What would you do in the first 90 days of a new job as the Quality Manager
K
kyoshin_man
Currently moving into a new section of the company thru promotion Aerospace bolts, screw, fixtures manufacturer and I am looking for advice, opinions, suggestions and comments on what should be done during the first 90 days of a new job as the Quality Manager, very fresh behind the ears.
The site is established with TS-16949 and I will need to review the Quality Dept and looking for ideas and complete my action plan and to do list.
Can I ask for some suggestions on where you all as experts here started when going into a new facility or to take over a dept?
Any help at all is appreciated as I am trying to learn and do the best job I can.
Bill :bonk:
Jen Kirley
Quality and Auditing Expert
Re: What would you do in the first 90 days
Aside from the obvious (study the QA Manual and process documentation and how the systems work): Look. Listen. Be attentive to learn who is able and willing to support your efforts, and pay attention to reasons they bring what they do to the organization. Try to understand if there was a person who was overlooked or declined for promotion to the position you were hired for, and what happened; the dynamics surrounding such circumstances can provide constraints to good performance.
Look around to see what has been done for audits and corrective actions; pay attention to what was given to top management as systems performance data is concerned, and what management's responses have been.
Seek to understand top management's goals and how they have resourced what initiatives to achieve the goals. Study how the departments work together and communicate to help each other accomplish their respective missions. Identify disconnects between responsibility and authority. Be sensitive to identify any push-pull forces that can slow down progress.
This should keep you busy for awhile!
Michael_M
Depending on several different options, I would:
1. Review personal and personal positions. Find out who does what and who 'should' be doing what. I have found that those who should be doing something are not because someone else is doing it.
2. Review the Quality Procedures. Read through it once, then after a day, read through it again, this time taking notes. Review what is being done vs. what should be done.
3. Try not to make too many changes to the process (unless it really needs it) right off the bat. Learn what is being done and why, why is very important.
Just my :2cents::2cents: (it has moved up to 4 cents, inflation has hit).
Chance
1. Observe if people are aware about their procedures. Are they using/monitoring it for improvement? If not, who is monitoring it then?
2. Ask them this question "Who is in-charge of quality?" If they say QA department. You have work to do.
3. After finding out if there are procedural gaps, examine why. Is it because of bureaucracy? Are people's voice being heard? If not, why not. This is tough.
4. Be people's friend, try to help them, talk to them, but don't push too hard. They might give up.
:2cents: cents for you. Congrats and goodluck!!!
silentrunning
This is top notch advice. It shouldn't take long to find out the company's strengths and weaknesses using previous audits. This could make you look real good real quick!
JLang
If you do all of the above you will be off to a great start. One thing I would strongly suggest is to find time to spend on the bottom of the ladder. Make sure you know what the people below you do and how they do it. Just as important is to observe or possibly even do some training out on the shop floor. I know this may seem time consuming, but I have found this to be quite important. If management (even from different departments) does not have a good understand of how things work in other departments (especially the floor) it can lead to a lot of wasted time and efforts. Root Cause analysis seems to go much smoother when you yourself have done those operations before. This is, of course, largely dependant upon the size and scope of your company as well. Good luck!:cfingers:
Steve Prevette
Deming Disciple
The bottom line is - what are you inheriting? Is the expectation for you to go in a "shake things up"? Just keep on keeping on?
That really establishes the tone of your initial 90 days.
I'd suggest studying some of Tom Peters' materials. If you don't have any of his books, there is a LOT of free stuff on his website.
Wes Bucey
I buy into Steve Prevette's thinking here.
  1. The first, most important question is,
    "What were you hired to do?"
  2. If you are now "aerospace," are you expected to add AS registration?
  3. Did the previous guy leave, die, or get promoted?
  4. If he's still around, an orientation might be useful versus starting from scratch.
  5. If the TS audit most recently completed is clear, what action plan did you have in mind?
  6. If not clear, what corrective actions (root cause investigation, etc.) are already in progress before your arrival? (If not in progress, why not?)
My memory of fastener manufacturers is that most change required would be incremental, not major - it's a pretty stable industry.
ssz102
what is expect for boss to you?
the status of work distribution for youself dept and dept organization chart
checking the content and quantity of customer complaints;
know the relationship for per dept and the leader or supervisor with the boss
go to workshop and look actually operation status
finally, prepare a improvement action plan to top management
K
kyoshin_man
I would like to thank you all for your comments and advice, these are all excellent ideas and have most of these in my mind at this moment.
But to see some other areas that I did not think of is fantastic and my eyes are now even wider than before and has given me more confidence to achieve my goal that is expected.
What a wonderful and professional place this is when help is needed and people come to the rescue to assist fellow professionals. All the comments and advice are spot on, very much appreciated and will help me considerably for my future new roll.
Thanks again everyone.
Bill :applause::agree:
M Hiring Decisions - How much effort do you put into the hiring process these days? (7/2020) Misc. Quality Assurance and Business Systems Related Topics 6
Q ISO 9001:2015 man days for surveillance audit ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
A IAF MD 5 - Audit Days calculator General Auditing Discussions 2
M Setting deadlines (ex. 45 days) for Document Registration & Review Cycle Document Control Systems, Procedures, Forms and Templates 3
A Man Days for IATF 16949 Audit IATF 16949 - Automotive Quality Systems Standard 5
M AS9100 Rev. D Transition Audit - Number of Audit Days AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
D Number of Audit Days - AS9100D Transition for a Small Shop AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
S Interpretation or Definition of ‘Once Every 5 Days’ ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
Stijloor Calculating (3rd Party) Audit Days for Company with Seasonal Employees General Auditing Discussions 3
Q Scheduling IATF 16949 Audits - Audit Man-Days IATF 16949 - Automotive Quality Systems Standard 9
S Internal Audit Man-days requirements using IAF MD9 General Auditing Discussions 2
Crimpshrine13 Rules of achieving and maintaining IATF recognition - Determining audit days IATF 16949 - Automotive Quality Systems Standard 2
J One third of the total audit days on manufacturing (TS 16949) General Auditing Discussions 2
T Reduced Audit days when UPGRADING from AS9100 to TS16949 - Is it possible? IATF 16949 - Automotive Quality Systems Standard 2
L 20 days to submit PPAP APQP and PPAP 9
P Scope Extension Audit - How many days? Do I audit all AS9100 requirements? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
J Audit days calculator based on Rules 4th IATF 16949 - Automotive Quality Systems Standard 2
kedarg6500 Could I have a recalibration frequency of +/- 15 days ? Calibration Frequency (Interval) 23
B Any future for someone working as Lead Quality right these days? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
J Required Audit Days for TS 16949 Initial Certification Audit IATF 16949 - Automotive Quality Systems Standard 1
T AS9104/3 is bringing in a requirement for an AA to qualify as AEA based on Audit Days AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
J How to calculate Surveillance Audit Days in Corporate Audit Scheme IATF 16949 - Automotive Quality Systems Standard 4
somashekar About NC (Nonconformance) Type and days for CA (Corrective Action) Response... ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
Marc Business These Days - Maker's Mark waters down bourbon to meet demand Coffee Break and Water Cooler Discussions 11
X Shall not exceed 2 working weeks = shall not exceed within 10 working days? IATF 16949 - Automotive Quality Systems Standard 2
S The days before International Standards - Has ISO done what it was supposed to? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
D Number of Audit Days for AS9100C Surveillance Audit (20 employees) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
Randy It's only 97 days until the 2013 DAYTONA 500 Coffee Break and Water Cooler Discussions 4
B How many days after an interview should I follow up on the status of the interview? Career and Occupation Discussions 10
M IAF-MD9 Audit Man-Days Requirements for ISO 13485 Quality Manager and Management Related Issues 30
M Calculating the IATF TS 16949 Recertification Audit Man Days - Clarification ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
T Deviation Tracker - Anyone have a template that can efficiently track 4 days of data? Customer Complaints 2
R Becoming a Certified Aerospace Auditor - How to get the required audit days AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
J AS91X0 Audit Man-Days Calculation - Risk for the Organization? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
J Audit Days Requirement for AS9100, Rev C Re-Certification AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
S PP (Polypropylene) Plastic part becomes brittle after 2-3 days Manufacturing and Related Processes 5
C ISO/TS 16949:2009 Audit Man Days Table IATF 16949 - Automotive Quality Systems Standard 15
A 510(k) Review time past 150 days?! 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
J What is Manufacturing Extension? Audit Man-Days General Auditing Discussions 6
S ISO 17025 Audit - 12 Days for 3 Auditors - 20 Employees ISO 17025 related Discussions 8
G Calculating AS9100 Registrar Audit Man Days AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
K Please help Calculate Audit Man Days Process Audits and Layered Process Audits 8
M ISO 9001 Re-Certification Audit: How Many Man-Days? General Auditing Discussions 6
D FDA Days - What is the FDA definition of FDA Days 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
A What happens if an External Audit NC (Nonconformance) is not closed in 90 days? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
A Query on Certification Man Days for ISO 9001:2008 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
P Panic time! Audit in three days! ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
S Calculation of Man-Days for OHSAS Audit Occupational Health & Safety Management Standards 3
A Cost of ISO 9001:2008 certification and certification audit days? Registrars and Notified Bodies 10
K Is ISO9001 Certification (Registration) in 30 days realistic? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 23
