When to update a PFMEA (Process FMEA)
jkittle
How far do you take updating PFMEA's?
I was written up by our register for "The APQP process is not effective at ensuring that PFMEAs are updated as new failure modes are identified and actions to reduce RPNs are taken."
I had the three customer complaints out of 20 that for 2007 that I did not update the PFMEA. My reasoning was that they were not new failure modes and I did not make any process changes. These were operator issues that they did follow existing procedures. Yes the root cause lies mostly in an ineffective training program.
Do you have to address the PFMEA on every customer failure and how do you address something that is a training issues with an occurrence of 1?
Kales Veggie
People: The Vital Few
Re: When to update a PFMEA
My first impression is that the registrar interprets the standard too tight.
What clause and what evidence is cited for the write-up?
jkittle
Element/Procedure Reference:
ISO/TS 16949 Clause 7.1.4 and 7.3.1.1
Below is the actual write up.
Description of Nonconformance, Requirement and Objective Evidence: "The APQP process is not effective at ensuring that PFMEAs are updated as new failure modes are identified and actions to reduce RPNs are taken."
Requirement: (The standard requires or their procedures/work instructions/Level 1/Level 2required and was not followed)
The organization shall develop and review PFMEAs. The organization shall have a change control process and changes shall be verified and validated before implementation.
The PFMEA for part numbers ABC/EFG has not been updated to include recent failure modes identified in addressing DCARs (cutomer complaints) and actions taken to reduce RPNs.
David DeLong
Yes the Process FMEA should be updated on all customer complaints but it is only clerical.
Your 8D or Corrective Action system will drive your customer complaint but make sure that the new failure mode is now in your Process FMEA. Should one get the team together (assuming you really did a proper FMEA during process development)? Probably not. This is a clerical situation and the only people who would be interested in the revised P FMEA would be the 3rd party auditor.
Sometimes it can be discouraging putting on a show but it is part of the "game" especially in automotive.
Duke Okes
This is not an adequate NC since there is no specific traceable evidence provided (e.g., which DCARs was PFMEA not updated?).
You might consider updating your CAR form to include something like "FMEA need updating?" to show when you do and don't consider it appropriate.
Chances are the auditor is being nitpicky, but without actual evidence hard to know.
Bigfoot
:agree1: I agree with what the others have said here. Tying the P FMEA "REVIEW" into the CAR form is a good trigger / reminder that it gets reviewed and updated, even if it is the clerical update Dave referenced.
Stijloor
Hi Jerry,
The PFMEA is a "living" document and should reflect the "current state of process affairs." That means that if new (significant) failure modes are discovered, they should be included in the PFMEA record. Also, as significant improvements have been realized (the process is becoming more robust), then the PFMEA should be updated as well. Your challenge is now to upgrade your PFMEA development process to incorporate such changes.
You should also develop criteria for what "significant" means for your organization. Be realistic about it and don't do this to satisfy the wishes/expectations of the auditor. Make it work for you! :yes:
Hope this helps.
Stijloor.
Here's what the OP said, with my emphasis:
There's no point in "updating" something with information it already contains. The fact that the OP had 20 issues and did update PFMEAs for 17 of them indicates that (A) this is not a systemic issue, and (B) the OP understands the requirements and (C) the auditor apparently doesn't.
Helmut Jilling
Auditor / Consultant
I fully agree. I am frankly surprised that 17 of 20 resulted in a PFMEA update. The PFMEA should be considered, but updates are only required when there is some information that needs to be changed. Perhaps the OP should ask the auditor what information inparticular should be changed. If he has a good answer, then perhaps a change is warrated. If not, it should shut down the discussion.
jkittle
Thanks to all for your replies.
I think you all hit on what I'm felling as well, that the P FMEA should be updated when important changes are needed and not just a clerical thing.
If I've made no process changes or amendments to existing procedures or work instructions and the failure lies with an operator failure regardless if the operator failure is due to poor training I see no need to update the P FMEA.
I still struggle at times with the P FMEA. I look at the P FMEA as a way of identifying potentials failures with machine process parameters or subsequent operations during the manufacturing process.
The other example that the auditor found was a customer requested change to a dimension a on a part to bring it closer to nominal. The change caused another dimension to go out of spec that did not get evaluated at the new PPAP because no one knew the change would have an adverse affect on that feature. This lead to a non-usable part (customer complaint). We looked at the failure as a design issue. The design team did communicate to a quality lab all the potential changes that could have occurred so the lab did measure this feature. We now use a form that comes from Engineering that when mold changes are done the Engineering group based on the change will know what features cold be changed and the lab is verify all before PPAP.
How does this go into a P FMEA? I look at this a more of a system failure and not a process failure that goes into a P FMEA.
J When to Update PFMEA (Process FMEA) - Rejection is found at the customer FMEA and Control Plans 12
H Corrective Action: When to update the Process FMEA (PFMEA) FMEA and Control Plans 15
B Update our PFMEA after Supplier updates their PFMEA? FMEA and Control Plans 4
A When will ISO13485 Update be Released? EU Medical Device Regulations 1
S ISO9001:2015 Implementation / update plan template ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
Sidney Vianna IATF 16949 News Update on the IATF CARA Project (“Common Audit Report Application”) - 12/2020 IATF 16949 - Automotive Quality Systems Standard 1
M Trigger to update of TLL VDA Standards - Germany's Automotive Standards 0
O IATF 16949 News Ford Motors Customer Specific Requirements Update - Nov 2020 IATF 16949 - Automotive Quality Systems Standard 5
D GMDN code update - Canada - Do you know if there is guidance? Canada Medical Device Regulations 0
Ninja Windows 10 100 % disk use after update Coffee Break and Water Cooler Discussions 33
mike10 QMS Update - Rev. up or start over? Document Control Systems, Procedures, Forms and Templates 3
M Do we need to create a new CER or can we just update the existing CER EU Medical Device Regulations 3
dgrainger Informational MHRA guidance update on withdrawal of Notified Bodies Medical Device and FDA Regulations and Standards News 0
F Software development plan for SW update IEC 62304 - Medical Device Software Life Cycle Processes 2
M Informational Update on ISO TC 210 JWG 1 activities Medical Device and FDA Regulations and Standards News 0
M Informational EU – October 2019 update – State-of-play of joint assessments of Notified Bodies in the medical device sector Medical Device and FDA Regulations and Standards News 2
M Informational US FDA Final and update guidances – Software Medical Device and FDA Regulations and Standards News 2
M Informational From Medtech Insight – QSR/ISO 13485 Harmonization Update: FDA Enforcement Discretion Likely When New Rule Stands Up; Draft Reg Coming By Year’s End; Medical Device and FDA Regulations and Standards News 0
M Informational Update from GOV.UK – Regulating medical devices in the event of a no-deal Brexit – UK Responsible Person Medical Device and FDA Regulations and Standards News 0
M Informational Device Shortages Update – The US FDA Announces Two New Innovation Challenges on Device Sterilization Medical Device and FDA Regulations and Standards News 0
J Where can I find the latest update to Reach and ROHS? REACH and RoHS Conversations 9
M Informational Update – MDR and IVDR implementing measures rolling plan – 2 more NBs designated under the new regulations Medical Device and FDA Regulations and Standards News 0
M Informational US FDA – Digital Health Update: Mid-Year Update on Software Precertification Program Medical Device and FDA Regulations and Standards News 0
M Informational US FDA – Device Shortages Update: Challenges to encourage the development of new approaches to device sterilization Medical Device and FDA Regulations and Standards News 0
M Informational MHRA update – Medical devices: guidance for manufacturers on vigilance - June 2019 Medical Device and FDA Regulations and Standards News 0
M Is it compulsory to update the obsolete GMDN codes in ARTG? Other Medical Device Regulations World-Wide 4
M Informational USFDA – Digital Health Update: The FDA Announces an Opportunity for Test Case Volunteers for the Test Plan for the Software Precertification Program Medical Device and FDA Regulations and Standards News 0
M Informational US FDA Guidance update – Requests for Feedback and Meetings for Medical Device Submissions: The Q-Submission Program Medical Device and FDA Regulations and Standards News 0
M Informational TGA – Webinar: An update on the consultation for the Regulation of Software, including Software as a Medical Device (SaMD) Medical Device and FDA Regulations and Standards News 0
M Informational EU – Update on state-of-play of joint assessments of Notified Bodies in the medical device sector Medical Device and FDA Regulations and Standards News 1
E Gamma Sterilization Product Update Manufacturing and Related Processes 2
M Informational EU – April 2019 update of the MDR and IVDR implementing measures rolling plan Medical Device and FDA Regulations and Standards News 0
B IEC 62304 - Update Checklist IEC 62304 - Medical Device Software Life Cycle Processes 2
M Informational ISO 14971 / ISO TR 24971 revision update – atualizações sobre a revisão Medical Device and FDA Regulations and Standards News 1
M Informational IMDRF – Proposed update to Clinical Evaluation documents Medical Device and FDA Regulations and Standards News 0
M Informational USFDA Draft Guidance – Review and Update of Device Establishment Inspection Processes and Standards Medical Device and FDA Regulations and Standards News 0
C Do we need to make a new OFI (Opportunity for Improvement) for each document/form we update? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 23
M Medical Device News Last update of the MDR and IVDR implementing measures rolling plan – December 2018 Medical Device and FDA Regulations and Standards News 0
M FDA News USFDA Digital Health Update – New actions and documents Medical Device and FDA Regulations and Standards News 0
M FDA News Digital Health Update: USFDA Report on Non-Device Software Functions Now Available Medical Device and FDA Regulations and Standards News 0
M Medical Device News Letter to the health and care sector: update on preparations for a potential no-deal Brexit Medical Device and FDA Regulations and Standards News 0
Marc Software Update 23 November 2018 Forum News and General Information 1
M Medical Device News Joint Action On Market Surveillance Of Medical Devices (JAMS) Releases Progress Update EU Medical Device Regulations 0
Marc Attachment List Update - 2018-11-16 Forum News and General Information 0
K Medical Device Software Update in Field of AIMD IEC 62304 - Medical Device Software Life Cycle Processes 1
M Medical Device News Health Canada update - Applications for Medical Device Investigational Testing Authorizations Canada Medical Device Regulations 0
M Medical Device News IMDRF update - 26-09-18 - Cybersecurity, Premarket Reviews, Personalized Devices Other Medical Device Regulations World-Wide 0
M Medical Device News TGA update 26-09-18 - Medical Devices Safety Update, Volume 6 September 2018 Other Medical Device Regulations World-Wide 0
M Medical Device News Health Canada Update - 05-09-18 - Pilot Device Advice Canada Medical Device Regulations 0
S How to enforce my colleagues to update SOPs? Document Control Systems, Procedures, Forms and Templates 4
