What the industry standard is for attribute gage tolerances - In Writing
K
kemiaskejo
Can someone tell me where I can find, in writing, what the industry standard is for attribute gage tolerances. I have always used the following : When checking a 0.150" ±0.003" hole diameter, I would use a 0.153 minus pin for the Nogo and a 0.147" plus pin for the Go OR if I was checking a 0.150" ±0.003" shaft I would use a 0.153" minus ring for the Go and a 0.147" plus ring for the Nogo. I am having a "discussion" with Engineering and they said that I am incorrect because I would be failing good product. I tried to explain to them that we would want to error for the customer and if the gage did not fit the hole, then we would verify the dimension by using a measurement instrument such as a comparator or CMM. Without written published documentation, my 15 years experience is not worth much.
I don't know of any such written standards. I think that what's being missed here is process control. If holes are the wrong size, it's almost always attributable to tool wear (drills or punches), and tools should be changed before nonconforming material is produced. I understand that you still have to measure the holes, but if you understand the process variation, there shouldn't be any need for arguments about pin sizes, imo.
K
kemiaskejo
Good point. You are correct that we should change tools before nonconforming material is produced. Process control is very important. However, the prefered inspection method at the moment at my facility is to use a Go/Nogo pin gage (Red and Green handle) to confirm the hole diameter is within print specifications. How would you specify what pin sizes and tolerance to use for the go/nogo gage that will be used to check an internal diameter?
I think the method you described in your original post is reasonable. What do the engineering people propose, especially in light of your (also reasonable) stipulation regarding rechecking with an alternate method if nonconforming material is discovered?
G
gaugefixer
gagemakers tolerance chart
Check out the gaugemakers tolerance chart and/or the 10% rule. Basically you take 10% of your total product tolerance (.006") & see what class it fits into for your size range.
Check out mayagage.com for more info.
E
e006823
There is a standard:
ASME Y14.43-2003: Dimensioning and Tolerancing Principles for Gages and Fixtures
There are three gauging policies in use that I know of.
1. Accept most good parts, reject all bad parts (reject some borderline good parts). This policy is the ANSI preferred policy.
2. Accept all good parts, reject most bad parts (accept some borderline bad parts). Not an ANSI preferred policy.
3. Accept most good parts, reject most bad parts (reject some borderline good parts and accept some borderline bad parts). Not an ANSI preferred policy.
Number one is the ANSI preferred and standard policy in the U.S.
- Recommended gage tolerancing policy is that no bad parts will be accepted; therefore, a small percentage of borderline technically good (in tolerance) parts must be rejected
- ANSI standards recommend 5% of the part tolerance be used as gage tolerance, with an optional 5% for wear allowance. This is a total recommended 5-10% of the part tolerance to be used as gage tolerance.
For your Go/NoGo gauges the Go member would have a + tolerance and the NoGo member would have a - tolerance. The amount of acceptable product falsely rejected would depend upon the amount of tolerance allocated to the gauge and to how your process is centered.
Hope this is of some help.
K
kemiaskejo
Thank-you all for the information. I am in the process of ordering the standard ASME Y14.43-2003: Dimensioning and Tolerancing Principles for Gages and Fixtures. I have looked at the Gagemaker Tolerances in the Machinery's Handbook. The Machinery's Handbook also has an illustration showing in what directions to add the gage tolerances depending on if it is an outside or inside dimension. In either case, the tolerances are never outside of the print specifications.
Wayne
Gage Crib Worldwide
Gage Makers Tolerance Calculator
There are three standards that you should read:
ASME B89.7.3.1 Guidelines for Decision Rules: Considering Measurement Uncertainty Determining Conformance to Specifications
ASME B89.1.5 Measurement of Plain External Diameters for use as Master Discs or Cylindrical Plug Gages
ASME B89.1.6 Measurement of Plain Internal Diameters for use as a Master Rings or Ring Gages
As far as I can tell from my contacts it is the internationally accepted norm to have the product tolerance be the gage limits. Circumstances such as costly gages, surface roughness, and cylindricity may require deviation from the norm. The ASME B89.7.3.1 paragraph 4.1 discusses the standard rule of thumb, the 10% tolerance rule. The rest of the standard gives you alternatives discussing guard bands and wear allowances. The gist of the standard is that you and your customer, or quality and engineering departments, review and agree on the gage tolerances, taking in consideration all aspects of the product fit and function.
To make your life just a little bit easier, there is a Gage Makers Tolerance Calculator on the web, which will calculate in both inch and metric options, at: http://www.ring-plug-thread-gages.com/ti-Gage-Makers-Tol-Calculator.htm
I have attached a PDF of the page showing the inch calculation. The page also has a brief description of the 10% tolerance rule.
N Program or application for standard time measurement in industry from video surveillance? Human Factors and Ergonomics in Engineering 1
D Need Resource for Industry Data - standard metrics for machine shops Lean in Manufacturing and Service Industries 3
Paul Simpson ISO TS 22163 - New Rail Industry Standard Other ISO and International Standards and European Regulations 11
R What is the typical industry standard for documenting Usability Risk? Human Factors and Ergonomics in Engineering 16
S Is there a minimum industry standard for PpK ? Statistical Analysis Tools, Techniques and SPC 8
0 Standard that is the equivalent to ISO 22000 but for the non-food industry Food Safety - ISO 22000, HACCP (21 CFR 120) 7
W Where to get French standard RCC-M (Nuclear Industry) The Reading Room 2
C Mitutoyo SJ210 Settings - Is there an Industry Standard Surface Measurement Setting? General Measurement Device and Calibration Topics 4
J Looking for reference to Electronics Industry's Standard Scrap Rates ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
T Cleaning Industry Management Standard (CIMS) Various Other Specifications, Standards, and related Requirements 4
Q Industry Standard for Supplier Tolerences - Sheet Metal Steel and Beams Manufacturing and Related Processes 4
E International Railway Industry Standard (IRIS) Auditor Training Requirements Other ISO and International Standards and European Regulations 13
J Meaning of Business Management System in IRIS (International Rail Industry Standard)? Various Other Specifications, Standards, and related Requirements 4
M International Rail Industry Standard (IRIS) GM/RT2450 Other ISO and International Standards and European Regulations 3
D FMEA with 2 or 3 criteria? Standard applicable to the Medical Device industry ISO 14971 - Medical Device Risk Management 13
M Auditing and harmonization? Determining what is an "industry standard" ISO 13485:2016 - Medical Device Quality Management Systems 6
N CIMS - Cleaning Industry Management Standard Other ISO and International Standards and European Regulations 5
S Recruitment Industry Service Delivery Standard (RCSA-SDS) - getting started Various Other Specifications, Standards, and related Requirements 3
D Industry Standard or rules or best practices pertaining to Automotive Process Flows? APQP and PPAP 3
R Industry inter-lot variation standard for Enzyme Linked Immuno Sorbent Assay (ELISA) Other Medical Device and Orthopedic Related Topics 2
S When (criteria) to Require a Corrective/Preventive Action? (Industry Standard?) Nonconformance and Corrective Action 11
hogheavenfarm ISO then International Railway Industry Standard (IRIS) Or straight to IRIS? Other ISO and International Standards and European Regulations 3
K Industry Standard for Correcting Dates on Documents US Food and Drug Administration (FDA) 9
D UL / Safety Testing Oscillators - Is there an "Industry Standard"? Reliability Analysis - Predictions, Testing and Standards 3
S Usability standard IEC 60601-1-6 in the Medical Device Industry IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
J How to get the International Railway Industry Standard (IRIS) Various Other Specifications, Standards, and related Requirements 5
T International Railway Industry Standard (IRIS) Other ISO and International Standards and European Regulations 4
D Industry Standard for Brazed Joint Integrity - Customer Specification Various Other Specifications, Standards, and related Requirements 1
J Industry Standard for turning in gages to the Calibration Lab? General Measurement Device and Calibration Topics 2
Q ISO/TS 16949 - The Quality Standard for the Automotive Industry IATF 16949 - Automotive Quality Systems Standard 3
Q Industry Standard burr on stamping-is there such a thing? Manufacturing and Related Processes 6
G DPPM Industry Standard - Metal fabrication (Job shop) Misc. Quality Assurance and Business Systems Related Topics 3
P Visual Standard for Watch Industry Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
A Has anyone heard anything about the Financial Industry standard FS9000 Various Other Specifications, Standards, and related Requirements 5
T QSF 2000 in UK and the US (Australian food industry Standard) - Withdrawn? Food Safety - ISO 22000, HACCP (21 CFR 120) 2
Marc SIC vs. NAICS vs. NACE - Standard Industry Codes Misc. Quality Assurance and Business Systems Related Topics 2
gramps What do you think about automated QA testing For software app industry? Misc. Quality Assurance and Business Systems Related Topics 5
V Certified Auditor - Need of additional certification specific to industry ( GMPs) ASQ vs ECA vs others Professional Certifications and Degrees 1
B Industrial RX inspection of welds (Oil&Gas industry) Reliability Analysis - Predictions, Testing and Standards 0
Revision36 Engineering Change Order Industry Standards Other Medical Device and Orthopedic Related Topics 4
B Quality manual for automotive industry wanted Quality Management System (QMS) Manuals 2
E Non-GMP examples in Pharmaceutical industry Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 2
DuncanGibbons Are the IQ OQ & PQ procedures applicable to the aerospace industry? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
Marc Security in Health Industry Software - February 2020 IEC 27001 - Information Security Management Systems (ISMS) 0
A Complaint alert levels - Industry standards pertaining to alert levels for complaints Customer Complaints 5
S Industry Labelling Standards - non medical Manufacturing and Related Processes 0
C Looking for APQP Training recommendations preferably in the aerospace industry APQP and PPAP 2
R Bill of Materials for a complex product - Industry best practice ISO 13485:2016 - Medical Device Quality Management Systems 2
R Risk Management in the Medical Device Industry ISO 14971 - Medical Device Risk Management 4
