When will Revision 5 of the AIAG FMEA Manual be released?
Emmyd
#91
I'm not ready to reinvent the wheel just yet, mine is rolling just fine at the moment. I'd love to see some clarification on this.
According to the webinar, existing FMEA's will not have to be updated to the new standard. Official rollout for the new FMEA's to be required by customers is still pending. The OEM's are supposed to be letting the auditors know a date to start auditing to the new FMEA in October. Until then, the new FMEA's are to be used by request from your customers. Training on the transition is supposed to start being offered in July.
Hope this helps!
#92
Re: Trainer Bob Right off the bat I noticed that the handbook allows previous 4th Edition formats to be used and recommends new products use the new format. I think that will put alot of people at ease a little longer.
#93
There are a couple things that I quite like about the new handboook:
1. Breaking down the system or process into its components or steps
2. Explicit address of the analysis scope up-front
3. Action priority being used as a risk metric instead of RPN
But it also seems like a pretty significant change if you're just using an Excel sheet. It also seems that some of the suggested tools for structure analysis, function analysis and failure analysis are not very well-described, so I'm curious if that is to leave room for interpretation or if there's additional clarification we'll need at some point on that front.
What are your biggest concerns after reading the handbook?
SQ_Joe
#94
There are a couple things that I quite like about the new handbook:
<<JMA - Absolutely! We have known for a very long time that RPN was useless. AP is a good start, but they made it a "stop light" control. Only 3 categories, R. Y, & G. There should be 5 categories for finer distinction between desired actions.>>
<<JMA - Yes and no. If you were building proper FMEAs in a V model fashion, There is nothing new.
Excel will still work easily. You have to think in terms of storing "Knowledge/Lessons-Learned modules for the focus element.
The new form is still built to "push down" actions, yet does not have good hooks (fields / columns) to "pull up" information which would enrich management's understanding and response actions. (Sensi, not beat down).
There are commercial MS Excel FMEA workbooks available today. They have built in methods for the AIAG-VDA approach.
Examine the one at FMEA Template - FMEA tools for Failure Mode Effects Analysis It can handle the FMEAs and their module linking.>>
<<JMA - It is well defined. Look at YOUR TEAM'S focus element only and you will see Rev. 4 structure.
YOUR TEAM will identify potential causes which are failures modes for the "lower level components" you use to build YOUR TEAM'S output (that which is within YOUR boundary). This process was completed by the "higher level systems team" and requirements to prevent failures and their modes where passed down to YOUR TEAM.
The higher level team does their work and passes down requirements to prevent failures and their modes
You take these "requirements to prevent failures and their modes" and determine how what within your boundary causes the effect.
Then you pass to other boundaries what "requirements to prevent failures and their modes" they are responsible to analyze. This is the data YOUR TEAM places in the Lower Element columns.
Basically, outside RPM to AP, YOUR Team still performs analysis in the same way. The form change is to force YOUR TEAM to recognize the "requirements to prevent failures and their modes" of the higher level boundary within which you are a piece of and to pass down "requirements to prevent failures and their modes" to "boundaries / groups" you are responsible.
The boundary diagram examples in the new manual are still misleading. Main issue: they show completed diagrams which can only be drawn at the conclusion of all of the FMEA processes - bottom to top. They are history starting points for future programs. >>
<<JMA - It was written again by high level OEM and Tier 1 management who got the job because they had the time. I.e.: They do not manage engineering groups who produce products and, therefore, out of the latest knowlwdge loop as to how data and information flows up and down the product chain.>>
S Pre-release version of the upcoming AIAG FMEA Revision 5 FMEA and Control Plans 1
B What is the Latest Revision Of the AIAG PPAP Manual? APQP and PPAP 1
O AIAG Manual Master List with Current Revision Level IATF 16949 - Automotive Quality Systems Standard 2
S AIAG working on PPAP 4th Edition? Revision status of AIAG documents APQP and PPAP 8
M Is There a Revision History or Change Log for Canadian Regulations? Canada Medical Device Regulations 3
C SOP unification. Revision No, Revision history Document Control Systems, Procedures, Forms and Templates 4
I Dating controlled documents after changes - Revision History Document Control Systems, Procedures, Forms and Templates 13
I Revision History Date - date of updates or date of release? ISO 13485:2016 - Medical Device Quality Management Systems 2
J ISO 14001 revision process ISO 14001:2015 Specific Discussions 1
B CQI-11 (Plating Audit) - New revision updates IATF 16949 - Automotive Quality Systems Standard 0
P Proposed revision of IEC 62304 - 2019 IEC 62304 - Medical Device Software Life Cycle Processes 6
I Tracking Protoype Changes; 8D or simple document revision? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
A The latest revision number and changes in automotive core tools IATF 16949 - Automotive Quality Systems Standard 1
L Getting Notice of Revision and Accessing Public Draft Copies of ISO Standards Service Industry Specific Topics 2
A Domain of the component (EASA CM No.: CM-SWCEH-001 Issue 01 Revision 02) Point 9.3.3 (Usage domain aspects) EASA and JAA Aviation Standards and Requirements 0
M Informational ISO 14971 / ISO TR 24971 revision update – atualizações sobre a revisão Medical Device and FDA Regulations and Standards News 1
M Document Control - Revision Number in Document Names Document Control Systems, Procedures, Forms and Templates 4
L VDA 1 Documented Information and Retention (new revision 4, August 2018) VDA Standards - Germany's Automotive Standards 0
M Informational ISO TC 210 JWG 1 meeting in São Paulo – Revision of ISO 14971 and ISO TR 24971 – Medical Device Risk Management Medical Device and FDA Regulations and Standards News 0
M Revision of a Form which is a Procedure Attachment Document Control Systems, Procedures, Forms and Templates 1
S IMS Manual Review and Revision Prior to Audit ISO 14001:2015 Specific Discussions 4
2 First Article Requirements for Revision Changes of Engineering AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 0
ScottK Question for Auditors on 7.1.4 in the ISO9001:2015 revision ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
C Document Control - old revision vs new revision Document Control Systems, Procedures, Forms and Templates 22
R Clinical evaluation Meddev (2.7.1 revision 4) - Example or Template EU Medical Device Regulations 4
Paul Simpson Informational The role of Annex SL - High Level Structure of ISO MSS's - Revision Update February 2019 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 26
T ISO 9004:2018 Revision - Released April 2018 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
Brizilla Knowledge of the upcoming ISO 17025 Revision ISO 17025 related Discussions 5
Q Change revision number in document when only codification was changed Document Control Systems, Procedures, Forms and Templates 8
Sam Lazzara Preferred Location for Revision History Section in Documents Document Control Systems, Procedures, Forms and Templates 16
J Is there a specification that provides directions on Drawing Revision Changes Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
L Supplier Revision Confirmation of Received Engineering Documents ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
M ISO 14971 and ISO TR 24971 revision ISO 14971 - Medical Device Risk Management 32
Q AS9100 Re-certification Audit - Which Revision? AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 3
M Proposed System: Revision = Modification Date; Approval = Access Permissions Document Control Systems, Procedures, Forms and Templates 1
Q Objective and Goals - ISO 9001:2008 Frequency Revision Requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
M ISO 14971:2007 Revision Approved - The Delft ISO TC 210 plenary meeting - Nov 2016 ISO 14971 - Medical Device Risk Management 2
N Transition Audits - AS9100 Revision D AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 26
P Is the next revision of ISO 15378 following the High Level Structure? Other ISO and International Standards and European Regulations 5
M Future of ISO 14971 - Possible revision? ISO 14971 - Medical Device Risk Management 9
L The ink is dry(ing) on the revision of ISO 14001:2015. “Is the payoff worth the price Imported Legacy Blogs 0
A Post-market Clinical Studies of Orthopaedic (Revision) Implants EU Medical Device Regulations 1
M Where does Document Revision Control Start? Rev 0 or Rev 1 Document Control Systems, Procedures, Forms and Templates 19
I Document Control - Document Revision History Question Document Control Systems, Procedures, Forms and Templates 16
T Is there a requirement in TS16949 that PO's show a revision level? IATF 16949 - Automotive Quality Systems Standard 3
O Regulatory Notification for IVD IFU Instructions Revision ISO 13485:2016 - Medical Device Quality Management Systems 3
M Is explicit revision control needed if handled automatically by software? Document Control Systems, Procedures, Forms and Templates 6
Marc Interview with Marek Bidwell about the revision to ISO14001 ISO 14001:2015 Specific Discussions 0
M Automated Revision Updates - Notifications of new revisions for ISO's to subscribers Document Control Systems, Procedures, Forms and Templates 2
J Questionable Audit Finding about Revision Levels of Product Manual CD's ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
