Where I could find any project HSE plan templates
G
gitugitus
Dear All
Is there someone can help me where I could find any project HSE plan templates.
Your direction or advice shall be great appreciates
regard
Pancho
wikineer
Hi Gitugitus,
What sort of project are you considering? Construction?
Also, do you have s OHS management system implemented in your company?
N
NGurney
Written plenty of QEHS plans for projects.
ISO 10005:2006 is for Quality plans however can be translated in similar manner.
Google: "project HSE plan pfd"
Things often missing from Project Management Plans: Reference corporate procedures (not regurgitate), call up relevant standards, and specs. Also Objectives and Targets at Project level often left out. Risk table often left out. Common things: Policy, O&T, Structure, References, Risk Table (overview). Often written for client instead of actual audience. I believe it should be for project staff and contractors working on site.
Depending on jurisdiction and standards you are working to. For example in most states in Australia, the Act and Regs (Leg requirement) requires Principle Contractor to provide Site Specific Safety Management Plan to subcontractors for them to consider in development of their own 'tools'. Target audience for me was ... not the client.. the subcontractor... the intended user.
Mostly, these documenting processes require some research in identifying the relevant legal and other requirements, standards and codes. The whole research thing (on the net) is an important skill.
I tried to post links to local examples i could find but system says "remove links".
"seek and ye shall find".
Better to do that than just copy the same mistakes off some other mistaken work.
Very jurisdiction orientated. For example google "safety management plan au". You can see the requirement stems from Act and Regs, depending on client (if you are PC) the client may have their own expectations. If you are contractor working for PC, typically, here, you are entitled to have PC provide their plan for you to use as input into your own.
I tend to think of a Project Plan as an opportunity to cherry pick which parts of our larger system will apply on this project. For example, if I have 4 monitoring tools (site inspection systems) I may nominate the one(s) we intend to use on this project. Like going to dinner and selecting from a menu of options to eat.
Again, maintaining an extensive list of relevant legal and other requirements is valuable if you are going to be working with this type of thing. Developing the list requires research, and checking out "referenced" items in other documented requirements/specs/standards/acts/codes/guides etc.
Hope this helps
N
NGurney
One of my local instruments (WHS Reg 2011) states:
309 WHS management plan—preparation
(1) The principal contractor for a construction project must prepare a
written WHS management plan for the workplace before work on the
project commences.
Maximum penalty:
(a) in the case of an individual—$6,000, or
(b) in the case of a body corporate—$30,000.
(2) A WHS management plan must include the following:
(a) the names, positions and health and safety responsibilities of all
persons at the workplace whose positions or roles involve
specific health and safety responsibilities in connection with the
project,
(b) the arrangements in place, between any persons conducting a
business or undertaking at the workplace where the construction
project is being undertaken, for consultation, co operation and the
co-ordination of activities in relation to compliance with their
duties under the Act and this Regulation,
(c) the arrangements in place for managing any work health and
safety incidents that occur,
(d) any site-specific health and safety rules, and the arrangements for
ensuring that all persons at the workplace are informed of these
rules,
(e) the arrangements for the collection and any assessment,
monitoring and review of safe work method statements at the
workplace.
310 WHS management plan—duty to inform
The principal contractor for a construction project must ensure, so far as
is reasonably practicable, that each person who is to carry out work, made aware of:
(a) the content of the WHS management plan for the workplace, and
(b) the person’s right to inspect the WHS management plan under
clause 313.
Maximum penalty:
(a) in the case of an individual—$3,600, or
(b) in the case of a body corporate—$18,000.
311 WHS management plan—review
(1) The principal contractor for a construction project must review and as
necessary revise the WHS management plan to ensure that it remains up
to date.
Maximum penalty:
(2) The principal contractor for a construction project must ensure, so far as
is reasonably practicable, that each person carrying out construction
work in connection with the project is made aware of any revision to the
WHS management plan.
Maximum penalty:
Then is goes into SWMS's. The legislation is the base, then a Code of Practice is more detailed, and then there are standards and guides that are more detailed.
Google NSW WHS regulations 2011 to see that example.
Bouziane
Hi Gitugitus,
Hi Mate,
I really need a HSE-MS gap analysis between 2 existing management systems.?
please assist
Boo
Ajit Basrur Where to find a pagination requirement as "Page x of y"? ISO 13485:2016 - Medical Device Quality Management Systems 7
D Any recommendations on where to find experienced quality hires in Chicago area? Job Openings, Consulting and Employment Opportunities 2
N Where to find Regulations for Reprocessing and Reuse of Single-Use Devices Other Medical Device Related Standards 2
D Where to find Guidance Class II Amendment Canada Medical Device Regulations 1
M Where can I find examples of PPAP? APQP and PPAP 6
J Where can I find the latest update to Reach and ROHS? REACH and RoHS Conversations 9
G Where to find Proficiency Test provider for photometrics (spectral %R, %T, photo density) General Measurement Device and Calibration Topics 9
M Plating standards - Where to find information AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
D Where I can find an ISO 13485:2016 Audit Schedule example? ISO 13485:2016 - Medical Device Quality Management Systems 4
Proud Liberal DFMEA / PFMEA linkage - Where in the standards do I find it? FMEA and Control Plans 5
N Where I can find an Excel sample/template for recording Delivery Time and Cost Excel .xls Spreadsheet Templates and Tools 2
R Specification on flare testing extruded aluminum - Where to find Design and Development of Products and Processes 1
A AS9100 Rev:D in Spanish - where can I find a Spanish version? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
B Where can I find an English version of Japan's PMD Act? Other ISO and International Standards and European Regulations 2
S Where to Find DEV and DFE numbers on FDA Website Other Medical Device and Orthopedic Related Topics 3
N Where to find a Qualified FDA Supplier Auditor located in China China Medical Device Regulations 7
A Where to find a Draft Copy of IATF 16949:2016? IATF 16949 - Automotive Quality Systems Standard 23
I Where to find VDA 6.3 Robust Production Process (rpp) PDF file ? VDA Standards - Germany's Automotive Standards 1
P Where to find the UMDNS code for CE Mark CE Marking (Conformité Européene) / CB Scheme 1
X Where to find UAE medical device registration regulation and guidelines Other Medical Device Regulations World-Wide 3
P Where to find conformance statistics for ISO 15189 Other Medical Device Regulations World-Wide 1
J Where can I find a product's CE Mark Number? CE Marking (Conformité Européene) / CB Scheme 20
R Where to find 21 CFR Part 820 Translated into Czech, Spanish, and German 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
A Where can I find the NADCAP Audit Criteria for all the processes? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
L Where to find ISO27000 Annex A? General Auditing Discussions 2
W Where to find the Daimler DBL 6992 10 new (old) standard Customer and Company Specific Requirements 1
V Where I can find an AAR form on Ford Covisint? APQP and PPAP 1
G Where to find the ANSI Z1.9 Rosetta Stone Capability, Accuracy and Stability - Processes, Machines, etc. 9
R How and Where can I find IFU (Instructions For Use) examples? ISO 13485:2016 - Medical Device Quality Management Systems 6
V Where to find Red/White Rust Rating Requirements? APQP and PPAP 4
P VDA 2 - Where to find EMPB (Erstmusterpr?fbericht) bilingual forms VDA Standards - Germany's Automotive Standards 2
K Where do I find Frequencies and Composite Scale in Minitab? Using Minitab Software 2
V Where do I find Adverse Event Database for Medical Devices? Quality Manager and Management Related Issues 2
S Where can I find a (Methods-Time Measurement) MTM-UAS Table? Human Factors and Ergonomics in Engineering 1
V Where to find FORD Specific PPAP Training Training - Internal, External, Online and Distance Learning 3
S Where can I find the World Bank Regulations Texts? Other ISO and International Standards and European Regulations 6
S Where can I find a list of CE Approved Products? CE Marking (Conformité Européene) / CB Scheme 4
J Where to find info about equivalent standards? ESD issues Other ISO and International Standards and European Regulations 4
B Where to find the 510(k) Device Listing Number 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
K ISO Certified, now where to find work? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
Marc Inspectors find safety flaws where airline food is prepared Travel - Hotels, Motels, Planes and Trains 5
J Where to find new GD&T (geometric dimensioning and tolerancing) standards? Various Other Specifications, Standards, and related Requirements 2
Q Where can I find the MDD definition of Labeling? EU Medical Device Regulations 7
O Where to find FAA Part 21 Federal Aviation Administration (FAA) Standards and Requirements 3
G Where to find Ggg-g-17 - Spec is related to GAGE, FILLET AND RADIUS Customer and Company Specific Requirements 7
S Where to find MIL Standard 8A,8B - Used for Dimensioning and Tolerancing Quality Tools, Improvement and Analysis 3
D Where to find Customer Specific Requirements Customer and Company Specific Requirements 6
Q Where to find CFR 820/GMP Training DVDs Book, Video, Blog and Web Site Reviews and Recommendations 7
M Where to find Medical Software Products on the internet? Software Quality Assurance 3
J Bias example-about Df=10.8 - Where to find the df table Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
