When to create a new Control Chart? Quick question
K
kwok007
Hi All,
I am a newbie to this forum and a beginner to SPC too.
Recently I am working on a very basic project plotting xbar-r chart on some production measurements. Based on the data from the 1st week, I was able to find the out-of-control (OOC) points and the root cause (human, machine, material, measurement, environment...). After adjusting the process, I received the data during the 2nd week.
My question is: should I plot 2 weeks data together (after removing the OOC point from the 1st week) to find the new control limits or I should plot the data from 2nd week separately from the 1st week's data?
I tend to prefer the latter, since I think something has been adjusted to change the process (maybe improved the process) from the beginning of 2nd week.
If so, what if the data in 2nd week are in control, then what should I do to the 3rd week's data? will the chart from 2nd week serve purely as a monitor to 3rd week's data as a Phase II chart? or I should calculate the control limits based on the 3rd week's data again?
Thanks very much in advance!
Kwok007
Steve Prevette
Deming Disciple
Re: Quick question: When to create a new control chart
Sounds like you are off to a good start. If you believe you have removed the source of the out of control points for the first week, yes, try a set of average and control limits for the first week without the out of control points. I don't know how much data you have, but if the first week was a dozen or less points, bring in the second week and see how it looks. If this brings you close to 25 points, then use this baseline as a prediction for future performance, and to tell if future changes have an effect on the process. You don't want to keep recalculating the control limits, or they in effect become moving averages and you won't be able to detect if the process is really changing, or just has random noise.
Now, if you do generate a significant improvement, then you can calculate a new set of average and control limits following that shift. Just remember something I was told - a baseline is innocent until proven guilty (that is - when a trend signal develops).
K
kwok007
Hi Steve,
Thanks for your help very much. It helped a lot. I read of other posts of yours too. They are great resources for this forum. I am glad that I found elsmar.com:)
So basically whenever I adjusted something in a process, I need to revised the control limits, right?
Another question: what can I do if the process mean is still off target after the process was adjusted a couple of times?
Thanks again for your help!
Steve Prevette
Deming Disciple
No, wrong. You would only revise the control limits IF the process results prove that the adjustment changed the process data. Not every adjustment is effective, and sometimes there is a time delay from when you believe the adjustment was made until it has an effect.
Keep on adjusting. Learn what you can from previous adjustments. Did they nudge the mean towards target? Do more of that. Did they get worse? Don't do that. Was there no change? Why not?
Keep in mind that if you can make changes on a small scale (such as if you have five processing lines, change only one) and usually the response is faster, and the risk is less if the change makes things worse.
K
kwok007
Got it! Thanks Steve for your help very much!
T Change control and configuration management - When to create a new model/part number? Other Medical Device and Orthopedic Related Topics 0
C Document Control using Wiki - Cannot Create all Documents as Wiki Pages Document Control Systems, Procedures, Forms and Templates 10
L Customer requirement to create a Guide for defining Control Methods FMEA and Control Plans 9
H How to create Stoplight Control charts with excel? Excel .xls Spreadsheet Templates and Tools 16
I Environmental Program - Create a Environmental Control Plan - Example Attached Miscellaneous Environmental Standards and EMS Related Discussions 4
V How many hrs does it take to create a Technical File (TD)? EU Medical Device Regulations 4
D ISO 13485 - 7.3.6 Design and development verification - Do most folks create a separate SOP? ISO 13485:2016 - Medical Device Quality Management Systems 6
J Question: How to create an IMDS RoHS, REACH, ELV, IMDS and Restricted Substances 3
M Do we need to create a new CER or can we just update the existing CER EU Medical Device Regulations 3
J Create your own symbol? Other Medical Device Related Standards 7
D How to create IQ, OQ, PQ protocol for existing equipment Other Medical Device Related Standards 2
O How to create robustness checklist from p diagram FMEA and Control Plans 11
R How to create a Work Breakdown Structure? Registrars and Notified Bodies 2
H IMDS for material - Can my Customer create one for my material? RoHS, REACH, ELV, IMDS and Restricted Substances 4
A How do I create a 3^k factorial design with factors be treated as continuous where I Using Minitab Software 0
E How do I create a FMEA for the Internal Audit process? Internal Auditing 11
S Response Surface Method to create design matrix in Minitab Using Minitab Software 5
S Cannot create Rejects for TMV on a medical instrument with an LCD Other Medical Device and Orthopedic Related Topics 10
RoxaneB Carte Blanche to Create an Audit Programme General Auditing Discussions 5
O Is it "legit" to create IMDS before Part Production? RoHS, REACH, ELV, IMDS and Restricted Substances 4
G How to create a mixed OAs in Minitab Using Minitab Software 1
S How to create an Audit Checklist using a Turtle Diagram Internal Auditing 9
A Could I create company specific Employee Records? Records and Data - Quality, Legal and Other Evidence 5
A How to create a Maintenance procedure based on TS 16949 Requirements IATF 16949 - Automotive Quality Systems Standard 5
Ajit Basrur How do I create two different columns in Excel spreadsheet ? Excel .xls Spreadsheet Templates and Tools 5
J Inspection Software to Balloon Drawings and Create First Article Reports Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
T Microsoft Access Database to create a Simple Calibration Certificate General Measurement Device and Calibration Topics 6
J Should a company create different SOPs for ISO14971? ISO 14971 - Medical Device Risk Management 1
J How do you Create SOPs for Multiple Authorities? EU Medical Device Regulations 8
R How to create a pop-up message in Excel Excel .xls Spreadsheet Templates and Tools 18
M What is the formula to create a bell curve? Excel .xls Spreadsheet Templates and Tools 8
M ISO/TS 16949:2009 Follow-up Audit Visits to create more Revenue IATF 16949 - Automotive Quality Systems Standard 12
Q Medical Device with Lead (Pb) - Do I need to create an MSDS sheet? Other US Medical Device Regulations 1
B How to use Minitab to create this Fractional Factorial Design Matrix Using Minitab Software 2
M How to create the Policy for determining criteria for Risk Acceptability ISO 14971 - Medical Device Risk Management 11
T How create a Fractional Factorial Design with Minitab Using Minitab Software 3
A How to create a Multiple Operations Specifications Comparison Spreadsheet? Excel .xls Spreadsheet Templates and Tools 3
A How to create Drop Down Box in Excel 2007 Excel .xls Spreadsheet Templates and Tools 2
N Asked to create a baseline survey on emails that come in and out of our Office Document Control Systems, Procedures, Forms and Templates 1
J How Do Processes Create Value? Article by Paul Harmon Book, Video, Blog and Web Site Reviews and Recommendations 2
W Requirements Traceability Database - Have one? Help create one? Document Control Systems, Procedures, Forms and Templates 1
S HR Manager refusing to create Quality Objectives - Is this a Non-Conformity? Quality Manager and Management Related Issues 11
S How do I create a Technical File for a Class IIa Medical Device EU Medical Device Regulations 5
C SOP (Standard Operating Procedure) on how to create an SOP Document Control Systems, Procedures, Forms and Templates 6
O Need to Create Macros so that it can copy data to the next row.... Excel .xls Spreadsheet Templates and Tools 5
B Who should create training associated with changes to the procedures? Document Control Systems, Procedures, Forms and Templates 7
J Environmental FMEA - Is it possible to create an environmental FMEA? FMEA and Control Plans 12
C Need help to create tracking tool Excel .xls Spreadsheet Templates and Tools 4
W Medical Device FMEA vs. ISO 14971 to create our Hazard Analysis ISO 14971 - Medical Device Risk Management 2
B How Can I Create a Bell curve in Excel 2007 Excel .xls Spreadsheet Templates and Tools 7
