Where are the rules for when a repeat minor nonconformance becomes a major?
Rameshwar25
#21
This is another time where I don't have the text so it would be good to know what "rule book" is being referred to, what 5.11.5 in it says, and to have example(s) of what the minor nonconformances are.
Dear Marc,
Following text is is part of clause 5.11.5
" In cases where the accepted corrective action plan for a minor nonconformity is found to be not effectively implemented, a new major nonconformity shall be issued against the corrective action process (see IATF 16949, section 10.2) and the previous minor nonconformity reissued as a major nonconformity."
There are two parts of this paragraph which require for two major NCs
1. a new major nonconformity shall be issued against the corrective action process.​
2. the previous minor nonconformity reissued as a major nonconformity.​
regards
rameshwar
Rameshwar25
#23
No Marc,
the discussion was started with an event when auditor converted a previous year's minor NC into major next year when submitted corrective actions were not effectively implemented throughout the year. The initiator of post wanted to know the rule against which it was converted.
The answer to this situation is in clause 5.11.5 only and nowhere else.
Marc
#24
@Rameshwar25 - What is the definition of "similar"? 5.11.5 addresses a specific identified nonconformance the corrective action for which "... isn't effectively implemented" which is an easy call to make.
Rameshwar25
#25
I want to explain with an example.
Two vernier calipers (VC-01 and VC-02) out of 20 are found uncalibrated in an audit. Getting them calibrated is only correction. after root cause determination, corrective action should be to prevent recurrence of such situation. The corrective action will not only cover these two vernier calipers but all instruments which needs calibration.
if any other instrument, apart from these two, is found uncalibrated in next audit, it will be considered SIMILAR minor nonconformity and will be considered failure to effectively implementing the corrective actions. The previous year's NC will be converted into major.
#27
Rameshwar - great example. This happened to an organization. However, with over 400 items of equipment and ZERO impact on product quality, I fail to see how 1) it's a complete breakdown and 2) it didn't result in any non-conforming product being made or shipped.
The rule is highly suspect, IMHO.
Rameshwar25
#28
Dear Andy, See below:
"Major nonconformity is one or more of the following:
01.The absence of or total breakdown of a system to meet an IATF 16949 requirement. A number of minor nonconformities against one requirement can represent a total breakdown of the system and thus be considered a major nonconformity.
02. Any noncompliance that would result in the probable shipment of nonconforming product. A condition that may result in the failure or materially reduce the usability of the products or services for their intended purpose.
03. A noncompliance that judgment and experience indicate is likely either to result in the failure of the quality management system or to materially reduce its ability to ensure controlled processes and products."
Complete breakdown, as you mentioned in your post, is not only one reason. There are other reasons also. If previous year, there were two instruments found calibrated. This year, other three found uncalibrated. What does it indicate? where are we going? The entire calibration calibration is likely to fail in future. and it becomes basis for a major NC. Pl read point No. 02 and 03 above.
And above all, we are not in capacity of challenging Rulebook. Sometimes, auditor, unwillingly, raises NC because of requirement of standard and rule.
Golfman25
#29
The rule is BS. As the calibration examples point out, you could have a no harm, no foul situation that suddenly becomes a major. Complete nonsense. But the rule was added because of issues they where having -- typical bureaucratic response.
Consider the situation where several years ago you filled out a FEMA form "wrong" by not having a date. You made the correction, and learned your "lesson" but who knows how many other old forms might be missing a date. Welcome to two majors. It's nuts.
Sidney Vianna
Post Responsibly
#30
The people who establish these rules don’t have to deal with the outcome and consequences of their decisions, unfortunately, and they believe that such rules will prevent soft grading of nonconformities. It seems to me that the IATF rule was copied from the IAQG Scheme, and, as I said earlier, in the aerospace sector, this rule was developed to placate regulators.
When they created the rule and submitted the draft of AS9101 for review, I was a member of the Americas Aerospace Quality Standard Committee and expressed my concern. We have threads here at The Cove about that circa 2011.
A much better rule would force lead auditors to justify in the report why similar nonconformities in consecutive audits do not represent a failure of the organization’s corrective action process. By forcing the auditor to justify their position, it would give the CB and the registrant a way out of an automatic major NC when and if the evidence and rationale justifies it. Everything is supposed to be processed via a risk-based line of thought. Why not in this case?
M Testing criteria - where to place Design and Development of Products and Processes 1
J UDI - Where to document it? EU Medical Device Regulations 8
J Where to get a Black belt certification ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 13
D Any recommendations on where to find experienced quality hires in Chicago area? Job Openings, Consulting and Employment Opportunities 3
J Where is the definition of a critical supplier? ISO 13485:2016 - Medical Device Quality Management Systems 5
W Where does a coatings and paint company fall in IATF? IATF 16949 - Automotive Quality Systems Standard 5
B When Travel is allowed - Where are you going? Travel - Hotels, Motels, Planes and Trains 16
G Where to buy Template / sample SCSMS Manual, checklist Supply Chain Security Management Systems 1
M Quality Manual - Where does Revision History Section go? Document Control Systems, Procedures, Forms and Templates 8
C Where to draw the line for "sufficient evidence" to verify safety/performance of a device? CE Marking (Conformité Européene) / CB Scheme 2
L Where to place the what/when/how/who/where procedures in a multi-regulation AS9110C organisation AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
B Where to acquire EN 868-5 required dye (Amaranth red)? Other Medical Device Related Standards 2
N Where to find Regulations for Reprocessing and Reuse of Single-Use Devices Other Medical Device Related Standards 2
H Where to get EK MED 1927/16 Other Medical Device Regulations World-Wide 3
D Where to find Guidance Class II Amendment Canada Medical Device Regulations 1
O EN 301 489-1 and EN 301 489-17 - Where do we get the information of the Published versions? CE Marking (Conformité Européene) / CB Scheme 1
A AS9100 Training - Where do I start? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 14
qualprod Records where apply and stop recording everything? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
C Where to place CE/label in Sterile IVD EU Medical Device Regulations 1
G New to ISO 9001 - Where to begin? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
BeaBea Interesting Discussion Where Does Marketing/ Advertisement of Products fit in to ISO 9001? Process Maps, Process Mapping and Turtle Diagrams 39
K No IFU, where the requirements would go? EU Medical Device Regulations 5
T Assessing Hazard-Related Use Scenarios where control measures exist through standards IEC 62366 - Medical Device Usability Engineering 32
J Where to Place Process Maps in our Documentation? Process Maps, Process Mapping and Turtle Diagrams 4
GreatNate Where to get a KPI dashboard for QMS processes Quality Tools, Improvement and Analysis 5
A Implementing ISO 20000-1 - Where to start Other ISO and International Standards and European Regulations 2
D Where does "as far as possible" stop? FMEA - EN 14971 ISO 14971 - Medical Device Risk Management 29
qualprod Statistics - Where to start in ISO 9001? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
H Calibration of InfraRan Vapor Analyzer - where to get calibration for SF6 General Measurement Device and Calibration Topics 2
M Where can I find examples of PPAP? APQP and PPAP 6
A What if Contract Manufacturers does not have an ISO 13485 certificate? Where will the NB audit take place, at legal mfg. site or contract mfg. site? Other Medical Device Regulations World-Wide 3
J Where can I find the latest update to Reach and ROHS? REACH and RoHS Conversations 9
D Where (in US) can I get the VDA Auditor Edition book? VDA Standards - Germany's Automotive Standards 3
S Where to get online AS standard audit certification classes? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
J Where I can get a copy of either the 3rd or 4th edition of UL544? Other Medical Device Regulations World-Wide 7
G Where to find Proficiency Test provider for photometrics (spectral %R, %T, photo density) General Measurement Device and Calibration Topics 9
Marc Quiz - Where did the idea of an assembly line come from? Coffee Break and Water Cooler Discussions 4
F Quality Objectives - Where in the QMS Quality Objectives should be located ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
M Where to obtain a calibrated DICOM image? ISO 13485:2016 - Medical Device Quality Management Systems 1
R Where to get information - M6 per WA900 Manufacturing and Related Processes 1
S Where did FDA 510(K) form 3654 go? Other US Medical Device Regulations 4
W Where to begin with an ISO 9001:2015 internal audit Internal Auditing 13
D China - Where I can get NMPA complete structure/organogram chart and GB/YY format list China Medical Device Regulations 1
D Where does FMEA fit in your ISO 14971 Risk Management process? ISO 14971 - Medical Device Risk Management 13
CCaantley Where to get a good test indicator stand for a granite surface plate General Measurement Device and Calibration Topics 8
