When do FORMs and Log Files become Records?
ISO_Man
I trust that everyone is staying safe and healthy.
I have a question, and if I might ask, please don't ask me what my document control policy says .. I own that policy and I'm looking for advice to change it.
I have someone who uses a file daily, it's created with a form, let's call it XYZ. As soon as she downloads a copy of XYZ and starts using it, it's no longer a released form, but a record based on that form. She uses the form all of the time as a log file of activity, and may end up using it for months, simply adding to the form. As she adds new information other's need to be able to see the form also.
Scenario is this - she uses the file indefinitely, it gets backed up automatically every day/week whatever - but no changes to the original, released version of XYZ. Is there anything in ISO-9001, other than the protection of data,etc. - what prevents her from doing this?
Other considerations?
Thanks for your help.
heiss
We have multiple log files that are used similar to what you described. The way we deal with such files, is the template of the form is controlled, and is in the master document list. As long as the user is not changing the functions of the form I don't see an issue with it.
ISO_Man
Are you ISO-9001:2015 certified?
In most cases, forms do not have to be controlled. Instead, control the information that's to be recorded via a documented procedure "documented information." Specify in the document that any convenient format may be used. You can still provide a form. In your situation, what happens when the form changes while it's in the sort of continual use that you describe?
ISO_Man
Nothing other than the addition of information. I've explained to the process owner that they can decide much "permanent" information is in the form and how much "changeable" information so that they can determine how frequently the form would need to be re-released.
Is form XYZ controlled in your system?
Jean_B
The case sounds more akin to a log receiving (multiple) record entries, than a form producing a single complete record (set of data linked to that record entry's unique identifier). Thus it is like controlling a database. The essential thing there is if you add a column to the table how to assess it over previous record entries (nil, null, not available, do calculate/retrospectively add) , and that you don't kill off what (column) makes a record entry uniquely identifiable.
Since this is not digital, you'd look at it as if it's at the highest level of control in the olden days: (classified) laboratory logbook.
Have the form's issue (verb) be authorized: and the authorizer notes a unique log identifier on the form (now becoming a record), that unique identifier in their own controlled copy log (which may be specific to this form, nothing prevents you having multiple), as well as date of issue, issued to, field location, revision of issue. You'll have further columns for date retrieved and perhaps some metadata to allow the log to serve easily as an index, which are only filled in as the finished (even if not full) is returned.
Add in an audit on this type of control process: issue, in field retention, returns. Or add a interval based check on each such issued item to see whether it's still there.
If you think they might be lost, prepare a comment field or other type of explanatory control. You don't want to be caught having to investigate what happened because someone else found out it's missing.
It's most akin to issuing controlled copies of already approved documents, but you won't scrap them in the field when superseded as what's added to them is essential.
C Excel .xls Log for Records Instead of Paper Forms Excel .xls Spreadsheet Templates and Tools 12
A Electronic forms QMS Document Control Systems, Procedures, Forms and Templates 7
E Document Change Request forms (or no forms)? ISO 13485:2016 - Medical Device Quality Management Systems 9
D Rules for Paper Forms outside of an eQMS - 3 Questions (ISO 13485) Document Control Systems, Procedures, Forms and Templates 9
M Forms review Manufacturing and Related Processes 5
T Controlled Forms or documented requirements for records? ISO 13485:2016 - Medical Device Quality Management Systems 2
Q Serialization and Reconciliation of Forms Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 7
G Any good examples of CAPA forms that include a risk based approach? ISO 13485:2016 - Medical Device Quality Management Systems 8
Q Forms Master List versus Record Matrix ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
M What to do about Non Conformance forms that are deleted or missing? Nonconformance and Corrective Action 4
R Purchase order forms - who keeps them? ISO 13485:2016 - Medical Device Quality Management Systems 3
GreatNate Various Audit Templates - Canned forms and templates Document Control Systems, Procedures, Forms and Templates 9
W Informational MDSAP Substantial change / Change of notice forms Document Control Systems, Procedures, Forms and Templates 2
D Internal audit forms or checklists for a medical/veterinary laboratory General Auditing Discussions 5
I Document levels and approval requirements for lower level documents like work instructions, forms etc. Document Control Systems, Procedures, Forms and Templates 18
S Supplier Audit Assessment / Evaluation Forms IATF 16949 - Automotive Quality Systems Standard 1
K Do Forms and Templates ALWAYS become Records? Records and Data - Quality, Legal and Other Evidence 4
M ISO13485 Documentation packs (manual, procedures, forms etc) ISO 13485:2016 - Medical Device Quality Management Systems 3
S Medical Device Servicing - Forms and Signature ISO 13485:2016 - Medical Device Quality Management Systems 1
S Control of Forms Document Control Systems, Procedures, Forms and Templates 4
M AS9100D Process Map Requirements - PEAR Forms AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 18
O AS9102 FAI report Forms 1-3 Document Control Systems, Procedures, Forms and Templates 6
Q Controlling Multi-Tab Microsoft Excel Forms Excel .xls Spreadsheet Templates and Tools 5
R Standards Data Forms (form 3654) - American Academy of Sleep Medicine (AASM) US Food and Drug Administration (FDA) 0
H Manufacturer vs. Supplier - Which is which on PPAP Forms APQP and PPAP 3
P ISO 9001:2008 Design and Development Process & Forms examples wanted Design and Development of Products and Processes 3
P FDA has just released the forms for "Small Business Qualification and Certification" Other US Medical Device Regulations 6
W Form Approval - Blank forms Document Control Systems, Procedures, Forms and Templates 9
W Unattached (stand-alone) Forms acceptable for AS9100C? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
J Training SOP and Forms Training - Internal, External, Online and Distance Learning 3
M Some ISO 9001:2015 Forms and Templates Document Control Systems, Procedures, Forms and Templates 5
P Customer Forms as external documents Document Control Systems, Procedures, Forms and Templates 4
H Incomplete forms and records missing date or a name Records and Data - Quality, Legal and Other Evidence 6
T Controlled Forms - Centralized or Decentralized? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
S Document Numbers (Identification) on Forms (AS9100) Document Control Systems, Procedures, Forms and Templates 15
S Clinical Trial Informed Consent Forms ("retro-signing") US Food and Drug Administration (FDA) 2
A How to Verify Supplier I-9 Forms for ITAR Requirements Other ISO and International Standards and European Regulations 2
Gman2 Control of Documents and (FORMS) on a Computer Network ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
MichaelDRoach Where in ISO 9001 is White Out on Forms and Records Prohibited? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
K List of procedures and forms or records required by ISO 15189:2012 Document Control Systems, Procedures, Forms and Templates 2
M Photocopy of Data Entry in Traveler Forms Document Control Systems, Procedures, Forms and Templates 2
cscalise Separate Forms or Procedure Attachments - What's more common? Document Control Systems, Procedures, Forms and Templates 2
C Controlled Forms Conundrum Document Control Systems, Procedures, Forms and Templates 2
K Document Control - Type-able Forms vs. Ink Quality Manager and Management Related Issues 10
R Document Control when an ERP System Produces most Forms and other Paperwork Document Control Systems, Procedures, Forms and Templates 7
G Internal Audit Report Forms ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 30
D Adding PPAP forms to the ISO procedures Document Control Systems, Procedures, Forms and Templates 2
T ISO 9001:2008 Forms Control for Electronic Built-In Template Document Control Systems, Procedures, Forms and Templates 2
Claes Gefvenberg Designing Supplier Questionnaire Forms Supplier Quality Assurance and other Supplier Issues 25
