When is a Work Instruction not necessary or required?
Pancho
wikineer
#11
Re: When isn't a Work Instruction necessary?
May I suggest that explicit can also mean electronically recorded sounds and images? For example, a simple video recording of a process or process steps can convey much more information and much clearer than a written document can.
A picture is worth a thousand words. :D
Indeed! Pics and video are great documentation aids. They also turn many a reluctant master into an eager performer/teacher.
ScottK
Not out of the crisis
#12
Our preference is to turn as much of the tacit knowledge in our organization as possible into explicit knowledge. In other words, we try to document all work that matters into written instructions.
That is certianly a noble goal.
In my case it's not practical because the variety is too high.
But there are ways around that!
I've approached it by having a detailed visual work instruction for a "family" of parts. A family being defined as parts that all have similar components in a similar configuration. Thus the method of assembly and test is always the same, just with different components parts by BOM.
The the BOMs are controlled - so we have part revision control.
The problem is when we have auditors who feel that each part number needs it own work instruction. Most can be reasoned with. But some.... :frust:
Stijloor
#13
If you can demonstrate that the assembly process is effective (process meets performance objectives), because the assemblers are competent, you have made your case. Period.
{Note: The automotive industry (ISO/TS 16949:2002(9), requires WI's.}
Folks argue too much with auditors because auditees have no recourse, no good evidence. Show results!
Stijloor.
mogluk
#14
*emerges from lurk mode*
with ISO showing of results batch test results, insection reports are great ways to show control of your process. I agree that WI's should be used as a means to ensure meeting of specs...if a particular step keeps getting missed or a valuable inspection. Also if you have high turnover WI's are a means to ensure that a certain standard is maintained. but if you have a high turnover I would say thats the least of your worries...
I work in medical electronics so we have 100% test results for all units exiting. To avoid explicit assembly instructions we use a schematic and Bill's of Materials.
P
Polly Pure Bread
#15
When I brought up the idea of having WIs for the machines here, I got some eyebrow raises. They explained that 1) their customers are not asking for it, and 2) it's impossible because the machinists are hired on 10+ years of experience, and training is performed as an apprenticeship. According to the foreman, "I can tell whether they know the machines or not after watching them for 90 days." (Small family company, so I don't know if it makes a difference.)
Do you have any recommendations for handling this, and is a WI necessary for everything?
Hi LexieB,
Do they agree with the documented procedures? Work instruction is, similar to a procedure, a detailed description of how to complete a specific task in an activity, but involving a single performer.
If the activity will be completed by performing tasks in sequence, then work instruction is necessary.
P
Polly Pure Bread
#16
Even if your machinists/operators are one of the very best in that area, try to imagine what would happen if your good mechanists, God for bid, suddenly passed away. Will your business continue to operate without using a work instruction as reference and for how long? If no/less experienced-workers can comfortably do those then congratulations –you don’t need Work Instruction. What about in times of human resource/economic crises e.g. labor strikes, rise in absenteeism, work place accidents, etc.?
AMITRAAJSHARMA
#17
OK - m reading a book called "How Toyota became the #1 Car Company in the world" by David Magee. I know it blemishes two pholisophies ISO and Lean but the objective is still the same - QUALITY.
Very well demonstrated in the book - STANDARDIZATION of the processes - typically attained by WIs - as mentioned in the ISO 9000 series.
Very young in my career I was made the MR of a cable company - the operators of the machines had like twice the experience than my age. Going upto them and convincing them about WIs on machines was like a child talking to his grandparents about the WISDOM life gives. But then (refer ISO 900X:1994) what has to be done has to be done. Thus followed a lotza :argue:, finally with Management support and positive competition (basically an R&R for the best and most innovative method to display WI et al) we managed to get that done.
And YES we did get the certification and a re-certification 3 yrs later...........:D
Cheers - Amit
SteelMaiden
#18
I think that work instructions might not fit that definition for everyone, but that is just my :2cents:. As stated, there is no "requirement" to have work instructions, but most of us find them useful, in whatever purpose we difine them. But, if they are not adding value to your process, you might as well not have them.
#19
Stijloor.
And the funny thing is that at Honda (and I suspect others) there are NO work instructions on how to assemble the car!! NONE. Nor do the associates ahve time to read them or look at them. Standardized work, visual work place and repetitive training keep everyone on task.
#20
Cheers - Amit
actually Work instructions are antithetical to standardized work, rapid improvement and the Toyota Production System.
I think too many auditors look for work instructions because it's easy. It's difficult for them to ensure that a worker is performing an operation correctly without it written down in front of them...we too often do things in our organization to make it easier for the auditors even if its' not value add for us...that isn't the point of ISO.
J One Work Instruction or Multiple Work Instructions (WI's) necessary Quality Management System (QMS) Manuals 13
T Is it necessary for every written procedure and work instruction to be controlled? Document Control Systems, Procedures, Forms and Templates 2
D Work Instruction Question ISO 13485:2016 - Medical Device Quality Management Systems 5
DuncanGibbons Resources for aiding in procedure, work instruction and manufacturing plan development and management AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
A Read instruction manual - What Graphic Symbol must I use? US Food and Drug Administration (FDA) 7
J Manufacturing procedure / work instruction depth ISO 13485:2016 - Medical Device Quality Management Systems 12
Mr Roo Work Instruction Authorization ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
F Label work instruction - Medical Devices Manufacturing and Related Processes 1
I 2017/745 (MDR) - Instruction for use (IFU) - manufacturer's website EU Medical Device Regulations 15
S Root cause analysis - The system of developing a work instruction is not effective Problem Solving, Root Cause Fault and Failure Analysis 1
J Standard Work Instruction Languages (IATF 16949 8.5.1.2) IATF 16949 - Automotive Quality Systems Standard 8
E Safety work instruction if the equipment have the CE Marking and a Manual with safety instruction Various Other Specifications, Standards, and related Requirements 16
M EU Regulations or Standards for instruction for use (IFU ) EU Medical Device Regulations 3
S Manufacturing Work Instruction examples that include process pictures Manufacturing and Related Processes 3
L I need an example rework procedure/instruction for injected plastic parts Document Control Systems, Procedures, Forms and Templates 2
Q Product Instruction for Use Manual (IFU) - Obligation to list the standard used 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
C Example Work Instruction/Procedure for AQL (Acceptable Quality Level) AQL - Acceptable Quality Level 4
W CPU BIST IEC 62304 - Embedded code has CPU instruction tests IEC 62304 - Medical Device Software Life Cycle Processes 2
M Standard work, standardized work instruction & work instruction: What are differences IATF 16949 - Automotive Quality Systems Standard 7
M Work Instruction Content or Sequence Changes and Operation Numbering Document Control Systems, Procedures, Forms and Templates 3
0 Safety Instruction Card and Safety Work Instruction Document Control Systems, Procedures, Forms and Templates 3
L TS16949 Work Instruction Requirements IATF 16949 - Automotive Quality Systems Standard 7
G SOP or Work Instruction for PFMEA? FMEA and Control Plans 5
Z Internal Memo used to document work instruction Document Control Systems, Procedures, Forms and Templates 2
T Handling of Obsolete Material Work Instruction ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
M Mention "according to Work Instruction" in Control Plan FMEA and Control Plans 3
alonFAI SMI (Solder Paste Inspection ) Inline Work Instruction (Procedure) Manufacturing and Related Processes 3
G Work Instruction Performance Measures Misc. Quality Assurance and Business Systems Related Topics 3
M ISO 9001 Work Instruction Structure Document Control Systems, Procedures, Forms and Templates 1
W Control of Document - Working Instruction and Checklist ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
D Steps to Complete Quality Control Plans and Work Instruction Manufacturing and Related Processes 4
A Should I call this ?Blank Template? a Work Instruction? Document Control Systems, Procedures, Forms and Templates 11
Q Referencing a Specification in a Work Instruction as a ?Guidance Document? ISO 13485:2016 - Medical Device Quality Management Systems 1
C SOP Work Instruction (Job Card) Template Revisions question Document Control Systems, Procedures, Forms and Templates 6
K Intended Use wording: What is suitable for the instruction manual? EU Medical Device Regulations 4
A Definition Technical Work Instruction vs. Method Statement - Differences Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 6
M Orthopedic IFU ( Instruction For Use ) EU Medical Device Regulations 3
J Control of equipment instruction manuals ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
H Writing a Product Label Inspection Work Instruction Manufacturing and Related Processes 2
I Document Control - Instruction Manuals and Service Manuals General Measurement Device and Calibration Topics 2
C SS-EN ISO13485 Work Instruction Requirements for Dentures ISO 13485:2016 - Medical Device Quality Management Systems 2
I Work Instruction for Validation of Packaging to EN ISO 11607-2 Requirements Document Control Systems, Procedures, Forms and Templates 3
M Looking for a Powder Coating Process Instruction Manufacturing and Related Processes 3
J Setting up Performance Review Instruction Phrases in my Company Human Factors and Ergonomics in Engineering 11
W FDA Labeling Requirements - Instruction for Use Content 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
L ISO 17021:2011 - The Application of Annex A - Work Instruction Details General Auditing Discussions 9
T AS9100C Work Instruction Clarification - How detailed should a Work Instruction be? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
B Work Instruction Application (Software for Document Control) Quality Assurance and Compliance Software Tools and Solutions 2
6 Instruction Manual for the production of Deionized Water Manufacturing and Related Processes 2
M Procedure & Work Instruction Flow Charting vs. Turtle Diagrams AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
