Where to buy "canned" Medical Device QMS Procedures and Documents
dspaul
We are new to the medical device software area and was wondering if anyone out here know where we can purchase standard operating procedure templates to satisfy FDA as well as the IEC 62304 standards.
Any help would be greatly appreciated.
Marc
Fully vaccinated are you?
There are some companies that run AdSense advertisements here that I have noticed but off hand I can't recommend any specific company. I think Mastercontrol is one.
Spazz
Our company bought a canned QMS from Emergo Group (which I neither recommend nor discourage :)).
The only thing about canned procedures is that they're one-size-fits-all and you may have to do extensive revising so that they work for you.
Marc
Not many people here are "pro" canned quality procedures. My suggestion is for you to read some of the existing threads on canned procedures. If you do you will get an idea of the pros and cons.
I have never used any, but I have seen companies who have and were quite satisfied. I have also seen companies use them and totally botch things up costing them a lot of totally wasted time and money. My opinion is that they can be good for people who know how to tailor the canned procedures to their system, and who understand that the canned procedures are *examples* from which to learn.
The biggest failure mode is people (companies) who try to mold/design their systems to the canned procedures.
Wes Bucey
Prophet of Profit
The reason many organizations consider "canned" documents to achieve registration or certification to a Standard or a regulatory body usually falls into one of two categories:
  1. BUDGET $$$: The time and effort to generate some "document" which the company only wants to fill in a requirement from a Standard or a regulatory body and has no intention of doing anything further except use the document as part of their submission for registration/certification. Thus they want a document they can process to "find and replace" a generic company name with their own.
  2. TIME CONSTRAINT: the company wants to get up and running ASAP and doesn't want to take the time to work out its own procedures, thinking they can just adopt some else's that successfully got certification.
The problem in both scenarios is that it takes someone with intimate knowledge of the regulations for certification AND the capabilities, capacity, and character of the company and its managers to successfully adapt the generic documents to accurately reflect what the company should be doing as the most efficacious and efficient system to produce its goods and services.
The point being that the company will fail certification/registration if a independent auditor comes in and notes the company does not actually follow the procedures set forth in the generic documents.
Alternately, the company may follow the procedures, but notice that many of them are just expensive "busy work" which erodes profits.
MY SUGGESTION:
If the company does not have a really knowledgeable person "with intimate knowledge of the regulations for certification AND the capabilities, capacity, and character of the company and its managers to successfully adapt the generic documents to accurately reflect what the company should be doing as the most efficacious and efficient system to produce its goods and services." then it should consider hiring a consultant who CAN get up to speed on the company system and make judicious decisions on adapting generic documents to BOTH fit the company's operation AND meet the certification/registration requirements.
W
WoodDuck
Hello Despaul,
:bigwave:
We are also new to medical device and are consulting with Emergo Group for our QMS. It has been a lot of work and having someone to guide you through the grey areas helps. Whatever you do, have a clear understanding of what you expect to have when you are finished writing your procedures. Our approach was to spend as little as possible while still having personal guidance with our project. Rather than have a person on site observing and writing procedures, Emergo agreed to draft procedures and work remotely with us so we could tailor them to our exact requirements. We started out not realizing we needed a QMS that addressed the embedded software in our device. Software was outside the scope of our contract with Emergo, so we engaged another consultant, RTEmd, to assist us with the alterations to the QMS. It's been nice to see how two independent companies approach QMS development and I've certainly learned more, but there has been a cost and time factor that has not helped. Good Luck!
Jim
Marc
This is a little bit off-topic, but I think it may be informative. The word consultant is mentioned. The thing to remember about consultants is, consultants are a source of training. In other words if your company does not have a person who fully understands the requirements, a consultant is much like a very intense trainer.
An off topic example: I worked with a company which had no one who was proficient in GD&T. They accepted contracts with prints that no one there fully understood and - As one might think - They ended up with problems now and again. I hooked them up with a local lab who agreed to provide "consulting" in interpreting prints which came with quotes (or contract revision requests). The company should have had a person in their lab who was proficient in GD&T, but they chose not to hire such a person (too expensive). But - They did start using the fellow from the outside lab to review prints when a quote came in.
Whenever I do an implementation as a consultant, one of the first things I explain is there has to be a target person for me to work with to teach the requirements and how they relate to their company. A consultant should be, above all else, a trainer.
Just something to think about.
G Where to buy Template / sample SCSMS Manual, checklist Supply Chain Security Management Systems 1
G Where to buy Medical Grade Transformer IEC 60601 - Medical Electrical Equipment Safety Standards Series 12
H AS9100D Cert question - Small machine shop - Where can I buy a certificate? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
C Where to buy the latest MHLW, Canada MDR, Brazil medical device regulations Other Medical Device Regulations World-Wide 2
Marc Where do you buy your ISO and other various standards? Various Other Specifications, Standards, and related Requirements 3
ernieto Where can I buy ISO-15223-1 CD with graphic symbols? Other Medical Device Related Standards 13
I Where to buy ISO 10001, 10002, 10003 & 10004 (latest) Other ISO and International Standards and European Regulations 3
J Where to buy English translation of Chinese Standard GB/T 14233 China Medical Device Regulations 8
B Where can I buy the ISO 9001:2015 Standard in pdf? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
M Where to buy ISO 3951-1 and ISO 3951-2 standard copy Other ISO and International Standards and European Regulations 1
M Where to buy AIAG Manuals ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 2
M Where to buy various VDA Sandards VDA Standards - Germany's Automotive Standards 1
Douglas E. Purdy Where to buy Little Red Arrow Stickers Coffee Break and Water Cooler Discussions 11
D Where to buy IEC60601-1 Symbols IEC 60601 - Medical Electrical Equipment Safety Standards Series 8
P Where to buy ISO 13485:2012 ISO 13485:2016 - Medical Device Quality Management Systems 10
E Where to Buy IEC 62304 Software Life Cycle IEC 62304 - Medical Device Software Life Cycle Processes 7
S IEC 60601-1 3rd Gap analysis template TO BUY - Does anyone know where? IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
J Where to buy standards such as IEC 62366:2007 Other Medical Device Related Standards 2
S Where to buy EN9130? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
G ISO 14040/44 - Are these 2 seperate documents and where to buy? Miscellaneous Environmental Standards and EMS Related Discussions 2
K Where to buy ISO/IEC 17025:2005 ISO 17025 related Discussions 4
A Where can I buy EN ISO 14971:2009 (Medical Device Risk Management)? ISO 14971 - Medical Device Risk Management 11
D Where to buy Cheap Plastic Bins for use as Inspection Tubs Manufacturing and Related Processes 6
S DIN 29591 and DIN 29531 - Where to buy in English or French? Other ISO and International Standards and European Regulations 3
C Where to Buy AS9003 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
Q Where to buy the ISO 13485 standard in a pocket sized book ISO 13485:2016 - Medical Device Quality Management Systems 19
J Where to buy AIAG MSA 3rd Edition Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
A Where to buy DIN 53504 in English Other ISO and International Standards and European Regulations 3
M Where to buy VDA volume nr 12 in English Language VDA Standards - Germany's Automotive Standards 2
D Where to buy ISO9001:2008 Edition at the cheapest price ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 18
S Where to buy an electronic copy of ISO 9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
S Where can I buy a PDF version of ISO 9001-2008 that I can print? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
Chennaiite English version of the JIS D5707 Standard - Where to buy Other ISO and International Standards and European Regulations 1
R Standard on Clean room - Where can I buy ISO 14644-1 and ISO 14644-4 US Food and Drug Administration (FDA) 3
A Vendor Rating System - IS:12040-1987 (India Standard) - Where to buy ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
W Where to buy referenced standards - ASQ Biomedical Auditor Certification - CBA exam Professional Certifications and Degrees 1
N Where to buy a good interpretation of the ISO 9001:2008 standard Quality Manager and Management Related Issues 17
L Where to buy the ISO 19011 guidance document General Auditing Discussions 18
A Where to Buy SAE J2340 Customer and Company Specific Requirements 4
Anerol C Where I can buy a Jaegar Eye Chart ? Various Other Specifications, Standards, and related Requirements 4
D Where to buy MIL-DTL-11195G Paint tested to ASTM-D1654 with Certifications Misc. Quality Assurance and Business Systems Related Topics 2
S Where can I buy TS7-K Supplier Quality Requirements QS 7 Pack? IATF 16949 - Automotive Quality Systems Standard 5
Marc Where would you go to buy an HDTV? After Work and Weekend Discussion Topics 30
I Where to buy ISO/IEC 7810 and ISO/IEC 10373-1 standards Other ISO and International Standards and European Regulations 3
R Where can I buy TS 16949 technical specs and manuals? IATF 16949 - Automotive Quality Systems Standard 8
M Where to get/buy Jedec Std - J-STD-005 Various Other Specifications, Standards, and related Requirements 7
M Where can I buy a copy of the QS9000 standard? QS-9000 - American Automotive Manufacturers Standard 16
A I need the ISO 13485 Standard manual. Where can I buy it? ISO 13485:2016 - Medical Device Quality Management Systems 9
K Where to buy a copy of the AS9100 Standard only? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 15
I Where to buy TS16949 Standards in Chinese IATF 16949 - Automotive Quality Systems Standard 6
