Rob Nix said:
Simply put, you change the limits when the process (reflected in the charts themselves) indicates you should. So only point #1 in e006823's post is applicable (the other points will show in point #1).
There is NEVER a set time period (e.g. week, month) where limits must be recalculated.
As Rob stated the chart itself will tell you that something has occurred with your process. You still have to determine if the change is “good” (has the process improved), is the change permanent or was it caused by a transient event, and what caused the change.
1) Process exhibits obvious change over past behavior
If this is not true then there is no reason to recalculate the limits
2) You know what has caused the change
If the answer to this is no you should be looking for the assignable cause.
3) You like the change (process has improved)
If this is not true you should be looking for the assignable cause.
4) You have reason to expect the change to last
It may be a philosophical difference but I believe that control charts should be used to understand and improve your process and unless you can answer all of these questions you have no valid reason for recalculating the control limits.
Regards,
Bob
