When do you start the Advanced Product Quality Planning (APQP) Process?
  • Thread starter alanwilliams08152004
  • Start date
We are having an internal debate in our company on when the APQP process starts. Does APQP start as soon as Sales receives the RFQ from the supplier, or does APQP start when Sales receives the official P.O. from the customer? The AIAG manual (as far as I can tell) assumes that the supplier has the order and needs to proceed to develop the product. In reality, a supplier must first develop a design/price proposal (using the same cross functional team input defined in APQP) to be proposed to the customer along side other supplier proposals . . . where in the end the may not result in an order from the customer. The question is . . . how much APQP type effort is devoted to developing the proposal before the order is received? I lean toward pulling the official APQP start to the RFQ phase . . . but again this is different from how AIAG defines the process.
I am curious to find out how other companies deal with this situation.
Stijloor
Re: When do you start APQP?
APQP = Planning for Product Realization. (Clause 7.1)
It starts when the customer contacts you or you contact the customer.
As simple as that.
Stijloor.
I
ignatiuswong
http://www.npd-solutions.com/apqp.html
maybe this could help you to understand the APQP
Thank you for the link. Do you have any suggestions on how to incorporate APQP into the proposal development process? Again, the question is . . . how much APQP effort should be spent by a company in developing a proposal which may in the end be rejected by the potential customer? The APQP in your link (which seems to be the same as the diagram in the AIAG manual) does not have a 'develop/submit proposal' step in any of the phases. Thank you.
I
ignatiuswong
Like Stijloor said, APQP is Planning for Development product, if you want to develop for part that Customer gave to your company, you must through passed all step in this APQP, no regret about it. about how much effort do you need to spent for this Developing depend on how much your effort to got this project, however if you want to develop a project you must do all step in this APQP,
if you rejected by a potential customers if possible to occurred, because Customers usual not to give the project only by one supplier, it could more than one supplier, but if you could give the best proposal to customers, you would be choosed by them of course,
in the link that i gave to you not mention develop/submit proposal, because as you know every step in here must be coordinate with customers from the first, you could not decide to do all step on this APQP without communicate with customers ? we just doing the VOA ( voice of customers ) such as when we received the DRD / RDDP until Prototypes,
hope this could help
D.Scott
Just to add my opinion -
APQP isn't a sit down at the table and get it done process. It can sometimes be a long involved process taking up to years to complete. On the other end it could be as simple as considering it as part of a family of existing parts.
My point is, APQP must be flexible enough to accommodate any circumstance. The process has to be robust enough to allow you to eliminate or add activities as needed to fully understand and plan for the requirements of the customer and the capability of your company.
When developing an APQP process, I would make it as flexible as possible. I wouldn't want a process that locked me into a massive cross-functional process with a mandatory checklist unless it were necessary to the development of the part.
Your internal discussion over when does it start addresses what I have said above. Depending on the planning needed for the project, APQP could and should start at any point. You could even argue that APQP has to start before you open your doors. Hasn't planning on what you can make and how you will make it already begun?
You know what you have to do as far as planning. The AIAG manual lists suggested steps. Set up your process to address the planning needed for you and your customer but don't be so specific you back yourself into a corner. Make your APQP part of a company culture that works for you not a burden.
Dave
Raffy
Hi alan,
First, you need to make sure the proposal you're going to submit will have an affirmative result. THINK POSITIVE.
Dave is right, APQP should be flexible.
Thanks Dave.
Raffy
Randy Stewart
Throw in my :2cents:.
APQP can be applied in many ways and started at different times, like Dave mentioned the flexibility.
If a customer mentions that it has a new part or wants to move an existing part to your company, APQP can start at thinking about which line you can run the part on. Advanced Planning.
It could be a plan to buy new equipment, new tooling, even looking for a new supplier for tooling, fixtures etc.
Their is no real "cookie cutter" for APQP, however, if a company has been in business for anytime, they do it and may not know it.
From determining how to flow your required quantities to deliver to planning a new facility for a program can be classified under APQP.
Hope that helped.
Ettore
U Examples of Quality Objectives for a Medtech start up ISO 13485:2016 - Medical Device Quality Management Systems 4
J ISO 13485 System 'soft start' - How to best reflect this in initial audits, management review minutes and other records? ISO 13485:2016 - Medical Device Quality Management Systems 3
A AS9100 Training - Where do I start? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 14
mike10 QMS Update - Rev. up or start over? Document Control Systems, Procedures, Forms and Templates 3
N China - Start manufacturing before change approval? China Medical Device Regulations 3
S How to start with ISO process in project based team - Documentation Document Control Systems, Procedures, Forms and Templates 4
A Implementing ISO 20000-1 - Where to start Other ISO and International Standards and European Regulations 2
T CE mark start date for a device EU Medical Device Regulations 7
qualprod Statistics - Where to start in ISO 9001? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
W My company is looking to start a materials testing lab that conforms to ISO17025:2017 ISO 17025 related Discussions 3
G Start and main steps of API Q1 Certification Process Various Other Specifications, Standards, and related Requirements 5
M Error trying to Start a New Thread Elsmar Cove Forum Suggestions, Complaints, Problems and Bug Reports 2
H Transferring an ISO 13485 certificate to a new CB - Do I have to start from scratch? ISO 13485:2016 - Medical Device Quality Management Systems 2
M Start-Up Company looking for ISO 13485 Certification Body and Medical Device CE Mark Notified Body Registrars and Notified Bodies 6
Marc Basic - How to Start a New Discussion Thread Elsmar Xenforo Forum Software Instructions and Help 1
TheMightyWife Can not start Personal Conversations Elsmar Cove Forum Suggestions, Complaints, Problems and Bug Reports 18
E Is it possible to start an ISO 9001 QMS from scratch (Really) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
M AS9100 - Where to start - Small company (10 employees) and I am the Quality Dept. AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 45
M How do you start a calibration/anything company? Career and Occupation Discussions 11
E ISO 9001 certification of the new plant before start of production ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 18
B Gap analysis of new start-up company technical documentation CE Marking (Conformité Européene) / CB Scheme 1
qualprod How to start with Lean? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
R QMS and ISO - Where to start? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 18
S ISO 17025 - Help in Getting accreditation- Where to start from ISO 17025 related Discussions 12
H Need to Start an R&D Laboratory, what to do? Design and Development of Products and Processes 6
O Start Up Approval Dimension Records IATF 16949 - Automotive Quality Systems Standard 5
V Product Development - When to start calculating Process Capability Capability, Accuracy and Stability - Processes, Machines, etc. 3
Moncia Design FMEA - Where to Start FMEA and Control Plans 20
M Where does Document Revision Control Start? Rev 0 or Rev 1 Document Control Systems, Procedures, Forms and Templates 19
M How to Start SPC from the ground up! Statistical Analysis Tools, Techniques and SPC 8
A Start Up of a small AS9100 Machine Shop AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
P CA,PA, Continual Improvement - How to start in a Service Company Quality Tools, Improvement and Analysis 1
P Where to start to helping other companies to get ISO IEC 27000? Consultants and Consulting 1
A How best to start revising an existing ISO 9001:2008 system in a company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
M APQP and PPAP for Beginners - Where do I start? APQP and PPAP 48
S How to Start SPC in a Shaft Grinding Section Statistical Analysis Tools, Techniques and SPC 1
M Start New Machine Shop OR BUY Business Continuity & Resiliency Planning (BCRP) 9
K Disaster Recovery and Business Continuity Planning - Where to start? Business Continuity & Resiliency Planning (BCRP) 20
Hershal ILAC is preparing to start the possible revision to ISO/IEC 17025 ISO 17025 related Discussions 2
S How do I start "Risk Management" ISO 14971 - Medical Device Risk Management 3
L Where to Start to Completely overhaul a QMS ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
D Which ASQ Certification should I start with? Career and Occupation Discussions 9
A Start Compliance to RoHS, SCHV and REACH RoHS, REACH, ELV, IMDS and Restricted Substances 10
M Where to start Maintenance Function Kaizen Lean in Manufacturing and Service Industries 4
J ISO 13485 and ISO9001 Quality Management Implementation Start ISO 13485:2016 - Medical Device Quality Management Systems 6
A ISO 9001 to ISO 17025 where to start ISO 17025 related Discussions 3
J Major Nonconformance on Stage 2 Audit causes to start over Stage 1? IATF 16949 - Automotive Quality Systems Standard 2
M General Guidelines on how to start a Quality Campaign Misc. Quality Assurance and Business Systems Related Topics 2
P Alternative Procedures to DOA: How to start? EASA and JAA Aviation Standards and Requirements 3
