hi,
i'm an amateur in FAI....i went through the standard 9102....i've some doubt request for clarification ....
Clause 5.1 says '....on new production representative of the First Production Run....".
Now the situation is...I have an LRU (Line Replaceable Unit) comprising of both mech parts and electronic sub-asssemblies....it's in final design stage and due for first time production....our company plans to do a batch production of the same.
I'll definetly do the FAI for the first case of the production....if we start a second batch of production after say 3 or 6 months then again should i do FAI on the first case of second batch production ?
our product has the diversity...small amount of software and hardware change can be used in another aircraft...then should i do partial FAI or the full FAI on the same ?
