When is a Change Management Process required?
TracyShirley
Hello all,
I am currently trying to implement a Change Management Process in my organization. My issue is being able to give a definitive answer as to when the change management process is required to be followed. I know the basics such as equipment, infrastructure, processes, etc. But my question is when is the line drawn? For example, if a method of doing something changes, although it is minimal such as the order in which a task is completed, does this need to go through the process.
Any guidance would be great. I need to present this information to upper management who is very reluctant in following this process so I need to get through to them exactly when they need to go through the change procedure, or else they will not, because I did not tell them they needed to.
Thanks!
Tracy
RoxaneB
My thought would be to incorporate a few criteria that can be weighted to determine if/when your Change Management protocols need to be implemented.
For example:
  • Frequency of activity conducted
  • Severity if activity is not conducted as per change
  • Associated legal requirements
  • Direct impact to Safety, Environment, Quality
Basically, it would be like a FMEA and there would be a score at the end of the process. If the change was above XX, change management would be implemented. If the change was below XX, alternate options such as formal training, on-the-job training, memos, grandfather, etc. can be used.
Hello all,
Thanks!
Tracy
You need design the system such that it's flexible enough to account for different degrees of change. Sometimes this is accomplished by establishing categories and making the requirements for each category such that a change in the order of operations isn't subjected to the same process as a major product change. In all cases, the path should be as short and direct as possible while still accounting for the known risks. Your management is probably afraid of being painted into a corner by a process that might be too complex for the task at hand, and rightly so.
As far as where lines are drawn between categories, it will inevitably become somewhat arbitrary at some point, so it's also important to allow people to make decisions when an ambiguous situation arises.
K
keres
You may not always follow the Change Management Process for every change. There are many routine changes without impact and for them you can create simpler procedure. But you must have clear criteria what is routine change and what is not.
Wes Bucey
Personally, I've always found success using some basic techniques of Change Management
  1. Address the human side
  2. start at the top
  3. involve every layer of the organization (and up and down the supply chain)
  4. make the formal case (Three steps should be followed in developing the case: First, confront reality and articulate a convincing need for change. Second, demonstrate faith that the company has a viable future and the leadership to get there. Finally, provide a road map to guide behavior and decision making. Leaders must then customize this message for various internal audiences, describing the pending change in terms that matter to the individuals. )
  5. create ownership (by involving people in identifying problems and crafting solutions. It is reinforced by incentives and rewards. These can be tangible (for example, financial compensation) or psychological (for example, camaraderie and a sense of shared destiny.))
  6. communicate the message (written, verbal, visual [actions speak louder than words])
  7. assess the cultural landscape
  8. address culture specifically
  9. prepare for the unexpected
  10. speak to the individual (not the mob)
Consultants such as I have been counseling companies on successful Change Management for a long time. I do not want to imply it is easy to accomplish a successful change in an organization, but it is doable. It is NOT an overnight miracle, but takes weeks and months of careful nurturing to bring to fruition. Normally, change must come from the top, but I have seen some middle level folk use power of persuasion to convince top managers to kick start and follow through on Change - it "ain't easy" that way and more than one mid-level person has been the slain messenger when he couldn't persuade the top bosses to move forward. As a consultant, I won't even begin to make a proposal until I have assessed the commitment of the top dogs in an organization.
  2. start at the top
I think the OP is referring to change management as synonymous with configuration management, not organizational change management.
Wes Bucey
terminology in our profession can be so challenging -
I certainly have lots of posts here in the Cove on Configuration Management. Use the search button.
Richard Regalado
Hi. My answer is based on my knowledge and experience in ISO/IEC 27001 information security management system standard.
Change management is required if changes to information systems and supporting facilities needs to be controlled. Inadequate control of changes could lead to systems failure or breach in security.
Under ISO/IEC 27002 (guidance) the following needs to be considered:
1. identification and recording of changes
2. planning and testing
3. assessing potential impacts of planned changes
4. approval and communication
5. fallback procedures
I hope the above helps.
Wes Bucey
Hello all,
Thanks!
Tracy
Jim knows. ;) But this should be communicated to the OP. :agree1:
Stijloor.
OK!
Here's a link to a Configuration Management post.
http://elsmar.com/Forums/showpost.php?p=435615&postcount=2
In the quality profession, there are lots of "terms of art" which have extended meanings beyond a bare bones definition of the individual words in the term. "Change Management" and Configuration Management" are such terms of art. Practitioners confuse them at the peril of seeming "uninformed." The way to avoid that is to be completely descriptive of the process, activity, or function instead of using a term with which you are completely familiar.
In the past, I have written
Any person managing documents must continually be alert to weeding out obsolete documents. It is just a matter of good management for that person to update Associated Documents as necessary.
Aerospace folks just put a lot of emphasis on CM [configuration management], therefore it is "expressed," whereas in many other industries it is a normal part of document management, therefore "implied."
Only a complete beginner might ignore the need to confirm all documents are correct and up-to-date BEFORE expending time and money on a production process. Folks have been and continue performing "Configuration Management" as a process without ever knowing or using the term "configuration management."
Similarly, most organizations have a Quality Management System (regardless of its efficacy or efficiency) without ever using the term "Quality Management System."
Don't get hung up on the terminology - concentrate on the PROCESS!
N Change Management, Configuration Management or Other Process? Manufacturing and Related Processes 9
T TS 16949 compliant Change Control Management Process IATF 16949 - Automotive Quality Systems Standard 3
T Process Change in a Laboratory - Start Date for new Procedure - Management Opinions Misc. Quality Assurance and Business Systems Related Topics 4
Q Change Management Process Mapping Process Maps, Process Mapping and Turtle Diagrams 7
G Management of Change Process (OHSAS) - What would an Auditor expect to see? Occupational Health & Safety Management Standards 6
K Change Management written process... is this mandatory? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
J Change Management System - Does ISO 9001 specify you need a process flow? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
A Change management - process, tooling, subcontractors etc. QS-9000 - American Automotive Manufacturers Standard 1
A Purchasing Controls on Change Management of Literature/Labeling ISO 13485:2016 - Medical Device Quality Management Systems 3
D Reports under change management | ISO 13485:2016 & ISO 9001:2015 ISO 13485:2016 - Medical Device Quality Management Systems 3
M EMS change management ISO 14001:2015 Specific Discussions 2
M Change management procedure when 7.3 is not applicable ISO 13485:2016 - Medical Device Quality Management Systems 5
R Change Management vs Opportunity for Improvement ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
U Change Management vs Change Control? Design and Development of Products and Processes 4
D Customer and Company Specific Requirements for notification of Customers of a change in Management or Key Personnel Customer and Company Specific Requirements 3
M How to implement the 4M Change Management System Lean in Manufacturing and Service Industries 3
J Change management with CFDA approved devices China Medical Device Regulations 1
R Linking the Processes of Continual Improvement, Change Management, Risk Management, Action Planning, etc? Preventive Action and Continuous Improvement 5
R 8.1.3 Management of change - Evidence of HIRA and related things Occupational Health & Safety Management Standards 3
T Change control and configuration management - When to create a new model/part number? Other Medical Device and Orthopedic Related Topics 0
R ISO 20000 requirement about the Change Management Policy IT (Information Technology) Service Management 3
J South Korea, MFDS - Medical Device Change Management Other Medical Device Regulations World-Wide 5
Q Top Management Change Prior to Certification ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
Y Change Management in a very complex Research Organization Misc. Quality Assurance and Business Systems Related Topics 3
M ISO 13485:2016 Cl. 5.1 - Management commitment verbiage change ISO 13485:2016 - Medical Device Quality Management Systems 2
P Change Management & New Hires ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
P Are we an outlier for so many variations of Change Management? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
Q Who can Change goals and kpi of top management? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
S Software Application for Management of Change (API 5.11) Other ISO and International Standards and European Regulations 3
G Management of Change Procedure Quality Manager and Management Related Issues 7
somashekar 5.4.2 b) Integrity of QMS in Change Management ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
T Engineering Change Management Systems Document Control Systems, Procedures, Forms and Templates 3
M Engineering Change Management Generic Procedure Manufacturing and Related Processes 3
K How do I change management culture in regards to product? Supplier Quality Assurance and other Supplier Issues 4
N New to Management: Culture Change Advice Quality Manager and Management Related Issues 20
C Change Management Toolkit Template Document Control Systems, Procedures, Forms and Templates 5
E Does anyone have a Change Management database? Document Control Systems, Procedures, Forms and Templates 7
L The Perfect Engineering Change and Concessions Management System Document Control Systems, Procedures, Forms and Templates 8
J Backsliding QMS - My office has gone through major management change ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
D Management of Change - MOC Procedure and Forms - Engineering, Project, Safety Systems Manufacturing and Related Processes 1
M GM Quality System Basic - Banking & Bypass Procedure in Change Management Manufacturing and Related Processes 6
R Change in Direction - Management decides to Outsource Manufacturing Operations ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
S Management Notice of Change - Sample Wanted AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
A Change Control Review Management Success or Effectiveness Metric Quality Manager and Management Related Issues 3
M ITIL vs. ISO 20000 Change Management Requirements IT (Information Technology) Service Management 3
D ECO (Engineering Change Order) Risk Management Criteria and QA Document Control Systems, Procedures, Forms and Templates 19
C Management Of Change System or Software - Recommendations and Ideas wanted After Work and Weekend Discussion Topics 2
D Specifications - All the same type of document? Change Management part of our QMS Document Control Systems, Procedures, Forms and Templates 4
S Change Management - From basic level to implement it succesfully ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
A Management of Change? What does that mean? Misc. Quality Assurance and Business Systems Related Topics 8
