What would the FDA expect to see when they ask for our QSR?
Jimmy the Brit
#11
Yes essentially, making sure to cover other relevant regs like ISO13485 and or 9001 in the same matrix and listing any exclusions/exemptions you have with the associated justification.
It is imporatnt that it has sufficient granularity to be useful and is frequently revisited/revised to reflect current QMS status. A living document rather than a one-off list of procedures.
Tim Penrose
#13
So a 'living' document with issue numbers updated as and when they chage?
Jimmy the Brit
#15
That's what we do - I realise that is a lot of work but we were having problems with keeping people in step with updates so we required the local doc controllers to update the quality plans at any rev. change as part of the change control process. If you have your revision control under control that that may be a step too far - we just lack that connectivity between sites and our electronic document system is deeply flawed.
Doug Tropf
#16
Thanks for your comment so far but
QSR 820.186 Quality System Record says:
Each manufacturer shall maintain a quality system record (QSR)
Then the text in my original post with a final sentance:
Each manufacturer shall ensure that the QSR is prepared and approved in accordance with 820.40 (Document control)
Now a 'record' to me means a completed form used to record that an activity has been performed by someone at a particular time.
So from that I'm assuming a QSR is a controlled document that includes details of/reference to all documents held within the Quality System that are NOT product specific, and going by past experience is more than a list of document numbers and titles
Any further comments/advice?
Thanks in advance
This is from the ASQ Biomedical Quality Auditor Handbook:
"The QSR comprises general procedures and documentation of activities not directly related to a product or process. For many manufacturers, the QSR comprises the quality manual, lower-level SOPs, and the records documenting those activities".
jscholen
#17
We have a principal document that we call, "Quality Manual"...it states at a high level how we intend to be compliant to QMS...here's the table of contents of our QM (our QM is 29 pages long)
SECTION 4.0 Quality Management System
4.1 General Requirements
4.2 Documentation Requirements
SECTION 5.0 Management Responsibility
5.1 Management Commitment
5.2 Customer Focus
5.3 Quality Policy
5.4 Planning
5.5 Responsibility, Authority and Communication
Organizational Chart
Business Process Map
5.6 Management Review
SECTION 6.0 Resource Management
6.1 Provision of Resources
6.2 Human Resources
6.3 Infrastructure
6.4 Work Environment
SECTION 7.0 Product Realization
7.1 Planning of Product Realization
7.2 Customer-related Processes
7.3 Design and Development
7.4 Purchasing
7.5 Production and Service Provision
7.6 Control of Monitoring and Measuring Devices
SECTION 8.0 Measurement, Analysis and Improvement
8.1 General
8.2 Monitoring and Measurement
8.3 Control of Nonconforming Product
8.4 Analysis of Data
8.5 Improvement
Appendix 1 Correlation Matrix for FDA QSR and Company procedures
Appendix 2 Correlation Matrix for ISO 13485:2003 and Company Procedures
Appendix 3 Quality Management System Planning Chart
Appendix 4 Product Realization Planning
Appendix 5 Design and Development Planning
Appendix 6 Measuring and Monitoring Planning
Revision History
Hope this helps
Tim Penrose
#18
Thanks to all
We have a quality Manual too but it's geared around ISO 9001:1994. We took a concious decision not to rewrite it when the 2000 version came out and we only have certification to ISO 13485:2003 so in a way it's a bit out of date though it does reference the 21 CFR part 820 clauses
Once again, thanks to you all
:thanx:
Weiner Dog
Med Device Consultant
#19
Kim Trautman's ASQ book "The FDA and Worldwide Quality System Requirements Guidebook for Medical Devices" is a good resource. Additionally, you can also refer to FDA's QSIT Manual http://www.fda.gov/cdrh/comp/gmp.html The QSIT manual "Preannounced Inspections" and "Management Controls" sections cite the typical documents FDA investigators ask to examine prior to and during the audit visit.
W
Watchwait
#20
Its very easy to confuse "Quality System Regulation" with the "Quality System Record". The latter is a subset of the former. 21 CFR 820.186 spells out the requirement for the Quality System Record.
FYI...here's an example of our Quality System Record procedure - and the QSR itself. My only advice is NOT to list the revision levels of the documents referenced in the procedure. Otherwise this would require constant maintenance. This way, it only needs to be revised it we create a new - or eliminate an existing procedure.
If you're like me - an example/template is worth a thousand words...
I 510k Performance Testing Studies (Raw Data) - What does the FDA expect 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
A What to expect if FDA wants to inspect a Class 1 Medical Device Manufacturer ISO 13485:2016 - Medical Device Quality Management Systems 1
S Does FDA expect suppliers to be independently assessed to 21 CFR Part 820 ? US Food and Drug Administration (FDA) 4
K IT Specialist /FDA - Interview Questions to Expect Career and Occupation Discussions 5
S Transitional Adolescent A and B - "CDRH PREMARKET REVIEW SUBMISSION COVER SHEET FORM FDA 3514" Medical Device and FDA Regulations and Standards News 1
P MSDS for MVQ FDA White, Vinyl Methyl Silicone Rubber EU Medical Device Regulations 4
C RA (Regulatory Assurance) Training (FDA) looking for resources Training - Internal, External, Online and Distance Learning 5
E FDA 513(g) Cover Letter US Food and Drug Administration (FDA) 5
S Records - Do's and don't' of record entries (FDA - 21 CFR 820) Records and Data - Quality, Legal and Other Evidence 13
B New Facility register with FDA Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 4
J FDA regulation on decorative contact lenses Medical Device and FDA Regulations and Standards News 5
P Anyone have an Idea on UAE Medical device registeration- Class B with FDA only Other Medical Device Regulations World-Wide 0
F FDA classification for a mobile app Medical Information Technology, Medical Software and Health Informatics 3
Ed Panek IFU Contact Requirements - FDA and MDD/MDR US Food and Drug Administration (FDA) 1
O Any info on release date of FDA “Computer Software Assurance for Manufacturing and Quality System Software” document? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
P Writing a presubmission to the FDA prior to the De novo submission US Food and Drug Administration (FDA) 4
K FDA - Can we have more than 1 Initial Importer Medical Device and FDA Regulations and Standards News 4
K Two FDA questions regarding UDI (and potentially 803.52 MDR) Other US Medical Device Regulations 0
R Importers - For the FDA Registration/ Listing, is the CMO the importer? Medical Device and FDA Regulations and Standards News 6
Z Iterative development and FDA change requests IEC 62304 - Medical Device Software Life Cycle Processes 12
P FDA Approved Product Contact Parts ISO 13485:2016 - Medical Device Quality Management Systems 6
O Clarifying FDA definition of "finished device" and “capable of functioning” 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
A FDA guidance on non-sterile Medical Device Packaging Medical Device and FDA Regulations and Standards News 7
JoCam FDA Registration for Sub-contract manufacturers Medical Device and FDA Regulations and Standards News 2
M FDA News FDA Releases Draft Guidance Clarifying Application of ISO 10993-1 Biocompatibility Standard Medical Device and FDA Regulations and Standards News 0
E Contract manufacturer FDA requirements foreign company US Food and Drug Administration (FDA) 6
P Choice of FDA reviewer US Food and Drug Administration (FDA) 6
J Is Device Tracking Card an actual requirement under FDA regulation? Other US Medical Device Regulations 0
T Definition Human Use (FDA) Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 7
K FDA 510k electrosurgery 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
J Leveraging FDA 510k Clearance for International Registrations Other Medical Device Regulations World-Wide 2
shimonv FDA News FDA guidance on Multiple Function Device Products (8/2020) Other US Medical Device Regulations 1
N FDA UDI - Label vs. Labeling - Does the insert need to include UDI? Other US Medical Device Regulations 1
J FDA notification of address change US Food and Drug Administration (FDA) 2
N Usability testing required for FDA IDE (investigational device exemption)? Human Factors and Ergonomics in Engineering 8
A FDA Class Classification for a cabinet 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
L FDA Biocompatibility Requirements - Transitory Contact Other US Medical Device Regulations 1
Edward Reesor FDA DM and /or Class I Life Saving US Food and Drug Administration (FDA) 0
Watchcat FDA will not tolerate fraud…meaning what, exactly? Other US Medical Device Regulations 8
K FDA Premarket Cybersecurity Guidance - 4 questions Other US Medical Device Regulations 5
