When is MSA (Measurement System Analysis) appropriate on a custom built gage?
:topic: When is MSA appropriate? I have been asked to perform MSA on a new custom built gauge. However, the characteristic the gauge is measuring is neither significant nor critical. Do I need to do MSA on this gauge? I can find nothing about when MSA needs to be performed. I also have several custom gauges which are the same. i.e. perform the same function and built the same. Now, I know that MSA can be performed on families of gauges. Do I need to do each gauge, or would one study be sufficient. And finally, when does MSA need to be re-done? My understanding is that MSA should be re-done after the gauge has been moved, after repair and when a new operator is using the gauge. Would that be correct?
Many thanks
Why have a custom-built gage for an insignificant characteristic?
It depends on customer requirements and common sense, although not necessarily in that order. If you are working under the AIAG PPAP requirements, MSA is required "...for all equipment used for new or modified gages, measurement, and test equipment" (page 8, PPAP 3rd Edition). There is also a requirement (page 6) for MSA to be performed on gages used in PPAP capability studies. Your customer(s) may have other specific requirements.
As for the common sense part of it, if you've spent good money on a custom gage it stands to reason that you'd want to know if it will work as intended, so MSA is a good idea even in the absence of customer requirements.
Assuming that you've verified that each was "built the same," a "family" GR&R would be appropriate under most circumstances insofar as customer requirements are concerned, but again, you should decide for yourself whether or not it would make sense to do MSA on each one.
There are no hard-and-fast rules in the absence of customer-specific requirements. Movement of a gage from one place to another shouldn't be reason in itself. New operators should be qualified the same way as present or former operators were qualified, and re-analysis might be appropriate, especially if previous analyses indicated an issue with operator error .
S IATF 16949 7.1.5.1.1 Measurement System Analysis (MSA - Die casting) IATF 16949 - Automotive Quality Systems Standard 5
B Camera Vision System Measurement System Analysis (MSA) Reliability Analysis - Predictions, Testing and Standards 3
L IATF 16949 7.1.5.1.1 Measurement System Analysis (MSA) - Visual Inspection IATF 16949 - Automotive Quality Systems Standard 14
C MSA (Measurement System Analysis) - Instrument Selection Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
C MSA (Measurement System Analysis) - Dimension Selection Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
S MSA (Measurement System Analysis) - Process Tolerances Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
S MSA (measurement system analysis) on Flammability tester? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
B Selecting Parts for an MSA (Measurement System Analysis) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
T MSA on Camera Vision System and other Process Measurement Systems Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
G MSA (Measurement System Analysis) and Dimensional Tolerances Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
F MSA - Measurement System Analysis Attribute Data Crosstab sheet APQP and PPAP 1
R Destructive Non Reproducibility MSA (Measurement System Analysis) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
M MSA (Measurement System Analysis) on a Photospectrometer Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
T MSA (Measurement System Analysis) Competency Test Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 11
B Surface Finish Equipment MSA (Measurement System Analysis) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
A Is MSA useful to prove a Measurement System after Relocation? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
B Very interesting article concerning MSA (Measurement System Analysis) Book, Video, Blog and Web Site Reviews and Recommendations 8
B Wait or not wait? MSA (Measurement System Analysis) Actions Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
B MSA (Measurement System Analysis) - Results and Actions Taken Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
A MSA (Measurement System Analysis) for Characteristics with One Tolerance Limit Capability, Accuracy and Stability - Processes, Machines, etc. 10
C Attribute Measurement System Analysis (MSA) Template Document Control Systems, Procedures, Forms and Templates 0
D MSA (Measurement System Analysis) on a Bore Measurement - Good or bad result? Six Sigma 9
M Is MSA (Measurement System Analysis) Required for Degradation Testing? IATF 16949 - Automotive Quality Systems Standard 1
M MSA (Measurement System Analysis) - Do we have control of all states in the chart? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
E MSA (Measurement System Analysis) Study on an Automated Process Quality Tools, Improvement and Analysis 4
optomist1 Is a MSA (Measurement System Analysis) needed on these two tests Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
C What is the most appropriate MSA (Measurement System Analysis) Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
M How to Stack for MSA (Measurement System Analysis) in Minitab? Using Minitab Software 1
V Is MSA (Measurement System Analysis) required for Weighing Scale? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
Rameshwar25 Linearity Problem (MSA - Measurement System Analysis) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
B Gage R&R/MSA for In Process Measurement System in a Turning Machine Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
S Weighing Scale MSA (Measurement System Analysis) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
Q MSA Studies on each Equipment, each Measurement System or Family in Control Plan? IATF 16949 - Automotive Quality Systems Standard 35
I Destructive Testing Measurement System Analysis (MSA) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
S Sample Size for Attribute MSA (Measurement System Analysis) in 4th Edition Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
L Measurement System Assessment (MSA) - Water Crackle Test General Measurement Device and Calibration Topics 2
S Choosing Parts for Attribute MSA (Measurement System Analysis) in 4th Edition, pg 132 Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
A Yearly MSA (Measurement System Analysis) & Capability Study - TS 16949 Requirements Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
Z MSA (Measurement System Analysis) for a .0003" tolerance feature Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
automoto Attribute MSA (Measurement System Analysis) - .xls Form attached Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 27
S MSA (Measurement System Analysis) for Medical Device Manufacturers Other US Medical Device Regulations 3
automoto Visual Inspection of a Weld - MSA (Measurement System Analysis) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
K MSA (Measurement System Analysis) on Multi-Phase Measurement System Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
A Width and location errors in MSA (Measurement System Analysis) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
M Measurement System Analysis (MSA) Procedure template Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
Miner Intro to Measurement System Analysis (MSA) of Continuous Data – Part 5b: R&R Imported Legacy Blogs 14
Miner Intro to Measurement System Analysis (MSA) of Continuous Data – Part 5a: R&R Imported Legacy Blogs 5
