What the difference is between Stub Acme & Acme thread?
Hello Everyone,
Can someone tell me briefly what the difference is between Stub Acme & Acme thread?
I'm asking because I just molded a internal thread that has a flat root but a rounded crest. (The print is calling out a Acme thread)
Now I haven't been dealing with Acme threads long at all, but can this be a Acme thread?
Thanks in advanced for your help.
Marc
Fully vaccinated are you?
As a quickie from a search - Stub Acme, what is it?
From the link:
I cut stub ACME quite a bit usaully for motor operated valve stems.
Forrest Addy got it right, the stub are basically 2/3 the thread death of the standard.
Having dealt with various factory reps over the years that build them, I've been told that the thread strength is basically the same as a standard ACME but quicker and easier to produce.
So you have the same thread format with the same strength, but easier to manufacture and it takes less time. If using a stub ACME tap, you'll use less horsepower to run it than you would for a standard.
25 years ago when I started as a Machinist at the Nuclear plant where I still work,everything was standard ACME. Its been in the last 15 or so years that the stub ACME had become popular.
Even so, it is not uncommon for a stub acme threaded valves stem to run in a standard acme bronze driver nut. I can think of a few cases where it is specified solely for the ability to be able to withstand higher clearances due to extreme length of a stem, or one that may be less than perfectly straight.
About a month ago a 12 foot long drive stem that was 2 inches in dia. that operated a 4'dia. butterfly valve was brought into the shop. That sucker was bent all over the place with about 3 different bends that deviated about 6 inches off plane. Believe it or not, it still operated the valve perfectly. The mechanics brought it to us to straighten, thinking that it was so ugly that they might as well get us to fix it while they were changing the rubber seating surface on the butterfly. I told them to bring me the drive nut as I was sure it had to be shot. I couldn't imagine that it couldn't be. As it was, there was nothing wrong with the drive nut and it actually looked pretty good.
We straightened out the shaft and put it back in operation. After looking at the tech manual AFTER the mechs put it in eek.gif I noticed that is specified a Stub acme thread with a standard drive bushing. I have never heard that before but the manufacutuer confirmed that it was standard practice on some valves as regular threads on a regular drive nut would bind up and lock up the thread, rendering the valve inoperable.
Anyhow, in that case it worked. I have noticed that some stub acme taps come in a 2 tap set verses the standard acme which is usually a 3 tap set.
DISCLAIMER: I know little about threads.
H API monogram 4F, The difference between PSL-1 & PSL-2 Oil and Gas Industry Standards and Regulations 5
G What's the difference between 1.32 and 1.33 Cpk? Capability, Accuracy and Stability - Processes, Machines, etc. 18
W What is the difference between TYPE B and TYPE BF? IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
Q Terminal Lugs sizes - Difference between 225/24 vs. 275/24 lugs Manufacturing and Related Processes 2
M Difference between "Production Trial Run" and "Run at Rate" IATF 16949 - Automotive Quality Systems Standard 8
T Difference between a subcontractor and a supplier ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 21
H Difference between Stainless Steel 316 ASTM F899 and ASTM A276 Other Medical Device Related Standards 3
A Exact terms for a plating failure and difference between rejection rate and failure rate Manufacturing and Related Processes 9
gramps What is the difference between discrete and continuous variables? Problem Solving, Root Cause Fault and Failure Analysis 3
JoCam Difference between Approval and Registration - ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 2
S Difference between EU-MDR Annex IX and the Annex-combo X&XI EU Medical Device Regulations 4
C IEC 60601-1-8, difference between table 4 and annex D IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
A What is the difference between Basic UDI-DI and UDI-DI? EU Medical Device Regulations 6
Q What is the difference between AS9100D 9.3.2.f and 9.3.3.a AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
M Aluminum - What is the difference between 6061-T6 and 6061-T651 (both per ASTM B211)? Manufacturing and Related Processes 4
P What is the exact difference between Risk and Opportunity in context of ISO 27001? IEC 27001 - Information Security Management Systems (ISMS) 7
S Difference between Surface Finish (Ra) and Flatness (GD&T) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
O Air Flow - Which is the operational difference between LAF (vertical and horizontal) and RLAF? Manufacturing and Related Processes 2
S DO 178B - What is the difference between review and verification? Federal Aviation Administration (FAA) Standards and Requirements 1
T The difference between SOP and Kaizen Standardization Lean in Manufacturing and Service Industries 2
K Difference between intended purpose and intended use of the device EU Medical Device Regulations 9
S Difference between an Advisory Notice (ISO 13485) and a Field Safety Notice? ISO 13485:2016 - Medical Device Quality Management Systems 3
T Difference between "data analysis" and "management review" ISO 13485:2016 - Medical Device Quality Management Systems 4
qualprod What is the difference between 7.4.1 (2008) and 8.4.1 (2015)? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
S EASA Part 145 - The difference between non-certifying staff and Certifying staff Federal Aviation Administration (FAA) Standards and Requirements 2
S The difference between a Medical Device Accessory and Component Canada Medical Device Regulations 2
S What is the difference between a service request and a complaint? ISO 13485:2016 - Medical Device Quality Management Systems 2
I What is the difference between OOS/OOT Imported Legacy Blogs 3
A Definition Difference between Quality System Procedure and Standard Operating Procedure (SOP) Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 4
Q Difference between Monitor & Measurement ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
T QA vs. RA - The difference between QA and RA Coffee Break and Water Cooler Discussions 6
A Difference between Discrimination and Least Count IATF 16949 - Automotive Quality Systems Standard 2
K Difference between Medical Electrical Equipment and Medical Equipment System IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
M Usability Standard - The difference between IEC 60601-1-6 to IEC 62336 Human Factors and Ergonomics in Engineering 1
S What is the difference between Verification and Validation of Test Reports? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
armani Difference between ISO 9001:2015 Clauses 8.1 and 8.5.1 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
M IATF 16949 Cl. 8.4.2.2 vs 8.6.5 - Is there any difference between these clauses? IATF 16949 - Automotive Quality Systems Standard 7
C What is the difference between "Overall Risk" and "Risk"? (ISO 14971) ISO 14971 - Medical Device Risk Management 10
C The difference between a Critical Dimension vs. Critical Characteristic Misc. Quality Assurance and Business Systems Related Topics 2
