Whats the difference in applying error factor and correction factor?
G
ggdjr
in regards to thermocouples and temperature control instruments.
What do you do if your correction factor is less than your measurement of uncertainty?
thanks in advance,
GD
Hershal
Metrologist-Auditor
Re: Whats the diff. in applying error factor and correction factor?
I would apply the correction factor and then calculate the uncertainty again.....
P Whats the difference between SOP and QMS ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 26
J Quality Manuals and Quality Plans - Whats the difference? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 31
R Whats the difference, ISO vs EN ISO Std's ISO 13485:2016 - Medical Device Quality Management Systems 6
R Whats different between these position CE Marking (Conformité Européene) / CB Scheme 10
L Process Measurement - ISO 9001:2008 Clause 8.2.3 - Whats your Interpretation ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
A Whats the rationale for a Sample size of 30 for Capability Analysis? Statistical Analysis Tools, Techniques and SPC 5
B What is the difference btw RUO vs IUO for IVD in FDA guidance ? US Food and Drug Administration (FDA) 9
G What's the difference between 1.32 and 1.33 Cpk? Capability, Accuracy and Stability - Processes, Machines, etc. 18
W What is the difference between TYPE B and TYPE BF? IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
Q Terminal Lugs sizes - Difference between 225/24 vs. 275/24 lugs Manufacturing and Related Processes 2
M Difference between "Production Trial Run" and "Run at Rate" IATF 16949 - Automotive Quality Systems Standard 8
Y Labeling difference for storage and operating conditions EU Medical Device Regulations 1
T Difference between a subcontractor and a supplier ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 21
H Difference between Stainless Steel 316 ASTM F899 and ASTM A276 Other Medical Device Related Standards 3
A Exact terms for a plating failure and difference between rejection rate and failure rate Manufacturing and Related Processes 9
gramps What is the difference between discrete and continuous variables? Problem Solving, Root Cause Fault and Failure Analysis 3
JoCam Difference between Approval and Registration - ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 2
S Difference between EU-MDR Annex IX and the Annex-combo X&XI EU Medical Device Regulations 4
Nicole Desouza The Difference of being AS 9100D Compliant vs.Certified AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 13
C IEC 60601-1-8, difference between table 4 and annex D IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
A What is the difference between Basic UDI-DI and UDI-DI? EU Medical Device Regulations 6
Q What is the difference between AS9100D 9.3.2.f and 9.3.3.a AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
M Aluminum - What is the difference between 6061-T6 and 6061-T651 (both per ASTM B211)? Manufacturing and Related Processes 4
R The difference b/w FMEA & Risk analysis as per iso 14971 ISO 14971 - Medical Device Risk Management 8
P What is the exact difference between Risk and Opportunity in context of ISO 27001? IEC 27001 - Information Security Management Systems (ISMS) 7
S Difference between Surface Finish (Ra) and Flatness (GD&T) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
O Air Flow - Which is the operational difference between LAF (vertical and horizontal) and RLAF? Manufacturing and Related Processes 2
S What the difference is between Stub Acme & Acme thread? Oil and Gas Industry Standards and Regulations 1
S DO 178B - What is the difference between review and verification? Federal Aviation Administration (FAA) Standards and Requirements 1
T The difference between SOP and Kaizen Standardization Lean in Manufacturing and Service Industries 2
K Difference between intended purpose and intended use of the device EU Medical Device Regulations 9
S Difference between an Advisory Notice (ISO 13485) and a Field Safety Notice? ISO 13485:2016 - Medical Device Quality Management Systems 3
T Difference between "data analysis" and "management review" ISO 13485:2016 - Medical Device Quality Management Systems 4
qualprod What is the difference between 7.4.1 (2008) and 8.4.1 (2015)? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
S Is there a difference in the process? Analyze residuals, construct interval estimate Using Minitab Software 2
S EASA Part 145 - The difference between non-certifying staff and Certifying staff Federal Aviation Administration (FAA) Standards and Requirements 2
S Certification Body, Registrar, Notified Body - What is the difference? Registrars and Notified Bodies 3
S The difference between a Medical Device Accessory and Component Canada Medical Device Regulations 2
S What is the difference between a service request and a complaint? ISO 13485:2016 - Medical Device Quality Management Systems 2
