Re: When to Validate and when not to
Illuminatus,
I work in the Pharma/BioPharm industry and I can tell you that the only things I would care about from a regulatory/validation point of view (for your paper insert) is:
The Print Quality
The accuracy of the variable data
The accuracy and readability of barcode/datamatrix/pharmacode
Beyond those requirements I would want to have a specification for size and weight of insert.
The size is important for three reason:
Fit in our containers
Meets design template (+/- agreed tolerance)
Control of weight (specification)
The weight is important only for the pharma company's packaging process. - The presence of an insert in the final pack is determined by final packaged weight measurement.
The ‘fold’ of the insert would be of no interest to me whatsoever. I would personally therefore not insist on validation of the process you describe. But, as others have said, if your customer ‘requires; it… what can you do?!
Thank you all for responding...
here's another layer... some pharma customers don't even audit for validation. At all. They scratch it out of their plan.
Others just care if we qualified the equipment.
And this is the root of the confusion here... when our customers can't even get on the same page.
Ronan - We do verify. We have an first piece inspection, in-process inspection, and final inspection plan that is fairly robust benchmarked against our competitors.
Gert - Seems to me the FDA is more concerned with the copy that goes on to the paper than the shape of the folded paper itself. The part never touches the drug. It either gets stuck on a bottle, or placed in a box. What you say is part of the problem for drug company suppliers like us - the drug companies expect us to do what they do... but the margins in a printed insert or outsert don't really allow for the techinical staff that pharma companies are accustomed to haveing on hand. If we try to increase the cost to allow for these resources we lose the business. It's a hard place.
Yodon - the specification is +- 1/16 all around. Not hard to verify. I know it's effective because we've never had a complaint about the length/width/thickness being out of spec going back through 4 years of records.
In fact the only complaint about this particular process is missing glue, and off counts. And even then it's under 4 PPM.
The Print Quality
