Where to find Proficiency Test provider for photometrics (spectral %R, %T, photo density)
greif
We are working to become ISO 17025 accredited as a calibration lab. I need to line up a proficiency test plan for measurements, But have only found one provider for glass line scales (NAPT) and one for L*a*b* color ( CTS). I need tests for the following;
Spectral % reflectance at 0:45 diffuse
Transmission optical density (ortho photographic densitometer)
Spectral % transmission (spectrophotometer)
Any leads on accredited outfits that offer such services would be much appreciated.!
Thanks!
dwperron
Thanks!
Unfortunately I don't know of any proficiency testing service for those disciplines.
Most accreditation bodies will allow you to opt out of this requirement if you show records of your due diligence in searching for such a lab.
Also 17025:2017 covers this much better than past versions:
7.7.2 The laboratory shall monitor its performance by comparison with results of other laboratories,
where available and appropriate. This monitoring shall be planned and reviewed and shall include, but
not be limited to, either or both of the following:
a) participation in proficiency testing;
b) participation in interlaboratory comparisons other than proficiency testing.
So you can use a planned and monitored interlab comparison here. Something I have done is to compare our lab results to measurements on freshly calibrated standards. That way you can show that your measurements are consistent with another outside laboratory.
Al Rosen
Thanks!
Have you considered NIST?
Al Rosen
I like NIST! Some of my standards were calibrated by them. How do they fit into the proficiency testing?
I'm not familiar with the requirements for proficiency testing, but NIST should have the capability to do the measurements. Make an inquiry and discuss your requirements.
greif
17025 requires a lab to test itself against a group of other labs for proficiency. And the outfit administerig the test must be ISO 17043 accredited as an proficiency tester. NIST probably does round robin things with other NMIs, but I don't know of them doing things with labs.
One thing I am sure must be out there, but have not seen is a test of labs for spectral transmission for a standard spectrophotometer using a cuvette cell. The ones I have seen all seem to be actual samples to analyze not "how good is your %T reading across the spectrum".
greif
NVLAP does 17025 accreditation , like A2LA, or ANAB; but I don't see proficiency testing in their bag of tricks.
dwperron
Since you are not finding a proficiency test provider I would suggest contacting other accredited laboratories doing the same calibrations. They will be running into the same issue. Perhaps you can team up with them on a round robin, or maybe they already know of one in operation.
NVLAP will accredit proficiency testing providers, but they are not a proficiency testing service.
Have you contacted the accreditation body you are working with? Maybe they can provide some guidance.
greif
Thanks- I was hoping it was just my ignorance of the various proficiency testers, but I will need to make more than a few calls.
D Any recommendations on where to find experienced quality hires in Chicago area? Job Openings, Consulting and Employment Opportunities 3
N Where to find Regulations for Reprocessing and Reuse of Single-Use Devices Other Medical Device Related Standards 2
D Where to find Guidance Class II Amendment Canada Medical Device Regulations 1
M Where can I find examples of PPAP? APQP and PPAP 6
J Where can I find the latest update to Reach and ROHS? REACH and RoHS Conversations 9
M Plating standards - Where to find information AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
D Where I can find an ISO 13485:2016 Audit Schedule example? ISO 13485:2016 - Medical Device Quality Management Systems 4
Proud Liberal DFMEA / PFMEA linkage - Where in the standards do I find it? FMEA and Control Plans 5
N Where I can find an Excel sample/template for recording Delivery Time and Cost Excel .xls Spreadsheet Templates and Tools 2
R Specification on flare testing extruded aluminum - Where to find Design and Development of Products and Processes 1
A AS9100 Rev:D in Spanish - where can I find a Spanish version? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
B Where can I find an English version of Japan's PMD Act? Other ISO and International Standards and European Regulations 2
S Where to Find DEV and DFE numbers on FDA Website Other Medical Device and Orthopedic Related Topics 3
N Where to find a Qualified FDA Supplier Auditor located in China China Medical Device Regulations 7
G Where I could find any project HSE plan templates Occupational Health & Safety Management Standards 4
A Where to find a Draft Copy of IATF 16949:2016? IATF 16949 - Automotive Quality Systems Standard 23
I Where to find VDA 6.3 Robust Production Process (rpp) PDF file ? VDA Standards - Germany's Automotive Standards 1
P Where to find the UMDNS code for CE Mark CE Marking (Conformité Européene) / CB Scheme 1
X Where to find UAE medical device registration regulation and guidelines Other Medical Device Regulations World-Wide 3
P Where to find conformance statistics for ISO 15189 Other Medical Device Regulations World-Wide 1
J Where can I find a product's CE Mark Number? CE Marking (Conformité Européene) / CB Scheme 20
R Where to find 21 CFR Part 820 Translated into Czech, Spanish, and German 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
A Where can I find the NADCAP Audit Criteria for all the processes? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
L Where to find ISO27000 Annex A? General Auditing Discussions 2
W Where to find the Daimler DBL 6992 10 new (old) standard Customer and Company Specific Requirements 1
V Where I can find an AAR form on Ford Covisint? APQP and PPAP 1
G Where to find the ANSI Z1.9 Rosetta Stone Capability, Accuracy and Stability - Processes, Machines, etc. 9
R How and Where can I find IFU (Instructions For Use) examples? ISO 13485:2016 - Medical Device Quality Management Systems 6
V Where to find Red/White Rust Rating Requirements? APQP and PPAP 4
P VDA 2 - Where to find EMPB (Erstmusterpr?fbericht) bilingual forms VDA Standards - Germany's Automotive Standards 2
K Where do I find Frequencies and Composite Scale in Minitab? Using Minitab Software 2
V Where do I find Adverse Event Database for Medical Devices? Quality Manager and Management Related Issues 2
S Where can I find a (Methods-Time Measurement) MTM-UAS Table? Human Factors and Ergonomics in Engineering 1
V Where to find FORD Specific PPAP Training Training - Internal, External, Online and Distance Learning 3
S Where can I find the World Bank Regulations Texts? Other ISO and International Standards and European Regulations 6
S Where can I find a list of CE Approved Products? CE Marking (Conformité Européene) / CB Scheme 4
J Where to find info about equivalent standards? ESD issues Other ISO and International Standards and European Regulations 4
B Where to find the 510(k) Device Listing Number 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
K ISO Certified, now where to find work? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
Marc Inspectors find safety flaws where airline food is prepared Travel - Hotels, Motels, Planes and Trains 5
J Where to find new GD&T (geometric dimensioning and tolerancing) standards? Various Other Specifications, Standards, and related Requirements 2
Q Where can I find the MDD definition of Labeling? EU Medical Device Regulations 7
O Where to find FAA Part 21 Federal Aviation Administration (FAA) Standards and Requirements 3
G Where to find Ggg-g-17 - Spec is related to GAGE, FILLET AND RADIUS Customer and Company Specific Requirements 7
S Where to find MIL Standard 8A,8B - Used for Dimensioning and Tolerancing Quality Tools, Improvement and Analysis 3
D Where to find Customer Specific Requirements Customer and Company Specific Requirements 6
Q Where to find CFR 820/GMP Training DVDs Book, Video, Blog and Web Site Reviews and Recommendations 7
M Where to find Medical Software Products on the internet? Software Quality Assurance 3
J Bias example-about Df=10.8 - Where to find the df table Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
R Where I can find a list of (Notified Chemical) substances? RoHS, REACH, ELV, IMDS and Restricted Substances 6
