When to write up a nonconformance and require a NCR - We produce labels
qualprod
Hello to everybody.
I ve been browsing looking for Guide about when to raise a ncr(non-conformity report) and nothing is found.
It is clear is not worth to raise ncr for everything.
For one side when something is found defective but is a minor problem, is not convenient to raise it.(lot of paperwork, no value added)
It is clear if it is a considerable amount of defective product, of course it has to be done.
The problem is , people ask, well , when to raise it? In what amount of bad product?.
According to some % of bad product? Or cost of defective product?
It is not clear to establish a % because for example, we produce labels, very big and very small, in sheets of 30x90 inches size.sometimes we produce
20 big labels in 20 sheets (1 label in each sheet) if I define that with 10% in defective production I will raise a NCR, ok sound good. But if I produce 5000 small labels in 20 sheets (250 en each sheet), in this case 10 % is very little.
So is not possible to use this criteria.
I wonder what are some used practices for these cases?
Could someone give some insights?
Pd .in this case we want to prepare almost all operators in the production team to raise the ncr and no to depend of the quality inspector to be raised.
Jen Kirley
Quality and Auditing Expert
One feature I always liked in my Nonconformance Tracking Log was its application of three criteria to help decide the extent of action for addressing nonconformances. I would like to take credit for that, but that design was from an Environmental Engineer I worked with. In the Log I attached, you can use whatever criteria suit your business and customers.
It makes sense to not treat all the same way, based on risk and value. Still, all need to be addressed in some way and it is important to record them so you can understand if there are repeats that would indicate your actions need to be enhanced.
qualprod
Qualprod, most businesses produce defective product. There are many ways to deal with it. Here is one approach. Does the defect occur repeatedly and perhaps relate to the same product, materials, machine, workers, process, etc. Then you should document the n/c followed by a c/a to eliminate or mitigate the issue. I cover this and many other approaches in my eCourse "Understanding ISO 9001:2015.
Thanks Artjlewis
The point Is : how to define a clear criteria to raise the ncr .
I mean don't want to raise reports for all the cases, I will have cases with very little defective product, while others with too much.
I have heard someone there , it is possible to have a list of criteria, by type of product, cost, percentages, but have no idea where to start
John Broomfield
Be more careful with your terminology. Nonconformity is not necessarily defective product.
Take a look at your acceptance criteria: do they define requirements so as to allow blemishes that are acceptable to your customers?
Now take a look at your NCR form. Why is it such a pain to complete? Can NC reporting be simplified to provide data that leads to valuable information?
From what you say you have a hair trigger invocation of onerous NC controls. So, apply your risk management thinking or process to tame your NC controls so they protect your reputation while being feasible and valuable.
It sounds like you need a process for production sort/scrap. Then you can trend your yields and open a CAPA if you see a drastic change. For example, let's say you print 50 labels and one is smeared. If your manufacturing procedures instruct you to reject out that label, you would not open an NCR. Your yield is now 49/50. On the other hand, if you print 50 labels, box them up and then later realize your label had the wrong information on it, that is an NCR.
Pancho
wikineer
Hello to everybody.
That’s not so clear to me. I’d advice to record nearly all nonconformities. Records needn’t be complex. A quick entry into your database takes little effort. You can consolidate several similar instances into one record. And the record provides solid evidence of your handling of the NCs if a problem shows up later.
No record invites sloppy work. Without a record, how can you even be sure that NCs are really that? Or that they are being handled properly? If NC handling is “a lot of paperwork”, then maybe you need to look at your NC handling procedure.
Whether you take corrective action or not is a different issue, but the NCRs allow you to make informed decisions about your process.
Tagin
What is the point of raising an NCR? It is to 1) log occurrences of nonconformances, and 2) to improve the system. So your NCR process should accommodate review of an NCR and determining if it should be pursued or simply logged and closed. Those NCRs which can be pursued in order to improve the process are the ones you want to spend effort on. That ROI of improvement cannot always be correlated directly with percentages or costs, which is why you are having a hard time trying to set some kind of artificial criteria. As JohnB said, use a risk mgmt approach to determine what the ROI will likely be from pursuing an NCR.
Don't discount logging & closing as inaction. It builds a database for patterns and trends which will help in the long run to uncover better improvements that might be overlooked if you try to react to individual events rather than the larger issue causing the pattern/trend.
Again, if you are going to do that, then you need to allow in your process to evaluate the newly created NCR and determine if it should be pursued or simply logged and closed.
qualprod
Thanks to all
I understand in respect to log all the non conformances and decide what to do.
but the question/doubt persists.
I know it may exist different criterias for the evaluation once is detected, but thats what I´m looking for.
I remember I got some day form the net a good criteria but not remember where , it was like this:
1- type of product, product A,B,C,D , with values 1, 2,3, and 4
2- Cost 0 -20 USD, 21-50, 51 and up (values 1,2 and 3)
3- time spent in production, 0-60 min, 61 - 120 min, 121 and up, values 1 , 2, 3
So if the nonconformity resulted in 1+1+1=3 , decision = no NCR risen
If 1+3+3 = 7, NCR is risen.
So values falling in certain ranges, deserved the NCR.
The point is if it is very low value of the nonconfrmance, time spent , few minutes, some cents.
there is no need to waste time the reporting these kind of non conformances.
And the need is to take the decision immediatelly , based on such criteria.
I know , it is also convenient to log all the nonconformances in order to propose improvements.
but no to rise NCR for all.
Hope have explained well.
John Broomfield
You seem to be confusing NCR with CAR.
Labels that do not conform to your acceptance criteria (and your customer’s acceptance criteria) must be controlled as nonconforming product and dispositioned using your NCR (nonconforming product report).
Deciding when to invest in removing the root causes of these nonconformities from your system is based on the expected return on investment using your CAR (corrective action request).
Kindly clarify so we can help.
M Medical Device Directive - Seeking common nonconformance write up scenarios CE Marking (Conformité Européene) / CB Scheme 2
A What ISO 9001:2015 clause could be used to write nonconformance for not updating licensed driver list? General Auditing Discussions 8
M How to write a Nonconformance Report ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
L Is it required to write a formal corrective action on any nonconformance? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 29
K Looking for guidance to write an SOP on Statistical Methodologies? Statistical Analysis Tools, Techniques and SPC 7
A Document Change Notice vs complete System re-write Manufacturing and Related Processes 4
K PQ validation qualification - Asked to write a PQ protocol ISO 13485:2016 - Medical Device Quality Management Systems 6
L How to write a proper defect description in a NCR Nonconformance and Corrective Action 4
D Validation of existing equipment - I have been asked to write a quality assessment for equipment ISO 13485:2016 - Medical Device Quality Management Systems 13
N How to Write and Compile a Technical File for CE Marking CE Marking (Conformité Européene) / CB Scheme 4
qualprod Write down same nonconformity in several processes? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
GStough Have You Had to Write a NC Against a Quality Manual in a Supplier Audit? General Auditing Discussions 12
D What is the appropriate way to write a conclusion from a % contribution result? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
M Who should write Departmental Work Instructions Document Control Systems, Procedures, Forms and Templates 6
L Requirement to write a Detailed Inspection Plan (DIP) APQP and PPAP 6
E How to write requirements for Medical App Validation and Verification IEC 62366 - Medical Device Usability Engineering 7
Z What to write on A3 Methodology Recognition Certificates? Six Sigma 2
T SOP for How to Write a Specification for Raw Materials and Finished Good ISO 13485:2016 - Medical Device Quality Management Systems 3
alonFAI Update an existing QMS manual or write a new one for AS9100C Certification? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
E How to write a Project Plan to Overhaul our QMS ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
C How to write a Post Market Surveillance REPORT (not procedure) EU Medical Device Regulations 4
E How to write an Aseptic Media Fill Validation Document Other US Medical Device Regulations 2
Q Who must write Quality Manual as per ISO 9001 Clause 5.5.2? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 23
J Can An External Auditor Also Write The Same Non-Conformance As An Internal Auditor? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
C How to Write Procedures without too many Details ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
B How do I tell my boss to write neatly without offending her? Career and Occupation Discussions 8
W How to write an EASA 145 Quality Manual EASA and JAA Aviation Standards and Requirements 3
N Do I Need to Write a CAR for..... (All Opinions Wanted :) ) ISO 13485:2016 - Medical Device Quality Management Systems 7
B I'm trying to write detailed Customer Service Work Instructions Customer Complaints 10
T How do I control web-based asp forms/rpts that write to and pull from an Access DB Document Control Systems, Procedures, Forms and Templates 4
P Internal Audit Corrective Actions - Can a CB write an NC on an in-process CA? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 27
J How to Write the Planned Interval to Conduct Internal Audit, Management Review, etc.. ISO 13485:2016 - Medical Device Quality Management Systems 3
A How to write a US FDA proof MDR procedure? Other US Medical Device Regulations 5
Y New Guidance for the Industry - How to write a Request for Designation (RFD) US Food and Drug Administration (FDA) 0
Q How to write Statement of Purpose for a Law School Admission Career and Occupation Discussions 9
K How to Write a User's Manual for Peachtree - Seeking help Document Control Systems, Procedures, Forms and Templates 4
K ISO 22000 requirement to write a Food Safety Manual Food Safety - ISO 22000, HACCP (21 CFR 120) 2
E How to write a Validation Risk Management Plan for Equipment ISO 14971 - Medical Device Risk Management 5
A How to write Quality Manual? Point to consider Quality Management System (QMS) Manuals 2
S How to write a Prerequisite Program (PRP) for food industry ? Food Safety - ISO 22000, HACCP (21 CFR 120) 14
B How to write a SOP for a Medical Device Document Control Systems, Procedures, Forms and Templates 4
E Software to Write and Control Work Instructions? Document Control Systems, Procedures, Forms and Templates 7
A How to write quality policy? Basics of Quality policy ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
M How to write the Essential Requirements EU Medical Device Regulations 14
R How to write a Capacity Plan Quality Manager and Management Related Issues 2
N Four CMMs and would like to write programs for intermediate checks General Measurement Device and Calibration Topics 5
A How to write a Quality Policy Statement Quality Manager and Management Related Issues 11
Jen Kirley How does a Demingite write a good self evaluation? Career and Occupation Discussions 5
E Starting to write a Quality System Manual - Import/export medical devices - Need help ISO 13485:2016 - Medical Device Quality Management Systems 1
L How to write Executive Summary for Health Canada medical device applications Canada Medical Device Regulations 4
