What to reference when using (not calibrating) handheld measurement equipment
SJWUNDER
Can anyone help with the specifications to reference when using (not calibrating) handheld measurement equipment?
Jerry Eldred
That is a rather broad question. If you are speaing of handheld multimeters, digital thermometers and the like, I don't believe such a thing exists. I guess I don't quite understand the context. In QS9000 MSA you can read about requirements for measuring instruments used that could affect the quality of end product or services. There are requirements for repeatability and reproducibility.
If you are speaking of measurement standards in a calibration laboratory, there are requirements for the ratio between uncertainty of measurement of your measurement standards compared with the accuracy specifications of the unit being calibrated. The minimum ratio is "normally" 4:1.
If you could elaborate, I could try to give a better answer
Marc
You are talking about 'work instructions', not 'specifications'. The hand book which came with the instrument should tell you how to properly use the instrument. If not, write your own instructions. You could also contact the manufacturer and ask what they have in the way of operating / use instructions.
barb butrym
ASQ had a publication about measuring...can't remember the name...but it has been used for the certified mechanical inspector body of knowledge...that covered equipment use and care...when to use which piece, how to use/read, as well as proper handling. It had a picture of a micrometer on the cover...was about an inch thick, 8x11 paperback..last used it a few years ago....try the asq.org web site and go to publications/inspection. It was a great reference, may have been updated by now.....but was reasonable....about $20-$30 back then. even covered surface plates, gauge blocks, plugs...compatators..both old style and the new digital ones. Wasn't a standard.....but reflected good practice.
Does anyone have some sample calibration instructions for different types of gages that I could compare with my own?
I Supplier Using Reference Part for PASS/FAIL Inspection Supplier Quality Assurance and other Supplier Issues 8
S Using Prepared In-House Reference Materials (RM) for Equipment Calibration & Verifica General Measurement Device and Calibration Topics 3
B Unaccredited Test using my Temperature Sensor as a Reference General Measurement Device and Calibration Topics 1
E Using Customer Unit as Reference Standard General Measurement Device and Calibration Topics 14
S ISO 17025 Validation Requirements - "calibration using reference standards or..." ISO 17025 related Discussions 5
N Digital Temperature Indicator Calibration (Thermocouple) - Using a reference junction General Measurement Device and Calibration Topics 1
M SOPs - Reference Documents Section Document Control Systems, Procedures, Forms and Templates 3
B Reference to IEC 60950-1 in Amendment 2 IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
D Question on equipment - when to use reference only or research only stickers ISO 13485:2016 - Medical Device Quality Management Systems 5
J Marking "Distributed By" to product with distributors' reference-code EU Medical Device Regulations 3
Dazza 9001, 14001 and 45001 mandatory documents and records cross reference matrix Process Maps, Process Mapping and Turtle Diagrams 2
T CSE 5.01 reference on drawing Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
CycleMike GD&T - Hole pattern - Print (attached) has a single Datum Reference Frame Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
J Sample size for creating a data base as a reference to a tested variable Other Medical Device and Orthopedic Related Topics 6
R ASQ reference material clarification - Spiral bound materials allowed in ASQ Exam? Professional Certifications and Degrees 1
D Good Acceptance Activity/Inspection flowchart for reference - Wanted Please Process Maps, Process Mapping and Turtle Diagrams 2
G Customer complaint over a Reference Dimension Manufacturing and Related Processes 9
G Measure 3 times, for calibration report? Customer Owned Reference Standard General Measurement Device and Calibration Topics 4
I Data Backup Plan - Document Reference ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
Q How to efficiently and compliantly reference external standards/regulations Other Medical Device Related Standards 2
S Lot assignment for secondary reference standard - Pharmaceuticals Manufacturing and Related Processes 0
V Inspection with 3D Scanning - Reference Data Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
E Ethylene Oxide Sterilization Validation-Reference Load Other Medical Device Related Standards 2
C Must your reference standard provider be ISO17034 certified to meet your testing lab's ISO 17025 certification requirements? Other ISO and International Standards and European Regulations 2
C Do Calibration Reference Standards require an MSA study? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
J Purpose of Reference Section in SOPs Document Control Systems, Procedures, Forms and Templates 6
M Quality Policy - Standards and reference numbers ISO 13485:2016 - Medical Device Quality Management Systems 14
M Reference to IATF 16949 clause 8.4.3 in clause 8.3.4.4, Is it right? IATF 16949 - Automotive Quality Systems Standard 1
S Reference calibration tools (traceable to NIST) that are not used in production ISO 13485:2016 - Medical Device Quality Management Systems 4
S Contract Manufacturer Question - Whether or not the reference to the ex-CMO ISO 13485:2016 - Medical Device Quality Management Systems 6
B Need to convert Reference Only M&TE to a calibration schedule General Measurement Device and Calibration Topics 3
M Looking for Cross reference of AS9100:2016 to ISO13485 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
E Print only has Reference Dimensions Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
V QMS / QSR - Reference to Framework - Templates - Procedures for Medical Devices 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 11
R How to Cross-Reference Controlled Documents Document Control Systems, Procedures, Forms and Templates 3
E IEC 60601-2-25 Reference to 60601-1 2nd Edition IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
D Visual Inspection with No Visual Reference General Measurement Device and Calibration Topics 2
M AS9100 Rev. D - Can anyone recommend a good reference book? Book, Video, Blog and Web Site Reviews and Recommendations 7
B When to use "For Reference Use Only" on documentation Document Control Systems, Procedures, Forms and Templates 4
G BCARs/EASA to ISO9001/AS9100 cross reference matrix/table wanted EASA and JAA Aviation Standards and Requirements 1
J In the ISO 9001:2008 company, can give reference to sister company also. ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
E Use of Certified Reference Materials for Quality Assurance General Measurement Device and Calibration Topics 6
A Reference Source for Polarity Symbol Other ISO and International Standards and European Regulations 1
Q Multiple Quality Standards - AS9100 and ISO13485/9001 Cross Reference Matrix Quality Manager and Management Related Issues 3
E Reference Only on Gage or Visual Aid Calibration Frequency (Interval) 4
F Quality Objective Reference Chart Customer Complaints 4
V Good Documentation Practices - FDA Reference US Food and Drug Administration (FDA) 9
M Good reference sites or material to help me brush up quickly on Gage R&R Reliability Analysis - Predictions, Testing and Standards 7
J How does Layout Inspection determine Reference Value? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
