What to do when 100 % verification is not 100 %
First, I am sorry if this comes across as confused - I am trying to figure this out.
We have an automatic measurement assembled machine, in which a robot arm moves an item along a series of steps. After turning, the item is moved to a steam cleaner, then it goes to one measuring device, then another measuring device. Then the computer decides if everything is okay: accept or discard.
So, this production of an item has 100 % measurement, with no sampling needed. My question is: what happens if any measurements is lost due to some incident. Let's say, as an example, that there is only data present to support that 90 % of the items has been measured and accepted. Is there any way to infer that the rest of the items are accepted?
The obvious option is to measure the whole lot again - but is there an alternative? I guess I can choose to do sampling, but then it would not be 100 % verification any more. But it would be a large sample, and it would demand that the measurement loss was not in a large chunk during the production cycle.
I hope I have been able to make myself understandable.
Thanks for reading!
Nicholas
Johnny Quality
Nicholas, is this 100% measurement a customer requirement? A requirement for a 3rd party?
Does your data suggest the 100% measurement is redundant? What is the consequence if a part that does not meet the tolerance falls through the chain? Will it be detected later?
Ed Panek
QA RA Small Med Dev Company
If I were reviewing post production DHR and I was missing 10% of my QC check data I would need to know why that happened, What the risk is, and then go through a MRB and disposition it.
For ISO 13485
If a deviation occurs in production the requirements state:
8.3 Control of nonconforming product
8.3.1 General
The organization shall ensure that product which does not conform to product requirements is
identified and controlled to prevent its unintended use or delivery. The organization shall document
a procedure to define the controls and related responsibilities and authorities for the identification,
documentation, segregation, evaluation and disposition of nonconforming product.
The evaluation of nonconformity shall include a determination of the need for an investigation and
notification of any external party responsible for the nonconformity.
Records of the nature of the nonconformities and any subsequent action taken, including the evaluation,
any investigation and the rationale for decisions shall be maintained (see 4.2.5)
Randy
Either change the requirement or change the process. 100% is 100% (each, every, all). 100% isn't 100% with the exception of unless that exception is well defined, understood and accepted.
Ronen E
Problem Solver
Moderator
Flag as non-conforming and run through MRB per your established SOP. Any concession should be appropriately rationalised, documented etc.
John Predmore
You say the measurement is lost, but does the sequence in the automatic inspection station change based on the result of the inspection?
If the automatic station takes an action based on the measurement - such as marking a defective part "reject" or placing the defective part in a reject bin, then you have indirectly the pass/fail results of the inspection on individual parts. By the way, a best practice is to also mark (in an inconspicuous way, such as a prick punch) an accepted part "pass" at the end of the inspection cycle. That is your assurance that no part somehow bypassed the inspection procedure. In this way, if any parts in your batch are suspect, you could hand sort for the inspection mark and that might be faster than remeasuring the entire lot.
G 100% Sort Verification - Statistical Method for Evaluating Suspect Material Statistical Analysis Tools, Techniques and SPC 19
L Verification of 100% Sort QS-9000 - American Automotive Manufacturers Standard 11
Ninja Windows 10 100 % disk use after update Coffee Break and Water Cooler Discussions 25
A 21 CFR part 11 - section 11.100 - Electronic Signature Certification Other US Medical Device Regulations 6
Stoic Manual soldering processes - 100% verifiable, or always requiring validation? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 13
E Correct way to certify hydrostatic testing when it is not 100% (and Sample Size) Various Other Specifications, Standards, and related Requirements 6
Nicole Desouza ISO / AS Certification - Small business with less than 100 employees ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
M EU – Chemical Safety Report – CSR – REACH Authorisation decisions – Triton X-100 – Ortho-clinical-Use1 REACH and RoHS Conversations 0
D Measuring fine tubing (< 0.100") "Wall by weight" General Measurement Device and Calibration Topics 11
Marc Anniversary of the First Trans-Atlantic Flight 100 years ago - June 2019 Coffee Break and Water Cooler Discussions 2
Y IEC 62304 Section 4.3(a) - 100% probability of failure IEC 62304 - Medical Device Software Life Cycle Processes 3
BHobbs_Busche All Measurements taken with a Variable Gage have to be Recorded 100% IATF 16949 - Automotive Quality Systems Standard 14
Pmarszal Clarification for 21 CFR Part 11.100 - General Requirements Other US Medical Device Regulations 14
S 100% Final Inspection Requirements of Active Medical Devices (MDD or IEC Standards?) EU Medical Device Regulations 4
B Is Gage R&R required on a 100% Dimensional Layout? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
K IEC 61010-2-100 Labeling question - IVD equipment Other ISO and International Standards and European Regulations 1
D Long length measurement of 18" up to 100" with an accuracy of .005 min General Measurement Device and Calibration Topics 8
F Yield reaction higher than 100% Manufacturing and Related Processes 3
S Suggestions for a 100% Paperless Manufacturing Shop Floor Quality Tools, Improvement and Analysis 10
Mikael Can OEE (overall equipment effectiveness) exceed 100%? Manufacturing and Related Processes 2
G Sampling Question - Random Sample of 100 pcs and 11 pcs. have been rejected Inspection, Prints (Drawings), Testing, Sampling and Related Topics 30
Marc 100 Years of Change in the United States - 1913 - 2013 Coffee Break and Water Cooler Discussions 5
E Is there a specific regulatory requirement for 100% inspection of IFUs? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
N Switch to 100% inspection when lot fails sampling? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
K 100 years war aviation - A plane is used for bombing World News 3
S ATA (Aerospace Testing Alliance) Specifications 100, 200 and 300 AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 1
K SPC to apply for Particle in Clean Room Class 100 Statistical Analysis Tools, Techniques and SPC 7
N What Makes Life 100% (joke) Funny Stuff - Jokes and Humour 0
V Supplier Capability and 100% Sort causing Gage Wear APQP and PPAP 1
P Sample Size to Test Products used for 100 hours in a Test Environment Reliability Analysis - Predictions, Testing and Standards 2
R Problems with Supplier - Always with 100% Sorting - No Corrective Actions Supplier Quality Assurance and other Supplier Issues 22
R Why do outgoing QA Sample Testing again when Product is tested 100% Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
Ajit Basrur China to launch 100 rockets, 100 satellites by 2015 Coffee Break and Water Cooler Discussions 1
V PPAP - Requirements when Cpk is <1.67 - 100% Sort for Defectives APQP and PPAP 8
G Is Controlled Shipping requirement Sampling Based or 100% Inspection? Misc. Quality Assurance and Business Systems Related Topics 3
J MSA Emergency - PV%=100(PV/TOL)in American? And that is correct? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 13
C What to expect in a GE Aerospace Audit of a 100 Person Machine Shop Customer and Company Specific Requirements 5
R Research involving a very small population (100 approx) - Help with Sampling Statistical Analysis Tools, Techniques and SPC 3
N 100% Inspection in Retail Warehouse which Ships Products to Customers Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
P FDA Part 820 Clause 820.100 Corrective and Preventive Action 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
J Can a Major Nonconformance be Open but 100% Resolved? IATF 16949 - Automotive Quality Systems Standard 6
K 100% Inspection or do the usual IQ, OQ, PQ Validation - Medical Molding Design and Development of Products and Processes 3
C Cleanroom Class 8 (100,000) Particulate Control and Warning Limits Statistical Analysis Tools, Techniques and SPC 1
S 100 Places to Remember Before They Disappear Coffee Break and Water Cooler Discussions 8
J Functional Test Sampling - Determining Sample Size to eliminate 100% Testing Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
S Taking samples in a 100 cavity mold for Xbar-R chart Statistical Analysis Tools, Techniques and SPC 1
Stijloor 100 Best companies to work for. Career and Occupation Discussions 0
arios Elsmar's Social Group "Mexican Curious" reached 100 Members Coffee Break and Water Cooler Discussions 8
J What Control Chart should be used for Microbial Limit (NMT 100 cfu/m3) Statistical Analysis Tools, Techniques and SPC 12
R Sample Size for P Chart - 100% Leak Test for Condensor Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
