Where no standards exist the basis used for calibration shall be recorded
Andrews
There is requirement in 7.6 of the TS standard that says "Measuring equipment shall be calibrated to measurement standards traceable to national/ international standards where no standards exist the basis used for calibration shall be recorded "
Can someone give me some examples of cases where there are no standards (masters) that are traceable to national or international standards
The exception addresses such things as temperature, speed, and pressure meters and controllers on machinery such as injection molding presses, and similar types of dedicated devices.
Hershal
Metrologist-Auditor
A good example is the Brinnell and Rockwell hardness.....
Until recently they were only a consensus standard.....since you are in India, contact NABL (accrediting body for India).....they may be able to give you more help for your situation.
Hope this helps.
Hershal
Gravity
When working for a vibration monitoring company, we used the earth's gravitational field to calibrate accelerometers. Since the gravitational constant is not in dispute, all we had to do was document the method used to achieve a measurement of the accelerometer dropping in that field.
K
Kevin H
Additional examples from when I was mechanical lab supervisor in a stainless steel mill - we were accredited by A2LA to ISO Guide 25 and our scope included tests for which there were no national or consensus standards. Among the tests without national standards were a "ridging test" a test developed internally within the company that dealt with formability of stainless sheet - it was a visual comparison test and our visual comparison standards were developed and controlled internally. Results also were reported externally to some customers. We also tested samples to determine a "modul-r" value that was reported to external customers (Modul-r was accepted by many customers in place of a strech-r value, which has an ASTM test method. Modul-r was actually more repeatable, quicker, and non-destuctive of test specimens than running a stretch-r, which involves preparing and pulling 3 tensile specimens ( 1 paralell to, 1 perpendicular to and 1 at 45 degrees to the rolling direction for flat sheet) and then making calculations to determine stretch-r) Again a formability test that was I believe originally developed by USX, By the time I took the lab over Tinius-Olsen had purchased the rights to manufacture the testers and associated punches, and ended up developing and certifying a set of standards, but as there were no national test methods based on this test method there were no national standards.
I also believe some standards for spectrometers, etc. have been developed by consensus testing between labs.
T Assessing Hazard-Related Use Scenarios where control measures exist through standards IEC 62366 - Medical Device Usability Engineering 32
M Plating standards - Where to find information AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
Proud Liberal DFMEA / PFMEA linkage - Where in the standards do I find it? FMEA and Control Plans 5
Marc Where do you buy your ISO and other various standards? Various Other Specifications, Standards, and related Requirements 3
J Where to buy standards such as IEC 62366:2007 Other Medical Device Related Standards 2
R Where can I get CSA (Canadian Standards Association) Electrical Bulletin 1402C? IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
A Where can I purchase VDA Standards (VDA 2, VDA 4902 Version 2&3, VDA 6) IATF 16949 - Automotive Quality Systems Standard 2
J Where to find info about equivalent standards? ESD issues Other ISO and International Standards and European Regulations 4
M Where to Start when Implementing ISO Standards in Rotational Molding ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
J Where to find new GD&T (geometric dimensioning and tolerancing) standards? Various Other Specifications, Standards, and related Requirements 2
R JIS B 7502, B7507 - what are these standards and where/how to use them? General Measurement Device and Calibration Topics 2
W Where to buy referenced standards - ASQ Biomedical Auditor Certification - CBA exam Professional Certifications and Degrees 1
V Traceability of Standards - Where can I send my standards to be calibrated? General Measurement Device and Calibration Topics 9
K Where do I access DCX Standards referenced in Chrysler Catia notes? Customer and Company Specific Requirements 8
P Where can I take a peek at ASTM standards without buying? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
A Where can I find the most up-to-date and current engineering standards? IATF 16949 - Automotive Quality Systems Standard 3
P Where to find CQI Standards? Other ISO and International Standards and European Regulations 4
A Where to Find the Most Recent Standards? Other ISO and International Standards and European Regulations 7
I Where to buy ISO/IEC 7810 and ISO/IEC 10373-1 standards Other ISO and International Standards and European Regulations 3
P Where to find JIS (Japan) Standards Various Other Specifications, Standards, and related Requirements 6
R Obsolete Standards - Need J 377:1987 SAE standard, where can i get this old one? Various Other Specifications, Standards, and related Requirements 3
I Where to buy TS16949 Standards in Chinese IATF 16949 - Automotive Quality Systems Standard 6
A Standards Mark - Required Font is Helvetica Plain type - Where to find? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
A Where does one find the complete list of ISO standards? Book, Video, Blog and Web Site Reviews and Recommendations 1
apestate Where to buy standards? Best bang for buying standards buck Book, Video, Blog and Web Site Reviews and Recommendations 4
T Where can I find Federal Standards FED-STD-151 and FED-STD-182 Various Other Specifications, Standards, and related Requirements 6
J ANSI-ASTM-MIL Standards etc. - Where to buy downloadable files - PDF Versions QS-9000 - American Automotive Manufacturers Standard 6
Marc Where to find Measurement Standards General Measurement Device and Calibration Topics 4
A Where to Buy ISO 900x:2000 Standards? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
A Where can I buy VDA 4, VDA 6 and other national or international standards? VDA Standards - Germany's Automotive Standards 3
Marc Where to find government DoD specifications and standards - Mil Specs Various Other Specifications, Standards, and related Requirements 0
J UDI - Where to document it? EU Medical Device Regulations 8
J Where to get a Black belt certification ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 13
D Any recommendations on where to find experienced quality hires in Chicago area? Job Openings, Consulting and Employment Opportunities 3
J Where is the definition of a critical supplier? ISO 13485:2016 - Medical Device Quality Management Systems 5
W Where does a coatings and paint company fall in IATF? IATF 16949 - Automotive Quality Systems Standard 5
B When Travel is allowed - Where are you going? Travel - Hotels, Motels, Planes and Trains 16
G Where to buy Template / sample SCSMS Manual, checklist Supply Chain Security Management Systems 1
M Quality Manual - Where does Revision History Section go? Document Control Systems, Procedures, Forms and Templates 8
C Where to draw the line for "sufficient evidence" to verify safety/performance of a device? CE Marking (Conformité Européene) / CB Scheme 2
L Where to place the what/when/how/who/where procedures in a multi-regulation AS9110C organisation AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
B Where to acquire EN 868-5 required dye (Amaranth red)? Other Medical Device Related Standards 2
N Where to find Regulations for Reprocessing and Reuse of Single-Use Devices Other Medical Device Related Standards 2
H Where to get EK MED 1927/16 Other Medical Device Regulations World-Wide 3
D Where to find Guidance Class II Amendment Canada Medical Device Regulations 1
O EN 301 489-1 and EN 301 489-17 - Where do we get the information of the Published versions? CE Marking (Conformité Européene) / CB Scheme 1
A AS9100 Training - Where do I start? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 14
qualprod Records where apply and stop recording everything? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
