Where did "breakpoint" analysis come from? AIAG MSA book
mwohlg
Hi all,
I've done some searching in the forums for information about the RPN breakpoint calculations, the section of the (somewhat common) GR&R form that evaluates whether the gage system is acceptable for use when the R&R is between 10% & 30%. I'm asking because no calculation like this is in the AIAG MSA book, it only says "may be acceptable based upon importance of application, cost of measurement device, cost of repair, etc." (page 77 MSA 3rd edition). So far I've only found one poster who attributed the breakpoint calculations to Delphi. Does anyone know anything else about this?
If you're curious, I've got a caliper being used for some part quality inspections with a GR&R of 11.73% and a breakpoint of 9.39, well below the cutoff of 37.8, but my customer won't accept without an improvement plan for the gage.
Thanks,
Mike
Stijloor
Hi all,
Thanks,
Mike
Can anybody help?
Thank you!
Hi all,
Thanks,
Mike
What is the "breakpoint" you're referring to? What do the 9.39 and 37.8 numbers mean?
mwohlg
In one of the Gage R&R forms that seems to be pretty commonly used here in the Cove, there is a section that calculates a "breakpoint". If the GR&R is more than 10% but less than 30%, the gage would be considered acceptable if the breakpoint is less than 37.8. The breakpoint is the RPN (from the PFMEA) for the characteristic in question times the GRR.
In my situation our GRR is 0.1173 (11.73%) and the RPN is 80, so the breakpoint is 9.39, well below the limit of 37.8.
I've never seen that breakpoint thing being used, and using the RPN from the PFMEA as a multiplier doesn't make much sense to me. It's a misguided attempt to quantify something that probably can't be quantified in a meaningful way. Unfortunately, there are customers who believe that the AIAG acceptability breakdown is inviolable scripture when in fact it's mostly arbitrary and of uncertain provenance. The best thing you can do is rationally explain to the customer that whatever risk there is in using the gage/measurement system is made negligible in terms of what would be required to improve it.
I remember seeing it once here in the forums, but had never seen it used then or later. I also am very suspicious of a method based on RPN numbers because the RPN numbers depend on the scales used, the interpretation of each scale by the users etc. The absolute value of an RPN is not important. It is only used to rank and prioritize improvement efforts.
E
equesnel
Agreed..I would suggest sticking to a know standard and accepted approach to assessing the GR&R of your gauge.
The AIAG-Manual is very good at giving required forumulas and techniques.
I would use RPN for PFMEAs only and would wonder why there is a need to complicate an already approved and accepted method for GR&R calculation???
Just my 2 Cents worth.
Eric
Marc Quiz - Where did the idea of an assembly line come from? Coffee Break and Water Cooler Discussions 4
S Where did FDA 510(K) form 3654 go? Other US Medical Device Regulations 4
Hershal Travel! Where have you been of late? What did you see? What do you think? Travel - Hotels, Motels, Planes and Trains 15
Q AS9100B Clause 7.5.1.5 - Where did it go in AS9100C? Servicing/Post Delivery Support AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
L Where did the name Elsmar come from? Coffee Break and Water Cooler Discussions 17
D TS 16949 - Where did the 16949 come from? IATF 16949 - Automotive Quality Systems Standard 4
M Where did 4.10.2.3 - Positive Recall - At Risk - go? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
D Where Did the Number 16949 Come From? IATF 16949 - Automotive Quality Systems Standard 2
G History of TQM? Where did Total Quality Management come from? Preventive Action and Continuous Improvement 18
J UDI - Where to document it? EU Medical Device Regulations 8
J Where to get a Black belt certification ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 13
D Any recommendations on where to find experienced quality hires in Chicago area? Job Openings, Consulting and Employment Opportunities 3
J Where is the definition of a critical supplier? ISO 13485:2016 - Medical Device Quality Management Systems 5
W Where does a coatings and paint company fall in IATF? IATF 16949 - Automotive Quality Systems Standard 5
B When Travel is allowed - Where are you going? Travel - Hotels, Motels, Planes and Trains 16
G Where to buy Template / sample SCSMS Manual, checklist Supply Chain Security Management Systems 1
M Quality Manual - Where does Revision History Section go? Document Control Systems, Procedures, Forms and Templates 8
C Where to draw the line for "sufficient evidence" to verify safety/performance of a device? CE Marking (Conformité Européene) / CB Scheme 2
L Where to place the what/when/how/who/where procedures in a multi-regulation AS9110C organisation AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
B Where to acquire EN 868-5 required dye (Amaranth red)? Other Medical Device Related Standards 2
N Where to find Regulations for Reprocessing and Reuse of Single-Use Devices Other Medical Device Related Standards 2
H Where to get EK MED 1927/16 Other Medical Device Regulations World-Wide 3
D Where to find Guidance Class II Amendment Canada Medical Device Regulations 1
O EN 301 489-1 and EN 301 489-17 - Where do we get the information of the Published versions? CE Marking (Conformité Européene) / CB Scheme 1
A AS9100 Training - Where do I start? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 14
qualprod Records where apply and stop recording everything? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
C Where to place CE/label in Sterile IVD EU Medical Device Regulations 1
G New to ISO 9001 - Where to begin? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
BeaBea Interesting Discussion Where Does Marketing/ Advertisement of Products fit in to ISO 9001? Process Maps, Process Mapping and Turtle Diagrams 39
K No IFU, where the requirements would go? EU Medical Device Regulations 5
T Assessing Hazard-Related Use Scenarios where control measures exist through standards IEC 62366 - Medical Device Usability Engineering 32
J Where to Place Process Maps in our Documentation? Process Maps, Process Mapping and Turtle Diagrams 4
GreatNate Where to get a KPI dashboard for QMS processes Quality Tools, Improvement and Analysis 5
A Implementing ISO 20000-1 - Where to start Other ISO and International Standards and European Regulations 2
D Where does "as far as possible" stop? FMEA - EN 14971 ISO 14971 - Medical Device Risk Management 29
qualprod Statistics - Where to start in ISO 9001? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
H Calibration of InfraRan Vapor Analyzer - where to get calibration for SF6 General Measurement Device and Calibration Topics 2
M Where can I find examples of PPAP? APQP and PPAP 6
A What if Contract Manufacturers does not have an ISO 13485 certificate? Where will the NB audit take place, at legal mfg. site or contract mfg. site? Other Medical Device Regulations World-Wide 3
J Where can I find the latest update to Reach and ROHS? REACH and RoHS Conversations 9
D Where (in US) can I get the VDA Auditor Edition book? VDA Standards - Germany's Automotive Standards 3
S Where to get online AS standard audit certification classes? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
J Where I can get a copy of either the 3rd or 4th edition of UL544? Other Medical Device Regulations World-Wide 7
G Where to find Proficiency Test provider for photometrics (spectral %R, %T, photo density) General Measurement Device and Calibration Topics 9
F Quality Objectives - Where in the QMS Quality Objectives should be located ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
