Where to buy ISO 13485:2012
Sam Lazzara
Interesting/strange.
In any case I highly recommend that you purchase EN ISO 13485:2012 instead of the pure ISO 13485:2012. Much better value since it includes the ISO version and the recently updated informative annexes.
I always check with BSI to get the scoop on EN/ISO/IEC standards but I tend to purchase what I need through AAMI (cannot get EN's from them though) or the Document Center in California, USA. I recently compared pricing between BSI, Document Center, Tech Street and IHS Global for this standard and unless you are a BSI member, the Document Center had the best pricing.
AAMI has the best pricing for medical device standards on planet earth if you become a member and then subscribe to their standards on CD collection.
I do not work for any of these companies, just sharing my experience. I like to check BSI's info since they indicate whether EN ISO standards are identical to an ISO standard. The ANSI/AAMI/ISO or ANSI/AAMI/IEC standards also indicate their equivalency to the pure ISO/IEC standards.
Ajit Basrur
Re: Where to buy ISO 13485:2012 ?
Current version is ISO 13485:2003 - http://www.iso.org/iso/catalogue_detail?csnumber=36786 with the stage of 90.92 that indicates it is "International Standard to be revised".
There is a Corrigendum - ISO 13485:2003/Cor. 1 :2009 - http://www.iso.org/iso/home/store/catalogue_tc/catalogue_detail.htm?csnumber=54724
There is a ISO 13485 under development - ISO/CD 13485 - http://www.iso.org/iso/home/store/catalogue_ics/catalogue_detail_ics.htm?csnumber=59752
There is a EN ISO 13485:2012 published in Mar 2012 - http://shop.bsigroup.com/en/ProductDetail/?pid=000000000030268037
Pls note that the text in the EN ISO 13485:2012 version remains unchanged from ISO 13485:2003 with changes only in the foreword and annexes.
parr05
Many thanks for the information and links.
We are 3 weeks away from a surveillance audit, and the NB asked us to observe the new version of ISO 13485:2003/2012 to incorporate new demands in our QMS.
If the new revision contains no new requirements, what changes can be done to our QMS? besides revision year.
Any comments are appreciated.
Sam Lazzara
I need to correct the first post I made in this thread. Here is what I should have stated.
There is no ISO 13485:2012 but if you have current CE marked devices you should be interested in EN ISO 13485:2012. The normative requirements have not changed. The 2012 version has updated informative "Z" annexes that point out the sections of the medical device directives that are not covered by ISO 13485:2003.
Since you have presumably already proven conformance with the directive(s) that apply to your devices, you should not have to make any changes to your QMS (except referencing EN ISO 13485:2012) unless you notice that you do not cover all of the requirements of the directive(s). That would also mean that your prior Notified Body audits and your internal audits did not detect those gaps.
Marcelo
I've been told by AAMI that they will issue a 2012 edition of AAMI/ANSI/ISO 13485 at some point in October or November, and that it will have US nationally specific content.
I think this is extremely unlikely. The way the FDA deals with ISO 13485 is by influencing the development of the standard, in the same manner they are influencing it's revision right now.
I'm also at the moment in a meeting with an AAMI officer which also thinks that it's unlikely, but we are still to hear a final word from the direct AAMI officer. Anyway, what we've got at the moment is that AAMI/ANSI/ISO 13485 is, as happens from time to time, under revision, but that it's probably going to be reaffirmed in 2012 without modifications.
MIREGMGR
Maybe I misunderstood? I talked with their sales folks about a month ago.
Marcelo
May be so.
I was also last week with the convenor of ISO TC 210 WG 1, who is also the convenor of the AAMI group, and he didn't mention anything related to this.
With the high emphasis the FDA is giving to the IMDRF single-audit program, it would be weird to begin creating "problems" with ISO 13485 right now.
When I get info from AAMI I will post an update.
Marc Where do you buy your ISO and other various standards? Various Other Specifications, Standards, and related Requirements 3
ernieto Where can I buy ISO-15223-1 CD with graphic symbols? Other Medical Device Related Standards 13
I Where to buy ISO 10001, 10002, 10003 & 10004 (latest) Other ISO and International Standards and European Regulations 3
B Where can I buy the ISO 9001:2015 Standard in pdf? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
M Where to buy ISO 3951-1 and ISO 3951-2 standard copy Other ISO and International Standards and European Regulations 1
G ISO 14040/44 - Are these 2 seperate documents and where to buy? Miscellaneous Environmental Standards and EMS Related Discussions 2
K Where to buy ISO/IEC 17025:2005 ISO 17025 related Discussions 4
A Where can I buy EN ISO 14971:2009 (Medical Device Risk Management)? ISO 14971 - Medical Device Risk Management 11
Q Where to buy the ISO 13485 standard in a pocket sized book ISO 13485:2016 - Medical Device Quality Management Systems 19
S Where to buy an electronic copy of ISO 9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
S Where can I buy a PDF version of ISO 9001-2008 that I can print? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
R Standard on Clean room - Where can I buy ISO 14644-1 and ISO 14644-4 US Food and Drug Administration (FDA) 3
N Where to buy a good interpretation of the ISO 9001:2008 standard Quality Manager and Management Related Issues 17
L Where to buy the ISO 19011 guidance document General Auditing Discussions 18
I Where to buy ISO/IEC 7810 and ISO/IEC 10373-1 standards Other ISO and International Standards and European Regulations 3
A I need the ISO 13485 Standard manual. Where can I buy it? ISO 13485:2016 - Medical Device Quality Management Systems 9
M Where can I buy (purchase) copies of the ISO/TS 16949:2002 Standard fast? IATF 16949 - Automotive Quality Systems Standard 3
J Where can I buy the new ISO 14001:2004 Standard? ISO 14001:2015 Specific Discussions 4
D Where can I buy an AS9100 / ISO 9001:2000 Banner? Misc. Quality Assurance and Business Systems Related Topics 3
C Where to buy a copy of ISO/TS 16949 IATF 16949 - Automotive Quality Systems Standard 7
T Where can I buy ISO 13485? ISO 13485:2016 - Medical Device Quality Management Systems 1
R Where can I buy ISO 14001 - The Electronic Version ISO 14001:2015 Specific Discussions 12
P Where can I buy ISO 13485? ISO 13485:2016 - Medical Device Quality Management Systems 3
A Where to Buy ISO 900x:2000 Standards? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
G Where to buy Template / sample SCSMS Manual, checklist Supply Chain Security Management Systems 1
G Where to buy Medical Grade Transformer IEC 60601 - Medical Electrical Equipment Safety Standards Series 12
H AS9100D Cert question - Small machine shop - Where can I buy a certificate? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
C Where to buy the latest MHLW, Canada MDR, Brazil medical device regulations Other Medical Device Regulations World-Wide 2
J Where to buy English translation of Chinese Standard GB/T 14233 China Medical Device Regulations 8
M Where to buy AIAG Manuals ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 2
D Where to buy "canned" Medical Device QMS Procedures and Documents IEC 62304 - Medical Device Software Life Cycle Processes 12
M Where to buy various VDA Sandards VDA Standards - Germany's Automotive Standards 1
Douglas E. Purdy Where to buy Little Red Arrow Stickers Coffee Break and Water Cooler Discussions 11
D Where to buy IEC60601-1 Symbols IEC 60601 - Medical Electrical Equipment Safety Standards Series 8
E Where to Buy IEC 62304 Software Life Cycle IEC 62304 - Medical Device Software Life Cycle Processes 7
S IEC 60601-1 3rd Gap analysis template TO BUY - Does anyone know where? IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
J Where to buy standards such as IEC 62366:2007 Other Medical Device Related Standards 2
S Where to buy EN9130? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
D Where to buy Cheap Plastic Bins for use as Inspection Tubs Manufacturing and Related Processes 6
S DIN 29591 and DIN 29531 - Where to buy in English or French? Other ISO and International Standards and European Regulations 3
C Where to Buy AS9003 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
J Where to buy AIAG MSA 3rd Edition Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
A Where to buy DIN 53504 in English Other ISO and International Standards and European Regulations 3
M Where to buy VDA volume nr 12 in English Language VDA Standards - Germany's Automotive Standards 2
D Where to buy ISO9001:2008 Edition at the cheapest price ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 18
Chennaiite English version of the JIS D5707 Standard - Where to buy Other ISO and International Standards and European Regulations 1
A Vendor Rating System - IS:12040-1987 (India Standard) - Where to buy ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
W Where to buy referenced standards - ASQ Biomedical Auditor Certification - CBA exam Professional Certifications and Degrees 1
A Where to Buy SAE J2340 Customer and Company Specific Requirements 4
Anerol C Where I can buy a Jaegar Eye Chart ? Various Other Specifications, Standards, and related Requirements 4
