Where does a coatings and paint company fall in IATF?
...And is being compliant to IATF enough.
We're a toll manufacturer and have an ISO9001 accreditation, with one of our labs having an ISO/IEC 17025 accreditation as well. We don't exclusively supply to the automotive industry, but some of our customers are from there. I think we only do coatings for wheels, but I have to double check that.
My question would be, would I be able to provide a sufficient argument that our ISO9001 cert and compliance to IATF (perhaps referencing the MAQMSR document) is enough as a paint and coatings company, or will we have to be certified to IATF?
I'm having trouble understanding section 8.4.2.3 Supplier quality management system development (sanctioned interpretation), specifically what an eligible organization is.
Excuse my ignorance, I just started this career about 2 months ago and for some reason they thought it was a good idea to hire someone with no experience in the field to "train from the bottom up" to figure out IATF 16949 (not that I don't appreciate the opportunity to learn, it's just a lot to take in and I have no one to guide me).
Thank you!
Howard Atkins
Forum Administrator
Eligible organisation from the rules
1-0 ELIGIBILITY FOR CERTIFICATION TO IATF16949
IATF 16949 defines the quality management system requirements for a client providing design and development, production and, when relevant, assembly, installation, and services {see the definition of “Manufacturing” below for the list of services} of automotive-related products.
“Client" shall be understood as the entire entity {including all related manufacturing sites and remote supporting locations} applying for IATF 16949 certitication-
IATF 16949 is applicable to all sites of a client where customer-specified production parts, service parts, and/or accessory parts are manufactured.
“Customer-specified production parts" shall be understood as parts that are an integral part of a vehicle. The only customer-specified parts that do not meet this requirement but are to be included are the following: fire extinguisher, carjacks, and floor mats, owner’s manuals, and warning
triangles- See additions from Rules SI
“Site” shall be understood as the location at which value-added manufacturing processes occur (see IATF 16949 section 3.1 )-A site may also include more than one {1} address {see Annex 4}-
Fabless sites and sites making only non-automotive related products are not eligible for IATF 16949 certification {see section 15-0}.
Note: A client performing value-added activities on their customer's premises can be considered as a remote support location of a site but is not eligible for a stand-alone certification- The function would be identified as "service" on the IATF certificate-
“Manufacturing" shall be understood as “the process of making or fabricating production materials, production of service parts, assemblies, or heat treating, welding, painting, plating, or other finishing services of automotive-related parts" (see IATF 16949, section 3.1).
Your explanation in my mind meets the standard as for development
as it states
suppliers of automotive products and services to develop, implement, and improve a quality management system (QMS) with the ultimate objective of eligible organisations becoming certified to this Automotive QMS Standard. Using a risk-based model, the organization shall define a minimum acceptable level of QMS development and a target QMS development level for each supplier.
a QMS certified to ISO 9001 is the initial minimum acceptable level of development. Based on current performance and the potential risk to the customer, the objective is to move suppliers through the following QMS development progression: YOU HAVE
c) certification to ISO 9091 with compliance to other customer-defined QMS requirements (such as Minimum Automotive Quality Management System Requirements for Sub-Tier Suppliers (MAQMSR) or equivalent) through second-party audits; YOU DISCUSS THIS
The point is Using a risk-based model, the organization shall define a minimum acceptable level of QMS development and a target QMS development level for each supplier.
Your customer needs to see define the risk and make his judgment on the level he wants from you.
To often there is an across the board requirement for ail suppliers to be IATF as it saves trouble and keeps the auditor happy. I see no problem for you
lyuluck
If the service amount is small, Maybe you can ask your automotive customer to get an processing authorization documents that involved in IATF. If you want to expand your spraying business, or step in auto parts business, it is better to have a IATF certification.
Howard Atkins
Forum Administrator
I disagree unless there is a customer requirement the status explained by Whiskey is sufficient to meet the requirements of his automotive customers.
As I said before
To often there is an across the board requirement for all suppliers to be IATF as it saves trouble and keeps the auditor happy.
The external auditor asks what are you doing for supplier developments and the auditee shows a letter saying all suppliers MUST be IATF.. I have encountered situations with certain commodities that GM and VW have not required IATF but some company buying once a year a small amount required it.
If you want to be IATF OK but it seems to me that from your point of view MAQMSR is the best way to go especially as I assume that you will have to certify all the plant just for a couple of orders.
As I said before
I thought so, thank you for your thorough replies, I really appreciate it.
I was looking through the supplier requirement manuals of our customers and they use the terms "comply" or "compliance" when referring to IATF, but in the e-mail discussions I dug up with the Emergency Managers before me they seem to push for certification. It looks like my predecessors didn't question why we can't just be compliant if that's their own wording and pull up these documents as proof.
M Quality Manual - Where does Revision History Section go? Document Control Systems, Procedures, Forms and Templates 8
BeaBea Interesting Discussion Where Does Marketing/ Advertisement of Products fit in to ISO 9001? Process Maps, Process Mapping and Turtle Diagrams 39
D Where does "as far as possible" stop? FMEA - EN 14971 ISO 14971 - Medical Device Risk Management 29
A What if Contract Manufacturers does not have an ISO 13485 certificate? Where will the NB audit take place, at legal mfg. site or contract mfg. site? Other Medical Device Regulations World-Wide 3
D Where does FMEA fit in your ISO 14971 Risk Management process? ISO 14971 - Medical Device Risk Management 13
P Warning Letter 1999 - Where does the FDA make older warning letters available? US Food and Drug Administration (FDA) 4
M Where does our regulatory responsibility end? ISO 13485:2016 - Medical Device Quality Management Systems 11
K Where does the FDA post its various compliance dates? US Food and Drug Administration (FDA) 2
C Where does Quality Authority come from? Career and Occupation Discussions 4
J Where does process validation fit within design & development? Design and Development of Products and Processes 7
Q When does the FDA deem something "where appropriate"? 21CFR820.30(g) 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 11
M Where does Document Revision Control Start? Rev 0 or Rev 1 Document Control Systems, Procedures, Forms and Templates 21
D Where does the QMS (Quality Management System) fit in your organization? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
Q Where does 5S technique fit into ISO 9001? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
M Where does OEE (Overall Equipment Effectiveness) belong? Quality Tools, Improvement and Analysis 11
F Where does Contact begin for Biocompatability? EU Medical Device Regulations 5
somashekar Where does RoHS stuff get audited by CB's? Quality Manager and Management Related Issues 3
S IEC 60601-1 3rd Gap analysis template TO BUY - Does anyone know where? IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
R Where does 20% Lot Qualification Rule Come from? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
G Customer Property Cl. 7.5.4 - Where does ISO 9001 stop and ISO 27001 start? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 33
R Where does the definition of ME (Medical Electrical) Equipment originate? IEC 60601 - Medical Electrical Equipment Safety Standards Series 7
J Quality Organization - Does it matter where it reports to? Other US Medical Device Regulations 13
I Where does it state Supplier Corrective Action is required? Supplier Quality Assurance and other Supplier Issues 5
J Where does Lean Six Sigma Originate? Six Sigma 5
G 12 or 13 Men - Where does the extra man come from? Brain Teasers and Puzzles 5
S Where does least significant digit come into play? Measurement Uncertainty (MU) 8
T Organizational Charts - Where does the Quality Assurance Manager fit in Quality Manager and Management Related Issues 30
T Does anyone know where I can view Bac5300 Various Other Specifications, Standards, and related Requirements 2
A Where does the Lean Manufacturing philosophy / tool set come from? Lean in Manufacturing and Service Industries 32
H Where does the 16949 number in TS16949 come from? ISO Numbering System IATF 16949 - Automotive Quality Systems Standard 1
Wes Bucey Where does your hospital rank on quality? Hospitals, Clinics & other Health Care Providers 20
J GMP CFR 21 Part 210 or 211 - Where does GMP address Document Control Document Control Systems, Procedures, Forms and Templates 6
A Where does one find the complete list of ISO standards? Book, Video, Blog and Web Site Reviews and Recommendations 1
D Does anyone know where to buy an instant read dosimeter? ISO 13485:2016 - Medical Device Quality Management Systems 10
C What is Money for? Where does Barter come into play? Coffee Break and Water Cooler Discussions 19
E Where Does One Get Customer Specific Requirements? Customer and Company Specific Requirements 26
CarolX Where does Quality begin? Philosophy, Gurus, Innovation and Evolution 36
M Research and Development Process - Where does research end and development begin? Misc. Quality Assurance and Business Systems Related Topics 15
M Attribute Charting - Where does Cp and Cpk come into the equation? Capability, Accuracy and Stability - Processes, Machines, etc. 5
K Where and How Does Marketing Fit In? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
L Does anyone know where I can get documentation for the PUMA method. General Measurement Device and Calibration Topics 1
E SOP or system Work Instruction? Controlled Document - Where does one draw the line? Document Control Systems, Procedures, Forms and Templates 5
D Number of Distinct Data Categories:nDC: Where does the constant 1.41 come from? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
S Does anyone know where Guide 25/Palcan Training is available? Training - Internal, External, Online and Distance Learning 1
R Internal audit schedules - Where does it say that I need an annual schedule? Internal Auditing 13
Q Where did my Alignment go wrong? MCOSMOS Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
Q Where to place our Safety Program in our QMS? Occupational Health & Safety Management Standards 9
MaHoDie Where to show the Software version IEC 62304 - Medical Device Software Life Cycle Processes 2
E Where can i get latest toyota and honda Supplier Quality Assurance Manual (SQAM) Customer and Company Specific Requirements 3
