When is a Manufacturing Date required on Medical Device Labeling?
Mark Meer
Hi everyone,
Years back, we had decided to include the date-of-manufacture on our Class II (non IVD) device labels.
Now, I can't for the life of me recall the rationale for this decision.
Is there a particular regional regulatory requirement someone could point me to that requires the manufacturing date be present on medical device labelling?
Thanks!
Ronen E
Problem Solver
Moderator
Re: When is manufacturing date required on Medical Device labeling?
Do you also show the expiry date?
Mark Meer
No, there is no expiry date.
...and these two dates (expiry date versus manufacturing date) appear to be independent as far as labeling frameworks go. For example EN980 and GS1 have distinct symbols/identifiers for specifying the two dates independently...
Mark Meer
Found one reference:
MDD 93/42/EEC, Annex I, 13.3:
"The label must bear the following particulars:...
(l) year of manufacture for active devices other than those covered by
(e). This indication may be included in the batch or serial number;"
...however this just calls for the year, and only for active devices.
Anyone know of any other medical device regulations or standards that require date of manufacture to be on the labelling?
Ronen E
Problem Solver
Moderator
If there's no expiry date but the device has a definite shelf life, the manufacturing date would be required so that the user can avoid using the device beyond its shelf life.
It's a bit difficult to relate to your specific device if we don't know what it is.
Mark Meer
We've applied this across our products, so there is a bunch (they're all Class II though), and none have an expiry, or stated shelf life.
I'm more curious about where the (perceived) need for this date came from. Like I mentioned EN 980 and GS1 have both constructed explicit symbologies/identifiers for putting manufacturing date on device labels.... but, aside from the MDD reference (which only requires the year, and has an option to just include it in the batch number), I can't track down any explicit requirement (in regulations or standards) that requires this date to be present (and hence any need to use EN 980 symbol, or GS1 application identifier)...
Bottom line is that, for a number of reasons, I'd like to get rid of it on our labels. I'm just trying to confirm that we are not removing labeling information required by a medical device regulation or standard.
Ronen E
Problem Solver
Moderator
So technically they can be used for a hundred years?... Even if you don't state it on the labelling, there must be a defined device lifetime to inform your verification etc. The default would be "indefinite lifetime", which you probably don't want to support (even if you can).
The MDD's Essential Requirement 4 reads:
The characteristics and performances referred to in Sections 1, 2 and 3 must not be adversely affected to such a degree that the clinical condi-tions and safety of the patients and, where applicable, of other persons are compromised during the lifetime of the device as indicated by the manufacturer, when the device is subjected to the stresses which can occur during normal conditions of use.
(Emphasis added), so you "kind of" have to address the issue one way or another.
Other than that it's still hard to say... "Class II" is still quite general. There might be Special Controls in place.
Ajit Basrur
Would the manufacturing date or an expiration date be not required per UDI requirements ?
somashekar
EN980 provides for the symbol. However the use of the symbol and the information alongside is an output from your risk assessment concerning device labeling information. Just a case., if the device has an adhesive backed part, the Mfg date (MM/YYYY) leads to the declared use before period, which can be., say 18 months from the Mfg date. This comes from the shelf life of the adhesive backed part. In fact the storage and transport temperature information also directly has an effect on the use before period.
So what is your Mfg date information's clarity and sincerity of the purpose .....
U Change to the manufacturing Date for a device in the field US Medical Device Regulations 0
C Definition of "Manufacturing date" Other Medical Device Regulations World-Wide 4
P Manufacturing site vs manufacturing date symbol Medical Device and FDA Regulations and Standards News 1
O Any info on release date of FDA “Computer Software Assurance for Manufacturing and Quality System Software” document? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
M GSPR 23.3 (h) Manufacturing date on sterile barrier EU Medical Device Regulations 0
M Manufacturing date does not match release date? Other US Medical Device Regulations 2
J Symbol for manufacturing date - Is ISO 980 expired? CE Marking (Conformité Européene) / CB Scheme 11
F Manufacturing date on serial number plate? ISO 13485:2016 - Medical Device Quality Management Systems 16
M If there is any prohibits from contract manufacturing/entrusted production in EU? EU Medical Device Regulations 2
M Looking for kindly help... If there is any prohibits from contract manufacturing in US? About SR medical devices US Medical Device Regulations 0
T Manufacturing flowchart SaMD IEC 62304 - Medical Device Software Life Cycle Processes 3
P Do Barcode scanners need validation in Medical device manufacturing? Manufacturing and Related Processes 6
H MTBF industry average for manufacturing automated equipment Manufacturing and Related Processes 0
A PMS and reportable incidents for company that outsources manufacturing? ISO 13485:2016 - Medical Device Quality Management Systems 2
A Guidance on Supplier Qualification - Phase 1 pharma manufacturing Supplier Quality Assurance and other Supplier Issues 4
P Manufacturing facility moved to different location ISO 13485:2016 - Medical Device Quality Management Systems 10
R Manufacturing and Import Licenses in Egypt Other Medical Device Regulations World-Wide 1
M Manufacturing Terminology Manufacturing and Related Processes 1
T First Pass Yield (FPY) of a Manufacturing Site? Manufacturing and Related Processes 11
K CE expiry and manufacturing devices CE Marking (Conformité Européene) / CB Scheme 3
N Paint Manufacturing Manufacturing and Related Processes 2
optomist1 Hybrid or Pure Electric Aircraft Manufacturing Standards Federal Aviation Administration (FAA) Standards and Requirements 0
B Hi , everyone i need a procedure for validation of design prototype api 6d (valve manufacturing) Oil and Gas Industry Standards and Regulations 1
J Medical Device Manufacturing Manufacturing and Related Processes 3
J Dry room for gummy manufacturing and floor storage US Food and Drug Administration (FDA) 4
E Please help! ! I AM FRASTRATED SO MUCH! Should inactive ingredient be included in the unit formula if it is removed during the manufacturing process? US Food and Drug Administration (FDA) 0
M Role of Quality Manager in a manufacturing company AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 12
N Writing Risk Management procedure for small manufacturing and we don't know where to start. Manufacturing and Related Processes 9
dgrainger Informational Guidance on In-House manufacturing UK Medical Device Regulations 0
K Pharmaceuticals and Manufacturing Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 0
C Training for Manufacturing Nonconformances and CAPS with focus on the wording Nonconformance and Corrective Action 4
A How would a candidate for Quality Systems Manager role answer questions in a med device manufacturing org ISO 13485:2016 - Medical Device Quality Management Systems 11
D Shopfloor drawings & manufacturing requirements Document Control Systems, Procedures, Forms and Templates 2
Sortinghat Auditing the Manufacturing Process IATF 16949 - Automotive Quality Systems Standard 3
J Outsourced Purchasing for Contract Manufacturing vs more typical/simple Supplier Management ISO 13485:2016 - Medical Device Quality Management Systems 5
Zafortner EU Manufacturing Incident Report (MIR) version 7.3 ISO 13485:2016 - Medical Device Quality Management Systems 9
D Out of specification procedure for Medical device manufacturing Manufacturing and Related Processes 7
malasuerte Performance of ISO 9001 certified vs. non-certified manufacturing companies ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
cgaro62 Does FDA apply to a non-medical 13485 certified custom manufacturing company? ISO 13485:2016 - Medical Device Quality Management Systems 11
A Layered Process Audits for Medical Device Manufacturing? ISO 13485:2016 - Medical Device Quality Management Systems 7
R FMEA's for non-manufacturing sites FMEA and Control Plans 4
M How to show the effect of the failure mode on the manufacturing process as a customer of product design process? FMEA and Control Plans 3
C MDR - Annex II _3. DESIGN AND MANUFACTURING INFORMATION_a EU Medical Device Regulations 3
Vader22 IATF 16949 extended manufacturing site help IATF 16949 - Automotive Quality Systems Standard 4
V Military ranks versus Manufacturing titles Misc. Quality Assurance and Business Systems Related Topics 8
K MHLW MO169 2021 Japan Ministerial Ordinance on Standards for Manufacturing Control and Quality Control for Medical Devices and In-Vitro Diagnostics Japan Medical Device Regulations 4
Booker PSW - Organization Manufacturing Information APQP and PPAP 0
Awais Taking Pictures of Outbound Material - In the Manufacturing Shop floor Manufacturing and Related Processes 5
blackholequasar ISO 13485 certification prior to Medical Device Manufacturing... worth it? ISO 13485:2016 - Medical Device Quality Management Systems 4
Jim Wynne Most Important Manufacturing KPI, per Oracle Coffee Break and Water Cooler Discussions 3
