When is Bioburden Testing Required?
If we are manufacturing a medical device in a non-certified clean room that is sent out to be packaged in a cleanroom & sterilized does routine bioburden testing monitoring need to be done during manufacturing or can it be done during packaging or by the sterilizer? Do some sterilization validations contain bioburden testing and monitoring?
Ed Panek
QA RA Small Med Dev Company
Not certain but there is a question before that answer. What method are you using to sterilize? Ethylene Oxide? Radiation? I think the method determines the standard to use.
indubioush
ISO 11737-1, Sterilization of health care products — Microbiological methods — Part 1: Determination of a population of microorganisms on products
If I have validated the EO process to overkill (for sterilization of medical devices) and each cycle is run with a BI, do I need to perform routing bioburden monitoring?
Cthames
Yes you would. The idea is you measure bioburden to establish a baseline. Then, you perform a sterilization validation to ensure your sterilization process is capable of sterilizing product's at that baseline. You must do routine monitoring of bioburden in order to ensure your baseline is not shifting, as your sterilization validation is performed with that baseline in mind.
D Sterility and BioBurden Testing for Plastics ISO 13485:2016 - Medical Device Quality Management Systems 5
C Sterility and Bioburden Testing - LAL passed under 0.5EU/mL Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 3
F Bioburden Testing requirements for Non-Sterile Dental Products EU Medical Device Regulations 6
R Simulated product for bioburden testing Other ISO and International Standards and European Regulations 2
M Bioburden testing for Class 10000 (Grade C) clean room ISO 13485:2016 - Medical Device Quality Management Systems 1
O Bioburden Testing - Non Sterile Product / Tapes - ISO 11737-1 Other ISO and International Standards and European Regulations 9
P Serial Testing of Bioburden for Medical Devices Other Medical Device Related Standards 2
P Frequency of Bioburden Testing EU Medical Device Regulations 3
M Sterility Testing vs Bioburden Testing - Differences Qualification and Validation (including 21 CFR Part 11) 7
I Bioburden and Endotoxin (LAL) Testing proposal help 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
M Spinal Implant Testing Requirements - Bioburden, TGA & Ion Chromatography 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
C ISO 11737 - Bioburden testing for non-sterile products Other ISO and International Standards and European Regulations 10
I Microbiological Testing - Bioburden and Identification of Micro-Organisms ISO 13485:2016 - Medical Device Quality Management Systems 2
B Routine Bioburden Monitoring ISO 13485:2016 - Medical Device Quality Management Systems 5
M Bioburden Frequency (sterile MD) Other Medical Device Related Standards 2
A ISO 11135:2014, B.1.4, BI resistance x product bioburden ISO 13485:2016 - Medical Device Quality Management Systems 6
B Bioburden monitoring for surgical instrument provided non-sterile EU Medical Device Regulations 3
B Radiation Sterilization Dose Audit: Bioburden frequency Other Medical Device Related Standards 1
V Cleanliness/Bioburden for Non-Sterile Gas Path Medical Devices Other Medical Device Regulations World-Wide 7
K Bioburden 0 cfu for Dose Setting using the VDmax25 Other Medical Device Related Standards 9
N Must Bioburden Sampling Procedures be Documented? Other Medical Device Related Standards 5
C What is the most appropriate Bioburden Test Method for Surgical Gloves ISO 13485:2016 - Medical Device Quality Management Systems 10
M Bioburden numbers and ECA gloves 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
M Biological Monitoring Program Environmental Bioburden Test Method Needed ISO 13485:2016 - Medical Device Quality Management Systems 1
C What is an acceptable bioburden level or count when working in cleanroom ISO class7 ISO 13485:2016 - Medical Device Quality Management Systems 1
B BioBurden and EndoToxin Questions Other Medical Device Related Standards 6
S Bioburden Monitoring Sample Size Increase ISO 13485:2016 - Medical Device Quality Management Systems 4
I Bioburden Count Question - Bioburden is above the alert limit >1 CFU/component avg. 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
J Bioburden Monitoring - 'Off the Shelf' Bioburden/Microbiological Monitoring Software ISO 13485:2016 - Medical Device Quality Management Systems 4
L GB15980-2003 Bioburden Count Trend on Operator Hands Other ISO and International Standards and European Regulations 1
0 Guideline/Method for Raw Material Roll Stock Bioburden Sampling Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
Q Bioburden Requirements on Device used on Unbroken Skin Other Medical Device and Orthopedic Related Topics 4
A Microbial Limit (Bioburden)on dry nonwoven that used for making Hand sanitizing wipes ISO 13485:2016 - Medical Device Quality Management Systems 1
D Bioburden and Product Labels - VD Max studies on all the BOMs Other Medical Device and Orthopedic Related Topics 9
H Determining a New Product Bioburden Limit ISO 13485:2016 - Medical Device Quality Management Systems 11
L Validation of transfer materials - Bioburden of items from lab into cleanroom Other Medical Device and Orthopedic Related Topics 2
L Monitoring bioburden on clean room gloves Other Medical Device and Orthopedic Related Topics 1
C Establishing alert and action limits for clean room bioburden Other Medical Device and Orthopedic Related Topics 9
E Bioburden tests duration and Monitoring of gloves ISO 13485:2016 - Medical Device Quality Management Systems 6
S What is a reasonable Bioburden limit? ISO 13485:2016 - Medical Device Quality Management Systems 13
S Pharmaceutical Shelf Life Testing Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 0
D How to testing of Pressure relief valve as per API 6D ? Oil and Gas Industry Standards and Regulations 1
J Impact Testing--Is conversion between Izod and Sharpy Possible? General Measurement Device and Calibration Topics 3
O Should a Covid vaccine and testing policy be included as part of ISO9001 or AS9100 risk management? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
V How to select the tests for proficiency testing Measurement Uncertainty (MU) 0
B Customer Preference Testing Customer and Company Specific Requirements 2
N Pre-Clinical Performance Testing Design and Development of Products and Processes 3
I Software (SaMD) mobile application verification testing: objective evidence Medical Information Technology, Medical Software and Health Informatics 2
I How to find required testing for a specific device? Other US Medical Device Regulations 3
J CQI-9v4 Alternative TUS Testing Methods Various Other Specifications, Standards, and related Requirements 0
