What testing would you run to determine if a device is "Clean"?
rwend07
What testing would you all run to determine if a device is "clean"? What are acceptable levels during those tests for a clean device?
We have asked our regulatory consultants this question, and got a bit of flaky answers. I also haven't seen anywhere that really defines what "clean" is/means.
Take initial bioburden during biocompatibility testing and use that as a baseline for future bioburden levels? Same thing for particulates?
JeantheBigone
Re: "Clean" device measurements
The type of testing depends on the type of residue expected.
ASTM F2847 suggested testing methods for different types of residue, and there are helpful resources here:
http://www.campoly.com/files/8913/6..._Workshop_on_Reprocessing_Medical_Devices.pdf
and here:
https://www.rms-foundation.ch/fileadmin/dokumente/ASTM_workshop_on_cleanliness.pdf
The first link shows a chart for the different testing methods for various types of residue.
Establishing acceptable cleanliness limits is left to the manufacturer and can as you said rely on biocompatibility testing. What is important is that the limits are justified.
Ronen E
Problem Solver
Moderator
It all depends on the intended use.
It's up to you to decide what's important and how is "clean" defined. Then you can set limits and derive test methods from what you're looking for.
Biocompatibility should be tested (if testing is necessary) on devices as they're serially manufactured. If bioburden is not important for the intended use and the manufacturing environment doesn't particularly attenuate bioburden, this is how biocompatibility should be tested (on "dirty" devices). If the device passes biocompatibility testing in its "natural" state there is no special reason to make it / keep it cleaner than as-tested, nor to actively monitor its cleanliness.
If bioburden is of importance for the intended use there are specific published standards which include test methods. The pass/fail criteria would, however, depend on the specific intended use, ie on what clinically matters.
Particulate contamination is tricky and I'm not aware of a wide consensus on acceptance criteria, even within specific application fields such as drug delivery. Talk to clinical opinion leaders in your specific field to get a feel for the requirements.
I wouldn't whole-heartedly support testing for residues that don't make a difference for the intended use, even if they're expected. Gross contamination would be obvious, and besides, it should be addressed through proper design & process controls rather than through testing (QA rather than QC).
rwend07
Re: What testing would you all run to determine if a device is "clean"?
Great, thank you both for the thoughtful responses.
normzone
Lick my finger, rub it on the product, lick my finger again.
Sorry, rough day. I did determine exactly what kind of soft drink had been spilled into a customer's computer returned "under warranty" in that manner once.
Customer Service report noted " Dr. Pepper " as the cause of failure.
G Success Run testing - Confidence Levels Reliability Analysis - Predictions, Testing and Standards 7
I Labeling requirements for Type Testing China Medical Device Regulations 0
T Human Factors and Usability Testing in the US - smaller sample size than the required 15 users Human Factors and Ergonomics in Engineering 6
H Regarding 47 CFR 15c testing CE Marking (Conformité Européene) / CB Scheme 3
O ESD Testing IEC 60601 IEC 60601 - Medical Electrical Equipment Safety Standards Series 7
Stoic Which medical device companies are using Recombinant Factor C (rFC) instead of Limulus Amebocyte Lysate (LAL) for endotoxin testing? Sustainability, Green Initiatives and Ecology 0
S Testing & Validation Phase Design and Development of Products and Processes 1
I Design Verification Testing on Non-Validated Equipment ISO 13485:2016 - Medical Device Quality Management Systems 2
R Quality Agreements with external testing laboratories now mandatory? EU Medical Device Regulations 16
A New biocompatibility testing? US Medical Device Regulations 1
S Guidance on Factory Acceptance Testing for injection moulds please Qualification and Validation (including 21 CFR Part 11) 2
C Biocompatability Testing - Electric Breast Pumps , Silicone Component EU Medical Device Regulations 3
L Proficiency Testing Statistical Analysis ISO 17025 related Discussions 0
T Changes to product IFU & Summative Testing IEC 62366 - Medical Device Usability Engineering 1
A Chemotherapy Resistance Testing for EU EU Medical Device Regulations 1
N FDA mechanical bench testing Manufacturing and Related Processes 5
E Microbial Barrier Testing for Medical Devices Qualification and Validation (including 21 CFR Part 11) 2
A Safety testing of Medical devices ISO 13485:2016 - Medical Device Quality Management Systems 2
C When should I take endotoxin testing? EU Medical Device Regulations 3
A Safety testing for Medical devices to be sold in India ISO 13485:2016 - Medical Device Quality Management Systems 0
M Test Lab Recommends ANSI C63.27 Wireless Coexistence Testing IEC 60601 - Medical Electrical Equipment Safety Standards Series 8
P Biocompatibility testing ISO-10993 for FDA submission Other Medical Device Related Standards 7
R Tips on transitioning out of testing lab Career and Occupation Discussions 0
T Aircraft GAPP Software Testing Compliance Question AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
E Usability for Near Patient Testing Test Kit Human Factors and Ergonomics in Engineering 2
J Single Fault Testing for Secondary Circuits (60601-1 section 13.1) IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
P Medical device testing lab/service standard Other Medical Device Related Standards 1
T Cytoxtoxicity Testing Dilution Other Medical Device Related Standards 1
M Altitude testing IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
H IEC 62368-1 Scope of Testing CE Marking (Conformité Européene) / CB Scheme 3
H EMC & Safety Testing of the product with the same Sr. No. for EC Declaration CE Marking (Conformité Européene) / CB Scheme 3
A Non-medical device testing in the medical system IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
H Is testing according to IEC 60601-1 & IEC 60601-1-2 mandatory for a device being registered under MDR? IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
W CQI-9 Testing Fluids Manufacturing and Related Processes 0
XRAY_3121 Class II heating pad - does the power supply have to have IEC 60601-1 testing?? US Medical Device Regulations 5
T Testing for proving food safety on USP class vi material RoHS, REACH, ELV, IMDS and Restricted Substances 0
J Risk Analysis for Proficiency Testing Reliability Analysis - Predictions, Testing and Standards 1
Rene Minassian Control of (TMME) Testing and Measurement Equipment Oil and Gas Industry Standards and Regulations 2
M Is complete testing required as per ISO 10993 for materials used in orthopedic implants or is literature review route possible Other Medical Device Related Standards 5
B A testing lab within an organization ISO 17025 related Discussions 10
B Package integrity Testing failure ISO 13485:2016 - Medical Device Quality Management Systems 7
R Basic Lab Practices - related to ISO 17025 testing labs ISO 17025 related Discussions 1
N Microbial testing on food packaging materials Food Safety - ISO 22000, HACCP (21 CFR 120) 3
A Stability Testing of a device with sterile fluid pathway claim Other Medical Device and Orthopedic Related Topics 1
M Cosmetic Shelf Life Testing Misc. Quality Assurance and Business Systems Related Topics 10
S Safety testing IEC 60601 series Medical Device and FDA Regulations and Standards News 2
M EE's - Laptops/Printer Change and Emissions Testing IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
keya1tos EU to UK plug adapter correct testing standard CE Marking (Conformité Européene) / CB Scheme 9
D IEC 60601-1-2: Is EMC immunity testing required for a device without essential performance? IEC 60601 - Medical Electrical Equipment Safety Standards Series 25
M Oral irritation testing Medical Information Technology, Medical Software and Health Informatics 0
