When and Where are Special Audits used?
dsanabria
As I talk to different customers, there seems to be a curiosity for when and where "Special Audits" are used.
I have heard of 2 from Boeing (one was on FOD - Foreign Object Debris, and the other on a potential escapes) but my experiences are limited.
Any one has a scenario of a "Special Audits" that they would like to share?
Sidney Vianna
Post Responsibly
ISO 17021 9.5 Special audits
9.5.1 Extensions to scope
The certification body shall, in response to an application for extension to the scope of a certification already granted, undertake a review of the application and determine any audit activities necessary to decide whether or not the extension may be granted. This may be conducted in conjunction with a surveillance audit.
9.5.2 Short-notice audits
It may be necessary for the certification body to conduct audits of certified clients at short notice to investigate complaints (see 9.8), or in response to changes (see 8.6.3), or as follow up on suspended clients (see 9.6). In such cases a) the certification body shall describe and make known in advance to the certified clients (e.g. in documents as described in 8.6.1) the conditions under which these short notice visits are to be conducted, and
b) the certification body shall exercise additional care in the assignment of the audit team because of the lack of opportunity for the client to object to audit team members.
9.6 Suspending, withdrawing or reducing the scope of certification
9.6.1 The certification body shall have a policy and documented procedure(s) for suspension, withdrawal or reduction of the scope of certification, and shall specify the subsequent actions by the certification body.
9.6.2 The certification body shall suspend certification in cases when, for example, the client's certified management system has persistently or seriously failed to meet certification requirements, including requirements for the effectiveness of the management system, the certified client does not allow surveillance or recertification audits to be conducted at the required frequencies, or the certified client has voluntarily requested a suspension.
9.6.3 Under suspension, the client's management system certification is temporarily invalid. The certification body shall have enforceable arrangements with its clients to ensure that in case of suspension the client refrains from further promotion of its certification. The certification body shall make the suspended status of the certification publicly accessible (see 8.1.3) and shall take any other measures it deems appropriate.
9.6.4 Failure to resolve the issues that have resulted in the suspension in a time established by the certification body shall result in withdrawal or reduction of the scope of certification.
NOTE In most cases the suspension would not exceed 6 months.
9.6.5 The certification body shall reduce the client's scope of certification to exclude the parts not meeting the requirements, when the client has persistently or seriously failed to meet the certification requirements for those parts of the scope of certification. Any such reduction shall be in line with the requirements of the standard used for certification.
9.6.6 The certification body shall have enforceable arrangements with the certified client concerning conditions of withdrawal [see 8.4.3.d)] ensuring upon notice of withdrawal of certification that the client discontinues its use of all advertising matter that contains any reference to a certified status.
9.6.7 Upon request by any party, the certification body shall correctly state the status of certification of a client's management system as being suspended, withdrawn or reduced.
I don't have my copy of ISO 19011 handy, but will try to partially answer your question.
I think a lot of the answer depends on what you classify as special audits. I promote using supplemental audits when conditions indicate additional auditing needs. For example, Your audit of material handling process is scheduled for November. During an unrelated audit (say... calibration), you discover a container of unidentifed product in an area you know product should not be stored. It is the end of March. Would you want to wait until November to audit the material handling process? Probably not, so you would use a supplemental or special audit. Or if you substantially change a process, or suddenly have a rash of nonconforming product (or anything else that would relate to process status discussed in 8.2.2).
Hope that helps... somewhat.
dsanabria
Sidney:
Are these from the new - just released AS 17021? - I don't have a copy but many thanks.
Sidney Vianna
Post Responsibly
There is no AS 17021. This is from ISO 17021:2011
AS9101D states
4.3.6 Special Audits
[ISO/IEC 17021 clause 9.5]
Special audits can be performed anytime during the certification cycle in response to one of the following situations:
a) in response to a customer or other interested party request, when a serious issue (supported by objective evidence) has been identified;
NOTE: In this case, the requester shall be notified in advance of the audit dates and made aware of the audit results.
b) in response to an organization’s request to change their scope of certification (commonly known as extensions to scope) or revise the listing of certified sites; or
c) when transferring certification from one CB to another.
NOTE: In this case, the pre-transfer review of the existing certification (see IAF MD 2) shall include an audit of the prospective organization site(s) by an AEA. Items listed in clause 4.2.1 shall be evaluated, including a review of previous certification audits performed by their prior CB (see requirements for transfer of certifications defined in 9104).
These audits shall be coordinated with the organization prior to the visit. The organization shall be given information about the specific reason and subject of the visit.
An audit plan shall be completed and submitted to the organization prior to arrival. The results for special audits shall be documented on the applicable appendices (e.g., Appendices A, B, C, and E).
Sydney, questions.
In case the scope extension audit is done during surv audit,is it a requirement to add audit hours,even if the employee count remains same?
Is it a requirement to prepare seperate audit plans-one for scope extension and one for surv audit and also to prepare two audit reports?
Sidney Vianna
Post Responsibly
It obviously depends on the nature of the scope extension. For the most part, yes, a scope extension would require additional time since you have to EXPAND the sampling of the system being assessed to ensure that all applicable requirements are deemed conforming.
A requirement? From whom? Certainly not the 17021 standard. It is up to the Conformity Assessment certification body to decide the requirements on the documents associated with the scope extension audit. One CB might differ from the next.
J UDI - Where to document it? EU Medical Device Regulations 8
J Where to get a Black belt certification ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 13
D Any recommendations on where to find experienced quality hires in Chicago area? Job Openings, Consulting and Employment Opportunities 3
J Where is the definition of a critical supplier? ISO 13485:2016 - Medical Device Quality Management Systems 5
W Where does a coatings and paint company fall in IATF? IATF 16949 - Automotive Quality Systems Standard 5
B When Travel is allowed - Where are you going? Travel - Hotels, Motels, Planes and Trains 16
G Where to buy Template / sample SCSMS Manual, checklist Supply Chain Security Management Systems 1
M Quality Manual - Where does Revision History Section go? Document Control Systems, Procedures, Forms and Templates 8
C Where to draw the line for "sufficient evidence" to verify safety/performance of a device? CE Marking (Conformité Européene) / CB Scheme 2
L Where to place the what/when/how/who/where procedures in a multi-regulation AS9110C organisation AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
B Where to acquire EN 868-5 required dye (Amaranth red)? Other Medical Device Related Standards 2
N Where to find Regulations for Reprocessing and Reuse of Single-Use Devices Other Medical Device Related Standards 2
H Where to get EK MED 1927/16 Other Medical Device Regulations World-Wide 3
D Where to find Guidance Class II Amendment Canada Medical Device Regulations 1
O EN 301 489-1 and EN 301 489-17 - Where do we get the information of the Published versions? CE Marking (Conformité Européene) / CB Scheme 1
A AS9100 Training - Where do I start? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 14
qualprod Records where apply and stop recording everything? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
C Where to place CE/label in Sterile IVD EU Medical Device Regulations 1
G New to ISO 9001 - Where to begin? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
BeaBea Interesting Discussion Where Does Marketing/ Advertisement of Products fit in to ISO 9001? Process Maps, Process Mapping and Turtle Diagrams 39
K No IFU, where the requirements would go? EU Medical Device Regulations 5
T Assessing Hazard-Related Use Scenarios where control measures exist through standards IEC 62366 - Medical Device Usability Engineering 32
J Where to Place Process Maps in our Documentation? Process Maps, Process Mapping and Turtle Diagrams 4
GreatNate Where to get a KPI dashboard for QMS processes Quality Tools, Improvement and Analysis 5
A Implementing ISO 20000-1 - Where to start Other ISO and International Standards and European Regulations 2
D Where does "as far as possible" stop? FMEA - EN 14971 ISO 14971 - Medical Device Risk Management 29
qualprod Statistics - Where to start in ISO 9001? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
H Calibration of InfraRan Vapor Analyzer - where to get calibration for SF6 General Measurement Device and Calibration Topics 2
M Where can I find examples of PPAP? APQP and PPAP 6
A What if Contract Manufacturers does not have an ISO 13485 certificate? Where will the NB audit take place, at legal mfg. site or contract mfg. site? Other Medical Device Regulations World-Wide 3
J Where can I find the latest update to Reach and ROHS? REACH and RoHS Conversations 9
D Where (in US) can I get the VDA Auditor Edition book? VDA Standards - Germany's Automotive Standards 3
S Where to get online AS standard audit certification classes? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
J Where I can get a copy of either the 3rd or 4th edition of UL544? Other Medical Device Regulations World-Wide 7
G Where to find Proficiency Test provider for photometrics (spectral %R, %T, photo density) General Measurement Device and Calibration Topics 9
Marc Quiz - Where did the idea of an assembly line come from? Coffee Break and Water Cooler Discussions 4
F Quality Objectives - Where in the QMS Quality Objectives should be located ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
M Where to obtain a calibrated DICOM image? ISO 13485:2016 - Medical Device Quality Management Systems 1
R Where to get information - M6 per WA900 Manufacturing and Related Processes 1
S Where did FDA 510(K) form 3654 go? Other US Medical Device Regulations 4
W Where to begin with an ISO 9001:2015 internal audit Internal Auditing 13
D China - Where I can get NMPA complete structure/organogram chart and GB/YY format list China Medical Device Regulations 1
D Where does FMEA fit in your ISO 14971 Risk Management process? ISO 14971 - Medical Device Risk Management 13
CCaantley Where to get a good test indicator stand for a granite surface plate General Measurement Device and Calibration Topics 8
I ESD - Dissipative foam on a seat for where the people sit at benches Manufacturing and Related Processes 6
