When is FAI required? AS9100 8.5.1.3 and 8.4.3 requirements
#11
Any ideas about cl. 8.4.3 Information for External Providers in part of FAI, please?
In which cases External Providers shall carry out the FAI and what will be the FAI subject (Parts? Assemblies? Sub-assemblies?)
Vlad, you will need to define when the FAIR needs to be completed in your SOP, you can also document the RISKs there as well. Note that you may want to do a FAIR even on COTS parts every few years (for a comfort level to ensure that nothing has changed that could impact the product or your process) - while you can flow this requirement down if its truly a COTS part your external provider will probably NOT give you any thing resembling AS9102; at any revision change (recommended) for assembly & subassembly parts. we also require a FAIR if the supplier moves, changes ownership etc but those are on a part to part basis and should be called out as part of your quality requirements.
A When there is a 2 year lapse in production, is a full FAI required? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
C Is a First Article Inspection (FAI) Procedure required by ISO 13485? ISO 13485:2016 - Medical Device Quality Management Systems 3
Z AS9102 FAI (First Article Inspection) - Is a Ballooned Drawing Required? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
gard2372 Our Parent company is our supplier? FAI (First Article Inspection) not required? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
NDesouza Is my Partial FAI an Assembly or Detail? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
R FAI & P.O. Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
M Weld Symbol--Bubble Drawings for FAI Document Control Systems, Procedures, Forms and Templates 4
briteme4 Customer Requests FAI on Tooling Fixture AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
F Circuit board FAI reports- How do you folks deal with these? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
NDesouza COTS Items CoC for FAI Documentation AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 12
NDesouza FAI Due Date Calculator AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
Q Change the shape of the raw material FAI AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
P FAI Ballooning ASME Y14.5 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
Q Full or Partial FAI? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
D Partial FAI - AS9102 - One single drawing has 10 part numbers AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
M AS9102B Detail Part/Assembly FAI Form 1 box 13; AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
M AS9102 FAI Report formats - Boxes in form 1, 2, 3 of AS9102 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
A AS9100D FAI requirements needed? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
R AS9100 DELTA FAI - Sub-supplier for plating changed AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
B FAI and ANSI Y14.5 Trailing Zeros and Print Tolerances Manufacturing and Related Processes 3
D AS9102 - Assembly FAI for Use As Is or Repaired Parts AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
A AS9102 Delta FAI Require after Rework stock item from stock AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
B AS9102 - Completing Partial FAI's for Baseline Part Numbers AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
K First Article Inspection (FAI) - Equipment used - Dimensions vs. Go/No-Go ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
E AS9102 FAI - What makes a COTS modified? (PCB assemblies) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
B AS9102 FAI & Lower Level Drawings - How should we perform the FAI? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
P AS9102 full FAl or a partial FAI after production inactivity period AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
M FAI AS9102 - What does a First Article Inspection cover? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
ScottK Statistical basis for 30 pieces for FAI 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 7
U Whether First Article Inspection Report- FAI is mandatory for regular Human Factors and Ergonomics in Engineering 4
D FAI. Form 2, process or functional test? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
G FAI Objective Evidence AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
M FAI Requirements of Detail and Assembly AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
O AS9102 FAI report Forms 1-3 Document Control Systems, Procedures, Forms and Templates 6
J FAI per AS9102 affecting Fit, Form, Function AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
R AS9100 FAI - First Article Inspection to a prior Customers PO AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
R AS9102 FAI with No Drawings Supplied AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
G FAI (First Article Inspection) Responsibility - QC or Engineering? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
APHX02 AS9102 FAI Requirements that pertain to a Dimension 'delta' AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
R FAI (First Article Inspection) on source-controlled parts AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
K FAI (First Article Inspection) vs PPAP (Production Part Approval Process) APQP and PPAP 15
W Am I allowed to ship parts without FAI approval from the customer? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
G Is it mandatory to record all processes in form 2 of AS9102 FAI report AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
T FAI (First Article Inspection) of Large Assemblies/Tooling after move to new building AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 12
W Certification on AS9100C - FAI or PPAP? Project Management or APQP? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
Q FAI IAW AS9102 - First Article Inspection Documentation Question AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 20
D AS9102 B (FAI - First Article Inspection) is Released - October 2014 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 12
G Plant Relocation - Is it necessary to perform FAI? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 13
A AS9102 First Article Inspection and NC Parts - New FAI? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
