You seem to be confusing NCR with CAR.
Labels that do not conform to your acceptance criteria (and your customer’s acceptance criteria) must be controlled as nonconforming product and dispositioned using your NCR (nonconforming product report).
Deciding when to invest in removing the root causes of these nonconformities from your system is based on the expected return on investment using your CAR (corrective action request).
Kindly clarify so we can help.
Maybe I have not explained in the right manner.
About this, ok, when labels are found in nonconformance, are controlled and dispositioned, but in this sense,
they are separated and repaired or scrapped but they are not documented when few pieces were resulted with nonconformity.
For example in this case, production are 100,000 labels, and 20 were found, I don´t think is worth the time spent in documenting these cases.
Moreover, my customer accepts me 2% of bad product (2000) ,in this case, other reason for not to be documented.
when I say not documented is, not NCR was risen, nor a CAR, just the case is registered in the log file.
Ok right, if A ncr was risen, because it was found great quantity of nonconformance product, from here a correction
or full analysis is done to find root causes.
Concluding, I don´t see the need to raise NCR for all the cases regardless the quantity found in nonconformance.
and that is the reason I´m looking for a criteria to be established.
Thanks , Hope is clear, sorry for my english.
P.S. Anyway, I log all cases in a spreadsheet.
Afterwards, I´ll analyze such information in order to detect improvements.
