDI, GUDID and Company Website? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
J Customer VDA Audit - We must provide refresher training? VDA Standards - Germany's Automotive Standards 4
J Any diverging opinions regarding audit findings or conclusions must be resolved no later than the closing meeting ISO 13485:2016 - Medical Device Quality Management Systems 13
I Sampling processes - Who must define the AQL level? AQL - Acceptable Quality Level 9
M Which documents must be updated upon product validation? Document Control Systems, Procedures, Forms and Templates 1
Q IATF 16949 - Product audit - Must each product be audited? IATF 16949 - Automotive Quality Systems Standard 6
G From an ISO 17025 auditor perspective must micrometer calibration check anvil flatness? General Measurement Device and Calibration Topics 4
C Must your reference standard provider be ISO17034 certified to meet your testing lab's ISO 17025 certification requirements? Other ISO and International Standards and European Regulations 2
R Changing Document Control software. Must I transfer EVERYTHING? Document Control Systems, Procedures, Forms and Templates 3
T Must all Disposable Medical Devices be DEHP Free for MDR? EU Medical Device Regulations 1
W Product Audit - It must be a separate and distinct activity (IATF 16949) IATF 16949 - Automotive Quality Systems Standard 4
P Quality objectives - must they include CAPA and internal audit topic? ISO 13485:2016 - Medical Device Quality Management Systems 28
S Record Retention - How long must a company keep the following records? Records and Data - Quality, Legal and Other Evidence 17
I Is risk acceptability really needed if all risks must be reduced as far as possible? ISO 14971 - Medical Device Risk Management 6
A ISO 9001:2015 Clause 9.3.2 - Management Review Inputs must be Documented? Management Review Meetings and related Processes 15
N Must Bioburden Sampling Procedures be Documented? Other Medical Device Related Standards 5
M Contacting a "Must Use" (aka Sole Source) Supplier's Registrar Supplier Quality Assurance and other Supplier Issues 6
T Auditor states my Oven Thermocouples must be Calibrated General Measurement Device and Calibration Topics 18
K Must I update the Quality Policy? (ISO 9001:2008) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
B Must a Design Outsourcing Company have ISO13485? ISO 13485:2016 - Medical Device Quality Management Systems 3
U Must every procedure be proceeded by a policy? Document Control Systems, Procedures, Forms and Templates 2
