Where does FMEA fit in your ISO 14971 Risk Management process?
After reading the FAQ and an article titled "Why FMEA is Not ISO 14971 Risk Management," I get that FMEA is only one tool in the process, but I'm trying to understand where FMEA fits in a typical medical device risk management process, and what additional tasks are needed (and in which order they are performed) in order to comply with ISO14971.
Is anyone willing to share a broad outline of their risk management process, or a template (with specific analyses mentioned) that they would follow to meet the standard's requirements? How does an FMEA performed for risk management purposes differ from a DFMEA performed presumably earlier in the design process in terms of scope and timing?
Thanks in advance.
yodon
The System Hazard Analysis is a top down look and the FMEAs provide bottom-up looks. Depending on the product, we do a variety of FMEAs: use FMEA, software FMEA, design FMEA (and process FMEA). So your design FMEA is one part of the whole risk management process.
yodon
It depends. Certainly the hazard analysis. I've seen Fault Trees used to support the FMEAs.
I see a lot of overlap with Usability Engineering (62366) and a lot of the characterization activities between 14971 and 62366 contribute to the risk analysis. (And if your product has / is software, 62304 requires software-centric risk analysis which also incorporates the SOUP assessment.)
Remember that risk management doesn't stop. You are continually collecting production and post-production data and using that to improve your risk analysis and product.
And, of course, the risk report wraps it all up.
My preference would be to eliminate FMEAs entirely from the 14971 RM process.
First, they do not address the normal condition. Second, it seems they are rarely performed well--compare typical results and online examples (e.g. 'component failure' is listed as a failure mode) to the stipulations of and samples in IEC 60812:2018 or :2006.
However, given their pervasivenss, FMEAs can be useful as a familiar means to associate fault conditions and their consequences.
racglobal
From my experience in two of the companies I've worked at, FMEA is to further break down your hazard analysis. Start with a preliminary hazard analysis (or PHA) to give you a sense of where the hazards are. From there, you do a much more in-depth analysis through an FMEA, to find the causes, the hazardous situations that give rise to the hazards, and the harm. FMEA requires team work and it's better to gather all your design people in one room and brain storm. Finally, for each risk identified, you decide what type of mitigation measure should be conducted. Let me know if this is clear. Anyone else has better suggestions, I would be interested to know.
racglobal
Also, it's important to get the vocabulary right. I have read instances where people do not know the difference between a hazard and a hazardous situation.
I like this discussion as this reflects my experience in that field.
I would agree that the term FMEA should be eliminated in the context of Risk Management. It is often used as a synonym for the risk analysis, however, if the Risk Management File only includes documents like dFMEA, pFMEA, etc. I already would judge that this Risk Management process is not well understood.
The basic principle is that at least two methods should be used (a bottom-up and a top-down method). In practice, you should look from the hazard-perspective (e.g., which hazards are relevant for my product, which hazardous situations could occur) and from the sequence of events perspective (how is the product being used, what can go wrong or what can happen if nothing goes wrong). This would ensure sufficient coverage of the risks.
I agree with what was said about the vocabulary. This is one of the significant issues that the terms hazard, hazardous situation, and harm are not considered when performing the risk analysis.
Even the examples for hazards in the current ISO 14971 are always compatible with the definition. E.g., the hazards related to labeling are from my perspective not in line with the definition. Therefore I am happy that in the 2019 revision this will be fixed.
D Where does "as far as possible" stop? FMEA - EN 14971 ISO 14971 - Medical Device Risk Management 29
W Where does a coatings and paint company fall in IATF? IATF 16949 - Automotive Quality Systems Standard 5
M Quality Manual - Where does Revision History Section go? Document Control Systems, Procedures, Forms and Templates 8
BeaBea Interesting Discussion Where Does Marketing/ Advertisement of Products fit in to ISO 9001? Process Maps, Process Mapping and Turtle Diagrams 39
A What if Contract Manufacturers does not have an ISO 13485 certificate? Where will the NB audit take place, at legal mfg. site or contract mfg. site? Other Medical Device Regulations World-Wide 3
P Warning Letter 1999 - Where does the FDA make older warning letters available? US Food and Drug Administration (FDA) 4
M Where does our regulatory responsibility end? ISO 13485:2016 - Medical Device Quality Management Systems 11
K Where does the FDA post its various compliance dates? US Food and Drug Administration (FDA) 2
C Where does Quality Authority come from? Career and Occupation Discussions 4
J Where does process validation fit within design & development? Design and Development of Products and Processes 7
Q When does the FDA deem something "where appropriate"? 21CFR820.30(g) 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 11
M Where does Document Revision Control Start? Rev 0 or Rev 1 Document Control Systems, Procedures, Forms and Templates 19
D Where does the QMS (Quality Management System) fit in your organization? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
Q Where does 5S technique fit into ISO 9001? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
M Where does OEE (Overall Equipment Effectiveness) belong? Quality Tools, Improvement and Analysis 11
F Where does Contact begin for Biocompatability? EU Medical Device Regulations 5
somashekar Where does RoHS stuff get audited by CB's? Quality Manager and Management Related Issues 3
S IEC 60601-1 3rd Gap analysis template TO BUY - Does anyone know where? IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
R Where does 20% Lot Qualification Rule Come from? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
G Customer Property Cl. 7.5.4 - Where does ISO 9001 stop and ISO 27001 start? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 33
R Where does the definition of ME (Medical Electrical) Equipment originate? IEC 60601 - Medical Electrical Equipment Safety Standards Series 7
J Quality Organization - Does it matter where it reports to? Other US Medical Device Regulations 13
I Where does it state Supplier Corrective Action is required? Supplier Quality Assurance and other Supplier Issues 5
J Where does Lean Six Sigma Originate? Six Sigma 5
G 12 or 13 Men - Where does the extra man come from? Brain Teasers and Puzzles 5
S Where does least significant digit come into play? Measurement Uncertainty (MU) 8
T Organizational Charts - Where does the Quality Assurance Manager fit in Quality Manager and Management Related Issues 30
T Does anyone know where I can view Bac5300 Various Other Specifications, Standards, and related Requirements 2
A Where does the Lean Manufacturing philosophy / tool set come from? Lean in Manufacturing and Service Industries 32
H Where does the 16949 number in TS16949 come from? ISO Numbering System IATF 16949 - Automotive Quality Systems Standard 1
Wes Bucey Where does your hospital rank on quality? Hospitals, Clinics & other Health Care Providers 20
J GMP CFR 21 Part 210 or 211 - Where does GMP address Document Control Document Control Systems, Procedures, Forms and Templates 6
A Where does one find the complete list of ISO standards? Book, Video, Blog and Web Site Reviews and Recommendations 1
D Does anyone know where to buy an instant read dosimeter? ISO 13485:2016 - Medical Device Quality Management Systems 10
C What is Money for? Where does Barter come into play? Coffee Break and Water Cooler Discussions 19
E Where Does One Get Customer Specific Requirements? Customer and Company Specific Requirements 26
CarolX Where does Quality begin? Philosophy, Gurus, Innovation and Evolution 36
M Research and Development Process - Where does research end and development begin? Misc. Quality Assurance and Business Systems Related Topics 15
M Attribute Charting - Where does Cp and Cpk come into the equation? Capability, Accuracy and Stability - Processes, Machines, etc. 5
K Where and How Does Marketing Fit In? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
L Does anyone know where I can get documentation for the PUMA method. General Measurement Device and Calibration Topics 1
E SOP or system Work Instruction? Controlled Document - Where does one draw the line? Document Control Systems, Procedures, Forms and Templates 5
D Number of Distinct Data Categories:nDC: Where does the constant 1.41 come from? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
S Does anyone know where Guide 25/Palcan Training is available? Training - Internal, External, Online and Distance Learning 1
R Internal audit schedules - Where does it say that I need an annual schedule? Internal Auditing 13
J UDI - Where to document it? EU Medical Device Regulations 8
J Where to get a Black belt certification ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 13
D Any recommendations on where to find experienced quality hires in Chicago area? Job Openings, Consulting and Employment Opportunities 3
J Where is the definition of a critical supplier? ISO 13485:2016 - Medical Device Quality Management Systems 5
