Where does the Lean Manufacturing philosophy / tool set come from?
G
gszekely
#21
KANBAN
REPLENISHABLE OR NOT ?
-REPLENISHABLE.
§ Self-Managing, Simple Visual Signals.
§ Frequent Demands.
§ Supported with Calculations.
§ Surfaces and Materials Investment.
-NON-REPLENISHABLE.
§ Infrequent Demands. – With Spikes.
§ High Value justifies Elegant Management.
§ As Complement to Replenishable Kanban to Satisfy an
Abnormal Demand.
§ Temporary Increase of the Daily Rate.
§ Do you estimate the Impact of Daily Change ?
Example:
PLANT A
QTY : 25
ASPIRATION VALVE
18230965-015
PULL FROM : STORE A1
DELIVER TO :LA-OP12
18230829-015
NON-REPLENISHABLE
Does this help ?
BR
György
G
Gilberto - 2009
#22
Kanban, regardless of the method or what it looks like, is simply a mechanism to signal production of a specific part at a specific quantity. It is used to facilitate flow where it couldn't otherwise be achieved. This could be due to the inability to stabilize the cycle times of the various operations, or because the processes are not connected. Think of a customer with their supplier across town, or a milling machine supplying parts to an assembly line on the other side of a 300,000 sq. ft. manufacturing facility.
The production scenarios (from best to worst) are:
1) Flow
2) FIFO Flow
3) Kanban
4) Batch
I can't remember which book/s cited (I'd have to look it up) the practice of "single-use kanban" or "one-time kanban" but if I remember correctly there are two reasons for the use of it:
1) Repetitive orders which have either a long frequency between orders and/or a low order quantity.
2) As a necessary mechanism due to a extreme and unexpected spike in production. I have used this concept in a seasonal environment.
Either way, once the parts are produced and delivered to the required delivery point, the kanban is destroyed or removed from the process.
Wayne
Ok. Excellent
It explained in the practical one what I wanted to say in the theory.:applause:
duecesevenOS - 2009
#23
1) Flow
2) FIFO Flow
3) Kanban
4) Batch
Wayne
Thank you Wayne,
I think I understand the application. It's basically a temporary signal to flow abnormalities. I've never heard this type of kanban described but I think we use it none the less:
The process has one customer that has a fluctuating takt time (they are still stuck on a batch process). When the customer of this particular process doesn't meet weekly demand, they occassionally run an extra half day. When the supplier knows that their customer will be running an extra day, they create a temporary kanban (non-replenishing) that is filled so that the customer can run without the supplier present. After the supplier empties the non-replenishing kanban, it is removed and not resupplied.
So basically the customer let's the supplier know of an unusual demand (signal/kanban) and the supplier fills the demand.
Thanks again.
branham91
#24
You need to read a book called "The Goal". Forgot who wrote it but it is a cheap paperback book. Lean Manufacturing came from Toyota. The head honcho there was grocery shopping one day and marveled at the way inventory was restocked on the shelves. Thus Lean Mfg was born. Basically you have just enough inventory to keep your lines running "Eliminating storage and warehousing". Lean MFG will uncover your process problems because excess inventory hides them. That is the core of lean. Also lean manufacturing means " taking a job that requires 5 people and making due with four" gotta go problem just came up.
W
wmarhel
#25
The author of the "The Goal" is Eliyahu M. Goldratt.
I would argue that "Lean Manufacturing" is a bastardized version of what Toyota did/does. "Lean Manufacturing" makes for a good catch-phrase.
Lean Manufacturing wasn't born out of the grocery store, it makes for a good story, but that is incomplete. The supermarket provided the spark for the concept of JIT (Just-in-Time). JIT is just one of the two pillars that the The Toyota Production System is built upon.
Ohno is largely credited with the material flow/JIT aspect of the Toyota system, but Shigeo Shingo was really the thought leader behind the rest. Keep in mind that Ohno himself believed calling it a production system was incorrect. He believed it should have been called the Toyota Management System.
Kanban isn't about quantity, it is about time. It is about the time necessary to replenish the kanban, and the length of time that the kanban will last based on the production levels. The inventory levels are what is necessary to satisfy the customer, and satisfying the customer is the ultimate goal. Eliminating inventory and warehousing is a great concept, like zero-defects, but the purpose is to minimize the amount required. The entire system really is about methods to minimize time, quantities are not the first priority.
The core of Lean is about waste, in any shape or form, not about inventory or headcount reduction. Where Lean most often fails is that it doesn't look at the long term strategic view, which Toyota did in their development of TPS over the decades. More often than not, Lean is trained as a bunch of discrete tools that one can hammer into place when needed. It doesn't work that way, which is probably the biggest reason so few companies have come close to being able to operate like Toyota.
Wayne
Steve Prevette
Deming Disciple
#26
The Goal is a great book, but I have seen people attribute too much to it. It is the source of the Theory of Constraints, which works well with systems thinking and with lean. I was introduced to it back in the Reengineering frenzy by a consultant who claimed if I read it, I'd become a believer in numerical goals and targets. I read it, I liked it, I didn't become a believer in numerical goals.
W
wmarhel
#27
I'm going to agree with you Steve. It was a good book to get people thinking in a different vein.
From the theory of constraints standpoints, H. William Dettmer's books were very informative.
Wayne
#28
For Lean I would reccomend the part in the ASQ Six sigma BOK that was mentioned before.
My reccomendation also is that for Lean to work you must base it on a robust 5S program. You may think is the most simple but it is the most important part. If you don't have order you don't have the basics to install all the other principles as kanban, work flow, jit, etc, etc.
W
wmarhel
#29
I agree that 5S is extremely important, but it isn't a "program". It is just the way you should operate on a daily basis, as are all the other component of TPS. They really are ways to "manage" the business, versus the typical thinking of "we can fix this with that".
From a systems perspective, 5S is just one of the foundational building blocks. I think your last sentence is on the mark though.
Wayne
J Where does Lean Six Sigma Originate? Six Sigma 5
BeaBea Interesting Discussion Where Does Marketing/ Advertisement of Products fit in to ISO 9001? Process Maps, Process Mapping and Turtle Diagrams 35
D Where does "as far as possible" stop? FMEA - EN 14971 ISO 14971 - Medical Device Risk Management 28
A What if Contract Manufacturers does not have an ISO 13485 certificate? Where will the NB audit take place, at legal mfg. site or contract mfg. site? Other Medical Device Regulations World-Wide 3
D Where does FMEA fit in your ISO 14971 Risk Management process? ISO 14971 - Medical Device Risk Management 13
P Warning Letter 1999 - Where does the FDA make older warning letters available? US Food and Drug Administration (FDA) 4
M Where does our regulatory responsibility end? ISO 13485:2016 - Medical Device Quality Management Systems 11
K Where does the FDA post its various compliance dates? US Food and Drug Administration (FDA) 2
C Where does Quality Authority come from? Career and Occupation Discussions 4
J Where does process validation fit within design & development? Design and Development of Products and Processes 7
Q When does the FDA deem something "where appropriate"? 21CFR820.30(g) 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 11
M Where does Document Revision Control Start? Rev 0 or Rev 1 Document Control Systems, Procedures, Forms and Templates 19
D Where does the QMS (Quality Management System) fit in your organization? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
Q Where does 5S technique fit into ISO 9001? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
Mikael Where does OEE (Overall Equipment Effectiveness) belong? Quality Tools, Improvement and Analysis 11
F Where does Contact begin for Biocompatability? EU Medical Device Regulations 5
somashekar Where does RoHS stuff get audited by CB's? Quality Manager and Management Related Issues 3
S IEC 60601-1 3rd Gap analysis template TO BUY - Does anyone know where? IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
R Where does 20% Lot Qualification Rule Come from? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
G Customer Property Cl. 7.5.4 - Where does ISO 9001 stop and ISO 27001 start? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 33
R Where does the definition of ME (Medical Electrical) Equipment originate? IEC 60601 - Medical Electrical Equipment Safety Standards Series 7
J Quality Organization - Does it matter where it reports to? Other US Medical Device Regulations 13
I Where does it state Supplier Corrective Action is required? Supplier Quality Assurance and other Supplier Issues 5
G 12 or 13 Men - Where does the extra man come from? Brain Teasers and Puzzles 5
S Where does least significant digit come into play? Measurement Uncertainty (MU) 8
T Organizational Charts - Where does the Quality Assurance Manager fit in Quality Manager and Management Related Issues 30
T Does anyone know where I can view Bac5300 Various Other Specifications, Standards, and related Requirements 2
H Where does the 16949 number in TS16949 come from? ISO Numbering System IATF 16949 - Automotive Quality Systems Standard 1
Wes Bucey Where does your hospital rank on quality? Hospitals, Clinics & other Health Care Providers 20
J GMP CFR 21 Part 210 or 211 - Where does GMP address Document Control Document Control Systems, Procedures, Forms and Templates 6
A Where does one find the complete list of ISO standards? Book, Video, Blog and Web Site Reviews and Recommendations 1
D Does anyone know where to buy an instant read dosimeter? ISO 13485:2016 - Medical Device Quality Management Systems 10
C What is Money for? Where does Barter come into play? Coffee Break and Water Cooler Discussions 19
E Where Does One Get Customer Specific Requirements? Customer and Company Specific Requirements 26
CarolX Where does Quality begin? Philosophy, Gurus, Innovation and Evolution 36
M Research and Development Process - Where does research end and development begin? Misc. Quality Assurance and Business Systems Related Topics 15
M Attribute Charting - Where does Cp and Cpk come into the equation? Capability, Accuracy and Stability - Processes, Machines, etc. 5
K Where and How Does Marketing Fit In? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
L Does anyone know where I can get documentation for the PUMA method. General Measurement Device and Calibration Topics 1
E SOP or system Work Instruction? Controlled Document - Where does one draw the line? Document Control Systems, Procedures, Forms and Templates 5
D Number of Distinct Data Categories:nDC: Where does the constant 1.41 come from? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
S Does anyone know where Guide 25/Palcan Training is available? Training - Internal, External, Online and Distance Learning 1
R Internal audit schedules - Where does it say that I need an annual schedule? Internal Auditing 13
C Where to place CE/label in Sterile IVD EU Medical Device Regulations 1
G New to ISO 9001 - Where to begin? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
K No IFU, where the requirements would go? EU Medical Device Regulations 5
T Assessing Hazard-Related Use Scenarios where control measures exist through standards IEC 62366 - Medical Device Usability Engineering 14
J Where to Place Process Maps in our Documentation? Process Maps, Process Mapping and Turtle Diagrams 4
GreatNate Where to get a KPI dashboard for QMS processes Quality Tools, Improvement and Analysis 5
