When is FAI required? AS9100 8.5.1.3 and 8.4.3 requirements
MVladimir
Involved - Posts
Hello 9100 experts,
According cl. 8.5.1.3 Production Process Verification
"The organization shall use a representative item from the first production run of a new part or assembly to verify that the production processes, production documentation, and tooling are able to produce parts and assemblies that meet requirements".
Question:
Shall organization perform FAI for every new part as well as assembly and sub-assembly (if manufactured)? Or it is up to organization to decide which parts, assemblies and sub-assemblies could be considered for FAI?
According cl. 8.4.3 Information for External Providers
The organization shall communicate to external providers its requirements for:
i. test, inspection, and verification (including production process verification);
The same question:
In which cases External Providers shall carry out the FAI and what will be the FAI subject (Parts? Assemblies? Sub-assemblies?)
Any input / opinion will be appreciate!
indubioush
It is up to the engineer to determine what dimensions are inspectable, what dimensions are for FAI only, and what dimensions are for reference (meaning they probably will never be measured). Inspectable dimensions need to be inspected for each batch produced. FAI dimensions are inspected on the initials run. The FAI dimensions along with the inspectable dimensions answer the question: Did we make the part correctly?
Let's say your part looks great. Then a few months later, you want to change a few dimensions. The engineer updates the drawing, and may make changes to the designation of certain dimensions (inspectable, FAI, Ref). You would then repeat the FAI on the initial run of the new revision parts. If it looks good, the next back you make, you will only inspect the inspectable dimensions.
Does that help?
MVladimir
Involved - Posts
Thanks indubioush, well explained!
No problems with parts.
I would like to understand - when assembly and sub-assembly should be subject for FAI? What is criteria for FAI in this case? For example - for complicated product such as Helicopter / Gas turbine engine etc.
Al Rosen
Hello 9100 experts,
Question:
In my opinion the standard requires an FAI for every part as well as every assembly and sub assembly. You don't get to pick and choose which ones.
The same question:
In this case, you as the customer will be able to choose, based on your requirement to perform an FAI. For example, if you have to perform an FAI on an assembly, you will request the FAI for a purchased part or sub-assembly from your supplier in support of (i.e. use the supplier's data) your FAI. Your supplier will charge you for the (part or sub-assembly) FAI. Depending on the cost of the supplier's FAI, you may decide to perform the purchased item's FAI as part of your assembly FAI.
BTW FAI does not always require AS9102. You can document what you do in your FAI procedure for when AS9102 is used (i.e. customer requirement) and when it's not used.
Al Rosen
Does that help?
In this example, a "delta" FAI may be performed, only verifying the changes.
MVladimir
Involved - Posts
I completely agree with this statement!! No choose for 9100 certified Company ! Various product level (part, assembly, sub assembly) - various risks for final product !
Thanks for great opinion!
MVladimir
Involved - Posts
Any ideas about cl. 8.4.3 Information for External Providers in part of FAI, please?
If you are doing this for Sikorsky ( or similar ), you should likely flow down the AS 9102 requirement to your vendors on your Purchase Order and have them do the FAI on any supplied parts & assemblies. COTS items not required. Up to you whether you want to perform an incoming inspection on said parts or go dock to stock based on your vendors FAI & inspection data.
You will have to do a higher level FAI if you are assembling said parts from a vendor into a higher level assembly.
A When there is a 2 year lapse in production, is a full FAI required? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
C Is a First Article Inspection (FAI) Procedure required by ISO 13485? ISO 13485:2016 - Medical Device Quality Management Systems 3
Z AS9102 FAI (First Article Inspection) - Is a Ballooned Drawing Required? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
gard2372 Our Parent company is our supplier? FAI (First Article Inspection) not required? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
DuncanGibbons Pre FAI production terminology AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
NDesouza Is my Partial FAI an Assembly or Detail? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
R FAI & P.O. Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
M Weld Symbol--Bubble Drawings for FAI Document Control Systems, Procedures, Forms and Templates 4
briteme4 Customer Requests FAI on Tooling Fixture AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
F Circuit board FAI reports- How do you folks deal with these? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
NDesouza COTS Items CoC for FAI Documentation AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 12
NDesouza FAI Due Date Calculator AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
Q Change the shape of the raw material FAI AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
P FAI Ballooning ASME Y14.5 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
Q Full or Partial FAI? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
D Partial FAI - AS9102 - One single drawing has 10 part numbers AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
M AS9102B Detail Part/Assembly FAI Form 1 box 13; AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
M AS9102 FAI Report formats - Boxes in form 1, 2, 3 of AS9102 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
A AS9100D FAI requirements needed? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
R AS9100 DELTA FAI - Sub-supplier for plating changed AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
B FAI and ANSI Y14.5 Trailing Zeros and Print Tolerances Manufacturing and Related Processes 3
D AS9102 - Assembly FAI for Use As Is or Repaired Parts AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
A AS9102 Delta FAI Require after Rework stock item from stock AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
B AS9102 - Completing Partial FAI's for Baseline Part Numbers AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
K First Article Inspection (FAI) - Equipment used - Dimensions vs. Go/No-Go ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
E AS9102 FAI - What makes a COTS modified? (PCB assemblies) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
B AS9102 FAI & Lower Level Drawings - How should we perform the FAI? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
P AS9102 full FAl or a partial FAI after production inactivity period AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
M FAI AS9102 - What does a First Article Inspection cover? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
ScottK Statistical basis for 30 pieces for FAI 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 7
U Whether First Article Inspection Report- FAI is mandatory for regular Human Factors and Ergonomics in Engineering 4
D FAI. Form 2, process or functional test? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
G FAI Objective Evidence AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
M FAI Requirements of Detail and Assembly AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
O AS9102 FAI report Forms 1-3 Document Control Systems, Procedures, Forms and Templates 6
J FAI per AS9102 affecting Fit, Form, Function AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
R AS9100 FAI - First Article Inspection to a prior Customers PO AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
R AS9102 FAI with No Drawings Supplied AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
G FAI (First Article Inspection) Responsibility - QC or Engineering? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
APHX02 AS9102 FAI Requirements that pertain to a Dimension 'delta' AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
R FAI (First Article Inspection) on source-controlled parts AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
K FAI (First Article Inspection) vs PPAP (Production Part Approval Process) APQP and PPAP 15
W Am I allowed to ship parts without FAI approval from the customer? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
G Is it mandatory to record all processes in form 2 of AS9102 FAI report AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
T FAI (First Article Inspection) of Large Assemblies/Tooling after move to new building AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 12
W Certification on AS9100C - FAI or PPAP? Project Management or APQP? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
Q FAI IAW AS9102 - First Article Inspection Documentation Question AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 20
D AS9102 B (FAI - First Article Inspection) is Released - October 2014 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 12
G Plant Relocation - Is it necessary to perform FAI? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 13
