What to do if no further control possible to reduce the OHS risk?
samsung
We had an observation during the stage -1 assessment.
"Organization needs to have adequate management program in place to control / reduce the severity level of risk associated with the operation of autoclave."
Scenario - We have an autoclave used to test the expansion of cement under the severest conditions, i.e. at 21 kg/cm2 pressure. The autoclave is operated in a moderately high occupancy area. the operators are qualified & trained, all mechanical safe guards in place, pressure guage is calibrated at the prescribed interval and a documented operation control procedure is followed by the staff. In addition, an emergency preparedness program (documented) is also in place and a copy is displayed in the operational area.
Based on our criteria of risk assessment, the residual risk is still very high in view of continuous exposure of people and the area being moderately occupied while the equipment is in operation.
There's no past history of any explosion in the plant during last 15 years nor any incidence heard of taking place elsewhere.
What more we can do to further reduce the risk level.
Request to share your experiences and best practices adopted.
I will appreciate your valued responses.
somashekar
I think I understand the scenario explained, but the observation statement I read makes me think how ever can one control or reduce the severity level, since in the event of occurance of an incident after all possible reduction in its probability, whatever severity is associated with it sticks with it.
The next step perhaps is like creating an engineering control (considered under a management program) by having a concrete wall seperating the autoclave from the people nearby such that even in the event of an unlikely explosion, a barrier is created to reduce the impact to the persons nearby and now with the wall included, the residual risk due to an incident can be different and less. The operation control procedure can mention about persons and location during the autoclave operation.
Jen Kirley
Quality and Auditing Expert
I have a question. What is at risk of exploding - cement dust from the autoclave's heat or spark? Is the autoclave gas fired?
ScottK
Not out of the crisis
I have the same primary question as Jennifer...
And I agree with Somashekar in that the next control might be to isolate the machine in an enclosure of either concrete or steel with a high burn through rating.
samsung
Neither dust not spark. It's electrically fired. Cement specimen are heated at about 215 degree C in water for around 3 hours inside a stainless steel chamber of about 1" thickness. It's somewhat like a steam boiler. What makes the machine hazardous is the steam pressure (21 Kg/cm3) at which the machine is operated.
The equipment is housed in a room at the ground floor of a 3 storey building. There are many offices at the ground and upper floors whereas the top most floor houses all the electronics/ automation centres as well as the main control room from where the entire plant is operated.
With all available controls, it's unlikely (but not impossible) that it will go off yet, under the operating conditions, if the equipment explodes in the most unfortunate of the events, it can knock the entire building down in no time while claiming numerous casualties.
Thanks.
ScottK
Thanks.
I can see why an insurance company might have issues :mg:
I'm not that familiar with cement manufacturing... what could cause and electrically fired oven to explode cement with that ferocity?
If it's that extreme I'd consider putting htis device in a separate room, detached from the building with red lights on every corner indicating when a test is in progress!
samsung
This autoclave is used in laboratory testing. Test conditions and operating procedure/ parameters have been prescribed by the regulatory authorities and are religiously followed.
Yes, one of the solutions can be the isolation of the hazard from the public place. I will discuss it with our people if it's workable.
Thanks.
Jen Kirley
A UCD Risk Assessment on autoclaves didn't include explosion due to failure of the unit itself, but from the business of loading, extracting and such use. Findings of safety evaluation at University of Oklahoma were similar, as was the risk evaluation at the University of Adelaide in Australia. Cardiff University's Guidance Document for autoclaves gives more information, but still focused on use and not explosion due to failure of the unit's physical integrity. Assemble enough of that kind of data and one can eventually decide risk of explosion is not severe enough to address, I expect with the exception of over-pressurizing the thing (if that's possible).
somashekar
Thanks.
The working pressure of 21 perhaps is far less than the safe working pressure of the autoclave, reading from the 1" thick steel housing and perhaps equally strong other mounted accessories.
Why not have a management program to install an emergency alarm which will activate when pressure inside the autoclave say reaches 25 or whatever safe limit feasible. This may be still far less than the pressure to explode the setup. This may activate when all other failsafe controls fails, and an evacuation to safe assembly area by all people will remove them from the site thereby the OHS purpose is acheived. The personnel who control at the third floor can also cut off all electrical supply to the autoclave as you say it is housed there, just before evacuating. Suitable drills of this situation can be put through and rehearsed.
Just my thoughts ~~~
R Control of Documents - Drawing (soft copy) for further work by other Consultants Document Control Systems, Procedures, Forms and Templates 1
N Sterilization Protocol Change in Validation Process and further impacts ISO 13485:2016 - Medical Device Quality Management Systems 1
M Pharmaceuticals News UK – Further guidance note on the regulation of medicines, medical devices and clinical trials if there’s no Brexit deal Medical Device and FDA Regulations and Standards News 0
M Medical Device News MedTech Europe - European Parliament further clarifies Commission proposal on HTA for medical technologies EU Medical Device Regulations 0
B Software Class A - Lengthy further risk analysis IEC 62304 - Medical Device Software Life Cycle Processes 9
K Further Analysis of Departmental KPI (Key Performance Indicator) Statistical Analysis Tools, Techniques and SPC 2
Sidney Vianna Auditors and CB's further investigating certified QMS' with ethical breaches? Registrars and Notified Bodies 8
M Further Inspection Required Form Misc. Quality Assurance and Business Systems Related Topics 1
Claes Gefvenberg Publication of ISO 45001 - Occupational Health and Safety - Further delays? Occupational Health & Safety Management Standards 6
G Further steps in Medical Devices Regulations in EU - Comments? EU Medical Device Regulations 11
P Further Own Brand Label questions - Urgent ISO 13485:2016 - Medical Device Quality Management Systems 6
F Customer Satisfaction Survey - Further actions needed for Customers Comments? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
M Two situations where it is appropriate to add further Hazard Audits to Internal Audit Occupational Health & Safety Management Standards 8
A How to further job skills to be a QA Manager? Career and Occupation Discussions 6
S Advice on Further Education for Practitioner interested in Quality? Professional Certifications and Degrees 1
P AS 9102 requirement for parts that need further treatment such as Anodizing AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
S Are Pp and Ppk more useful than Cp and Cpk as a benchmark for further studies? Statistical Analysis Tools, Techniques and SPC 1
Jim Wynne Further evidence that Microsoft is doomed: Ms. Dewey After Work and Weekend Discussion Topics 29
Hershal Movies - Further discussions Coffee Break and Water Cooler Discussions 3
S What to do after BE? Which type of studies will help me to shine further? Professional Certifications and Degrees 3
N Any recommended further reading for ISO/IEC 17025? ISO 17025 related Discussions 6
Casana Beyond CQE: Any suggestions to improve my knowledge further? Statistical Analysis Tools, Techniques and SPC 25
D Control Number for Class III and IV devices Canada Medical Device Regulations 0
C UDI Questions on Control Units Other US Medical Device Regulations 6
A Quality Control Datasheets Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
M Control-self assessment Internal Auditing 5
GreatNate Master Control QMS software Quality Tools, Improvement and Analysis 0
A Prototype control plan FMEA and Control Plans 2
shimonv Document Control Procedure Header Content Document Control Systems, Procedures, Forms and Templates 3
W FMEA - Current control and occurrence rating FMEA and Control Plans 3
G Control Plan & PFMEA Review Procedure? FMEA and Control Plans 1
N What are the software audit and control steps Reliability Analysis - Predictions, Testing and Standards 2
A Fabric roll inspection - What type of Control Chart to use? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
C Monitoring and Control Instruments RoHS, REACH, ELV, IMDS and Restricted Substances 3
M ISO14971:2019 - Verification of implementation and effectiveness of risk control ISO 14971 - Medical Device Risk Management 3
T Risks arising from control measures vs. ineffective control measures ISO 14971 - Medical Device Risk Management 11
J Need Change Control Yes/No Decision Tree Template ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
P IQ, OQ, PQ protocol, and report templates for Distributed Control Systems in Pharmaceutical Manufacturing Systems. Qualification and Validation (including 21 CFR Part 11) 0
R Risk control measures as per ISO 14971 ISO 14971 - Medical Device Risk Management 6
T Linking Control Plans and PFMEA's FMEA and Control Plans 3
P IATF 16949 requirement - error-proofing in control plan IATF 16949 - Automotive Quality Systems Standard 3
C 8.5.1.1 Control of Equipment, Tools, and Software Programs - Questions about the extent of control of NC programs AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
