Where to draw the line for "sufficient evidence" to verify safety/performance of a device?
Sorry in advance if this is long-winded. I'm having trouble understanding the limits people (mainly notified bodies I suppose) set for determining whether there is sufficient clinical evidence to verify safety/performance of a device. Is it just a judgement call on a case-by-case basis? Is it ever OK to have zero evidence of one type if you have tons of evidence of a different type? For instance, what if you had zero PMCF but hundreds upon hundreds of articles in the literature? What about vice versa, with nothing in the literature (even with really broad search terms) but a lot of PMCF information available? Same question goes for any other combination you can think of (eg, lots of FMEA, some literature, no PMCF, a little bit of MAUDE/MHRA/TGA-DAEN or whatever else). Some related questions:
a) If you're doing an update, do you need recent verification/validation/FMEA data if no design changes were made since the last evaluation period? Can you just say "it worked last time so that old data is sufficient"?
b) Are non-peer reviewed abstracts sufficient evidence if no peer-reviewed literature is available? Can they be a tie-breaker where you're on the borderline between "sufficient" and "insufficient" and they tip you over the edge to "sufficient"?
c) Can absence (or near absence) of information be used to support your conclusion? If you receive no complaints and nothing shows up in databases like MAUDE (and others), would you consider that to support the safety of your device? What if a previous evaluation period had none but the current evaluation period has a small (subjective, I know) amount? It's at the mercy of what people report to you so there's no real way to know how representative the previous or current periods were.
d) What happens if you ultimately decide there's insufficient evidence? Do you just tell the notified body "hey our device isn't safe/effective" or "hey we're not really sure and need more info" then get reprimanded, lose the CE mark, and forced to take your device off the market? Seems like there would be pressure to make data "fit" into being sufficient if that's the case.
If you made it this far, thanks for any info/insight!!
Raisin picker
Well, you should start your (continually ongoing) clinical evaluation process early during development. You will then see in time where there is sufficient data in the literature, and where you need to create more data.
If you closely follow the MDR requirements(*) for the clinical evaluation plan (CEP, see MDR Annex XIV 1. a), you will have a list of your device "clinical outcome parameters", with measurable aspects. You then should dissect every piece of data you found (literature, PMS, PMCF, registers, HTAs, ...) for these aspects. You do the same for the current state of science and medicine. Since you are trained in scientific research and writing (MDR requirement), you can compare these aspects for your device (including equivalent devices) and the state of the art and evaluate if there's a significant difference, or if you have not enough data to determine significance.
MDR Annex XIV 2.:
"... Its depth and extent shall be proportionate and appropriate to the nature, classification, intended purpose and risks of the device in question, as well as to the manufacturer's claims in respect of the device. "
This allows you to justify to use few data for an old, simple class IIa device and requires you to really dig deep for your new class III device with game-changing features.
There's no need to have data from all possible sources, but you should justify why you used the sources you did, or show that you found no data. That's especially common with competent authority databases. You search with FDA MAUDE, Health Canada and TGA and will receive a nonconformity for forgetting the european databases. If you add MHRA, Swissmedic, BfArM, and still find no data (using the right keywords, not just your company name), you're actually lucky to have no data.
In the long run, however, you should have a very good reason not to have PMCF data. Keep in mind that PMCF need not be a PMCF trial. But the NB will want to see data from your own device sooner or later.
You also need to be aware that, although the demonstration of equivalence under MDR sounds equal or even easier that under MEDDEV 2.7/1 rev4, you have to show how you got access to the data you compare. That can include the other devices IFU, data sheet, homepage, literature, but also own lab analysis. There's always a chance that you cannot show that for some critical aspect, e.g. the exact surface treatment of the implant that's supposed to facilitate bone integration.
(*): Don't forget to add the MEDDEV 2.7/1 requirements to your CEP.
J Medical Device Failure Effects - Where to draw the line? FMEA and Control Plans 8
K Where do you draw the line on what fixtures/testing equipment require calibration General Measurement Device and Calibration Topics 36
J Where to draw the line with Red Lining? US Food and Drug Administration (FDA) 7
C Quality Manager and employee issues, where to draw the line? Career and Occupation Discussions 17
E SOP or system Work Instruction? Controlled Document - Where does one draw the line? Document Control Systems, Procedures, Forms and Templates 5
W Where does a coatings and paint company fall in IATF? IATF 16949 - Automotive Quality Systems Standard 5
B When Travel is allowed - Where are you going? Travel - Hotels, Motels, Planes and Trains 12
G Where to buy Template / sample SCSMS Manual, checklist Supply Chain Security Management Systems 1
M Quality Manual - Where does Revision History Section go? Document Control Systems, Procedures, Forms and Templates 8
L Where to place the what/when/how/who/where procedures in a multi-regulation AS9110C organisation AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
B Where to acquire EN 868-5 required dye (Amaranth red)? Other Medical Device Related Standards 2
N Where to find Regulations for Reprocessing and Reuse of Single-Use Devices Other Medical Device Related Standards 2
H Where to get EK MED 1927/16 Other Medical Device Regulations World-Wide 3
D Where to find Guidance Class II Amendment Canada Medical Device Regulations 1
O EN 301 489-1 and EN 301 489-17 - Where do we get the information of the Published versions? CE Marking (Conformité Européene) / CB Scheme 1
A AS9100 Training - Where do I start? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 14
qualprod Records where apply and stop recording everything? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
C Where to place CE/label in Sterile IVD EU Medical Device Regulations 1
G New to ISO 9001 - Where to begin? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
BeaBea Interesting Discussion Where Does Marketing/ Advertisement of Products fit in to ISO 9001? Process Maps, Process Mapping and Turtle Diagrams 39
K No IFU, where the requirements would go? EU Medical Device Regulations 5
T Assessing Hazard-Related Use Scenarios where control measures exist through standards IEC 62366 - Medical Device Usability Engineering 32
J Where to Place Process Maps in our Documentation? Process Maps, Process Mapping and Turtle Diagrams 4
GreatNate Where to get a KPI dashboard for QMS processes Quality Tools, Improvement and Analysis 5
A Implementing ISO 20000-1 - Where to start Other ISO and International Standards and European Regulations 2
D Where does "as far as possible" stop? FMEA - EN 14971 ISO 14971 - Medical Device Risk Management 29
qualprod Statistics - Where to start in ISO 9001? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
H Calibration of InfraRan Vapor Analyzer - where to get calibration for SF6 General Measurement Device and Calibration Topics 2
M Where can I find examples of PPAP? APQP and PPAP 6
A What if Contract Manufacturers does not have an ISO 13485 certificate? Where will the NB audit take place, at legal mfg. site or contract mfg. site? Other Medical Device Regulations World-Wide 3
J Where can I find the latest update to Reach and ROHS? REACH and RoHS Conversations 9
D Where (in US) can I get the VDA Auditor Edition book? VDA Standards - Germany's Automotive Standards 3
S Where to get online AS standard audit certification classes? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
J Where I can get a copy of either the 3rd or 4th edition of UL544? Other Medical Device Regulations World-Wide 7
G Where to find Proficiency Test provider for photometrics (spectral %R, %T, photo density) General Measurement Device and Calibration Topics 9
Marc Quiz - Where did the idea of an assembly line come from? Coffee Break and Water Cooler Discussions 4
F Quality Objectives - Where in the QMS Quality Objectives should be located ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
M Where to obtain a calibrated DICOM image? ISO 13485:2016 - Medical Device Quality Management Systems 1
R Where to get information - M6 per WA900 Manufacturing and Related Processes 1
S Where did FDA 510(K) form 3654 go? Other US Medical Device Regulations 1
W Where to begin with an ISO 9001:2015 internal audit Internal Auditing 13
D China - Where I can get NMPA complete structure/organogram chart and GB/YY format list China Medical Device Regulations 1
D Where does FMEA fit in your ISO 14971 Risk Management process? ISO 14971 - Medical Device Risk Management 13
CCaantley Where to get a good test indicator stand for a granite surface plate General Measurement Device and Calibration Topics 8
I ESD - Dissipative foam on a seat for where the people sit at benches Manufacturing and Related Processes 6
