When should a Corrective action be created? (Procedures not being followed)
Ragnarok
Hello To All .
I am having a problem at work .
Corrective actions are being requested for the following:
- Customer complaints
- Internal audits
- Product Non Conformance
- Issues costing the company Money
- Procedures not being followed
my main concern is the 5th point ... its creating a lot of problems because people are feeling like other people are "snitches" and they are getting angry at each other when some people are reporting that a procedure was not followed
MY question is : How can i clarify to the staff when it is OK to request a Corrective action , and when a corrective action is not needed ( a simple correction will do ) ???
Could you provide me with examples of "levels" of corrective actions , or any classification that would allow me to determine if a corrective action needs to be created ?
Thanks for the help
somashekar
Re: When should a Corrective action be created ?
Welcome to the Cove Ragnarok ...
I understand that you are mentioning about DOCUMENTED procedures not being followed.
Am I OK ?
So what is happening actually. What is going wrong ?
Did you come back from the non conforming end to the procedure and then find out that not following the procedure resulted in that non conformance ?
Sometimes it so happens that the procedures were made when they were felt good and appropriate, but as years roll by the procedure could no longer be relevant.
It could also happen that a thing can be made in many ways achieving the same end result, however the procedure captures only one way.
So, again.... What is happening actually. What is going wrong ?
Come back to the procedure finally to
Amend it
or
Obsolete it
Ragnarok
yes documented procedure
i will give an example:
Our Purchasing procedure stipulate that our purchasing officers must get quotes and contact the suppliers to get prices and purchase goods .
However there are some employees (not purchasing) that contacted directly the supplier , got a quote and then asked the supplier to send us the goods
This infuriated the purchasing officers who sent a corrective action request , but it created a problem between purchasing department and other departments
The persons that contacted the suppliers said that they did it because it was an emergency ...but our procedure does not allow other people than purchase officers to buy from suppliers even if its an emergency :(
hope I am clear
Kindly advise
Stijloor
hope I am clear
That is a management/discipline issue. Using the corrective action process as a means to change people's behavior will be viewed as punitive and kills the corrective action process and its benefits in no time.
The supervisor or manager must take care of this with the offending employee directly without corrective action requests.
Disciplinary action can be initiated if needed.
somashekar
Why must a purchasing officer only get a quote ? Some employees who are getting the quote are perhaps the user's and they are doing a bit ahead to get the required material, thereby assisting the purchasing.
Ask supplier to send the material ?
How.. On the phone ? by e-mail ?
Does the supplier send you the goods without a Purchase order from you ? How does he get paid for the goods ?
The best those employees can do is to forward the quote and supplier reference to purchasing for further actions, with the approval to purchase.
Ragnarok
Ok ...
but my question remains :
Could you provide me with examples of "levels" of corrective actions , or any classification that would allow me to determine if a corrective action needs to be created or if instead a simple correction will do ?
Should i tell the staff that Corrective action request are for customer complaints , product non conformance , but that Internal Procedure non implementation does not require a corrective action request and should be sent to the appropriate manager to be treated ?
But if some employees are repeatedly not working according to procedures then doesnt that require a corrective action request ???
I am lost ...
Marcelo
It's weird to request a corrective action. People should identify NCs and request an investigation. Then, after analyzing the root cause, you decide if you need only a correction or a corrective action.
Ragnarok
hmmm..
maybe change the "Corrective action request form" to " Problem investigation request" form
then we would decide if the problem needs simple correction or corrective action
W
WsmithA
Hello. This is my first post. I hope it will be helpful.
I've found issuing a corrective action is a costly activity. It takes up a lot of resources. At the same time it is a necessary activity for some nonconformances.
To help your situation I would suggest to update your corrective action procedure and put in-place a qualification to get a corrective action issued. I've used Severity levels and frequency levels to justify a corrective action being issued. To give you an example we'll use your situation:
If the personnel deviated from the purchasing procedure once, a corrective action wouldn't be issued. Some discussion should occur to reinforce that there is a procedure and it must be followed and if it happened again a corrective action will be issued (according to the corrective action procedure). If the personnel or another personnel deviated from the same procedure, a corrective action would need to be issued.
Cheers!
K
kgott
hmmm..
Thats actually a very good idea. It will give it a global application and not restrict it to quality issues, it would go well in safety.
Just got to ensure it stays only the management system arena and not spill over into HR issues, but thinking obout it, are unwanted events in safety HR or system oriented isses ...humm?
sagai Should Corrective Action be segregated from Preventive Action? ISO 13485:2016 - Medical Device Quality Management Systems 10
A Whom should I send the FSCA (Field Safety Corrective Action) to? EU Medical Device Regulations 2
C Should Preventative Action follow a Corrective Action Nonconformance and Corrective Action 27
J What should generate a CAPA (corrective action - preventive action) US Food and Drug Administration (FDA) 16
Q How many records should I keep when implementing Corrective Actions Records and Data - Quality, Legal and Other Evidence 3
Q CAPA - What criteria should be used to initiate Corrective and Preventive Actions ISO 13485:2016 - Medical Device Quality Management Systems 8
T Who should take the lead for 8D Corrective Actions Preventive Action and Continuous Improvement 13
S Who should do the CA's (Corrective Actions) from Internal Audits Internal Auditing 9
Sidney Vianna Interesting Discussion Should ISO 9004 be changed from a guidance standard to a requirements standard? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
N Master Samples - What should we be keeping? IATF 16949 - Automotive Quality Systems Standard 9
G Supplier delivered recent PPAP, should he deliver yearly layout inspection? IATF 16949 - Automotive Quality Systems Standard 4
John Broomfield Vote - Should ISO9004 Become a Requirements Standard? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
J Should Loading and Unloading be Included in Cycle Times? Lean in Manufacturing and Service Industries 14
E Manufacturers should develop a testing device for covid19 Service Industry Specific Topics 0
T 510(k) submission - Which name should I use in the submission? Other US Medical Device Regulations 3
N ISO 19011:2018 - 5.4.2 "...audit program should engage in appropriate continual development..." Training - Internal, External, Online and Distance Learning 4
M Should 510(k) Predicates be Actively Listed Devices? Other US Medical Device Regulations 12
H Who should be listed as the manufacturer/distributor on the box? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 15
M MDR, RED and LVD - Should our device comply with them? EU Medical Device Regulations 3
BeaBea How Many Processes should be created for each Department? Process Maps, Process Mapping and Turtle Diagrams 5
M Should volume of sales be factored into risk probability assessments? ISO 14971 - Medical Device Risk Management 33
S Should safety checks be included in the Control Plan? IATF 16949 - Automotive Quality Systems Standard 5
M Which incubation condition should be selected to recover both bacteria and fungus effectively Miscellaneous Environmental Standards and EMS Related Discussions 3
D Is there a specific location for PPE such as safety glass holders and glove dispensers should be mounted Occupational Health & Safety Management Standards 10
M Who should receive the bills from suppliers and vendors, account payable or procurement? Consultants and Consulting 4
A We are ISO 13485:2016 should we be audited to ISO 14971 ISO 13485:2016 - Medical Device Quality Management Systems 16
E Received a Major finding during IATF Surveillance audit for loss of BIQS Level 3 (more than 6 SPPS in 6 months)...how should we address SYSTEMIC CA? IATF 16949 - Automotive Quality Systems Standard 11
J Organization merger. Should we keep two separate ISO 13485 certificates? ISO 13485:2016 - Medical Device Quality Management Systems 6
S Companies that maintain your machine should be in ASL? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
S Use of "Shall" versus "Should" in Procedures ISO 13485:2016 - Medical Device Quality Management Systems 26
D Class II medical device - When should a complaint be closed? Customer Complaints 6
Sidney Vianna IATF 16949 News Presentations from the latest IATF Stakeholder Event - Expectation that IATF 16949 certification should equate with product quality. Misguided? IATF 16949 - Automotive Quality Systems Standard 7
