What to "bubble" on customer print vs. internal print
Mark Paul
There is some debate as to what must be APQP bubble numbered and what should be numbered and what doesn't have to be APQP numbered and listed in various PPAP documents.
In a ts16949 environment, do you buble number every dimension including basic dims?
What about the notes on the side or bottom of the print that reference all sorts of things and can take up half of the print itself.(Ford comes to mind with their part prints)
ralphsulser
Re: What to "bubble" on customer vs. internal print
Typically, this is discussed with your STA ahead of time to decide what to bubble. Ours told us which dimensions to bubble.
It's generally expected that all dimensions and specifications, except reference dimensions, will be addressed in PPAP dimensional reports unless otherwise stipulated by the customer.
Z
z28tt
We're an aerospace machine shop, and in the past, our company has bubbled *everything* on a print (via Excel). I just found an old bubbleup with about 30 casting target points even bubbled! Now I'm trying to push through bubbling the minimum necessary, using Visual FAIR software.
One of our customer FQE's was in the shop this morning, so I broached the subject with him. My position is that actual dimensions as well as GD&T feature control frames need to be bubbled, but not basic dimensions (since they're captured in the toleranced feature control frame). His stance is that he wants to see the basic dimensions that build up the feature control frame, since they are required for the measurement.
This example is a hole drilled on an angle. The angle is basic 45 degrees. The hole has a .001" true position callout. I just want to bubble the true position tolerance and report that measurement, but our FQE insists that the basic 45deg should also be bubbled, along with an actual dimension for the angle on the AS9102 form. My take is that since the 45deg is theoretically perfect with no tolerance (just in the .001" true pos), there is no measurement necessary. He wants to see how we calculated the .001" true pos, rather than just have a number in the form.
If we're supposed to put actuals on the 45deg basic feature, how do you tolerance it? Is it in? Is it out?
Another question came up on parts that have radial features. There's 0-180 and 90-270deg lines drawn on the print. Only the 0° is used to reference another angle (12±.25°) for a feature. We have to bubble the 12°±.25°, but why do we need to bubble the 0° (and on the dimensional results form state "noted" as the result)? Also with 90, 180, and 270°?
The one thing we did agree on is that reference dimensions doot need bubbles. Datums also do not, but he likes to see them (why? where's the value added in stating "noted" or "accepted" on the results form?). Drawing notes must be bubbled. Now one of our customers is requiring that we bubble the PO as well for a preferred PPAP!!!
mwohlg
Don't put any tolerance at all. It isn't in. It isn't out. It just is what it is. If it is really screwed up it will be reflected in the true position (or whatever) dimension it is used for.
Watchcat Inside the Bubble 2019 Other US Medical Device Regulations 8
A Tubing Clog Tester - Convert from Air Bubble to Flow Rate Reliability Analysis - Predictions, Testing and Standards 1
A Maximum bubble volume for subcutaneous injection IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
triathlonx13 Leak test correlation - Bubble to Air Reliability Analysis - Predictions, Testing and Standards 8
D Bubble Point Testing of Syringe Filters Design and Development of Products and Processes 1
T Calibration procedure for Bubble Gas Flow Meter General Measurement Device and Calibration Topics 3
N Excel Bubble Print Utility - Bubble Prints/Roadmap Prints Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
J Print (Drawing) Bubble Techniques Document Control Systems, Procedures, Forms and Templates 45
C AS9102 FAI Bubble Drawings AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 12
Y Inspecting Glued Components - Bubble size - Medical Device Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
S Ballooning a Print (Drawing) - A correct way to do a "bubble" print for a PPAP APQP and PPAP 35
D Suggestions for Ishikawa for hyperdetailed customer - plastic molding automotive parts Nonconformance and Corrective Action 9
J WAIVED ON Q1 - We Don't have to comply with FORDS customer specific requirements IATF 16949 - Automotive Quality Systems Standard 2
A Customer Approval (Medical Devices) Document Control Systems, Procedures, Forms and Templates 4
M Reduce occurrence rating based on the PMS data and customer complaint data ISO 14971 - Medical Device Risk Management 2
M IATF16949 Clause 9.1.2.1e - Customer notification related IATF 16949 - Automotive Quality Systems Standard 4
G Too many customer complaints Customer Complaints 16
lanley liao Does the customer`s trademark belong to customer-supplied property? Oil and Gas Industry Standards and Regulations 2
J Customer Complaint & SCAR, false data Nonconformance and Corrective Action 14
S Annual Inspection Layout - Based on Customer print ? IATF 16949 - Automotive Quality Systems Standard 8
G Risk of stopping your customer's line IATF 16949 - Automotive Quality Systems Standard 4
D CB and customer audits considered as internal audits? General Auditing Discussions 9
O Informational Ford Motor Company Customer Specific Requirements for IATF 16949:2016 - 08 Jan 2021 Customer and Company Specific Requirements 0
G Bad Parts cause Customer line stop IATF 16949 - Automotive Quality Systems Standard 13
O IATF 16949 News Ford Motors Customer Specific Requirements Update - Nov 2020 IATF 16949 - Automotive Quality Systems Standard 5
D Question regarding customer feedback process ISO 13485:2016 - Medical Device Quality Management Systems 3
B Retention Samples when Customer Leaves Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 1
M Email Template that go to a customer and then get returned to us for RMA/Warranty Document Control Systems, Procedures, Forms and Templates 1
B FCA US Customer Specific IATF 16949- Critical Characteristics 8.6.2 Customer and Company Specific Requirements 0
D ISO 13485 8.2.1 and 8.2.2 - Customer Feedback and Customer Complaints ISO 13485:2016 - Medical Device Quality Management Systems 5
J Customer Complaint Response 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
V Quality review Meeting with Customer for complaints we received Customer Complaints 6
D IATF16949 - Interpretation of Customer Requirements clauses IATF 16949 - Automotive Quality Systems Standard 3
S Obligation to accept customer audits? IATF 16949 - Automotive Quality Systems Standard 23
D IATF16949 7.5.3.2.1 Record Retention - Our Product or Customer Product? Elsmar Cove Forum Suggestions, Complaints, Problems and Bug Reports 1
S Customer Specific Requirements (CSR) not signed/approved IATF 16949 - Automotive Quality Systems Standard 17
B FCA US IATF 16949 Customer Requirements updates Customer and Company Specific Requirements 3
G Same parts but new customer - What will the auditor ask me? IATF 16949 - Automotive Quality Systems Standard 2
R Customer Satisfaction importance in companies with Government/Public Administration as main customer? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
G Self Assessment Audit from a new potential customer General Auditing Discussions 3
P Customer Corrective Action Requests in OASIS? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
Ooi Yew Jin Customer E audit preparation Quality Manager and Management Related Issues 2
qualprod Managing a "special" customer into the QMS? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
C Certificate of Conformance Form - COC for each customer a controlled document? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
R Who is the customer in the ISO/IEC 17025:2017? ISO 17025 related Discussions 1
BeaBea ISO 9001 Customer Feedback Methods - What has worked for your company? Service Industry Specific Topics 17
T Root Cause Failure Analysis - Not following Customer packaging Specification Problem Solving, Root Cause Fault and Failure Analysis 9
