Where to Purchase an MS Word version of ISO 9001
Wes Bucey
Prophet of Profit
#21
Re: Word version of ISO 9001
My point was that the concept of conformed copies in the legal sense has nothing to do with the subject at hand. I was simply warning the OP to verify that an editable copy of the standard hasn't been edited such that requirements or meaning has been changed.
OK - let's drop the topic of what kind of copy and determine WHY OP thinks he needs/wants a Word Format versus one in Portable Document File Format.
I presume OP thinks it will be "cool" to extract portions to insert in his organization's Quality Management System (QMS) Documents as "evidence" of what ISO says it "shall" do. (i.e. "extract" rather than "transcribe" from a hard copy or locked pdf copy.)
This leads down the well-worn path of folks regurgitating the Standard as the Quality Manual for the organization - a theme we [in consensus as a group] generally oppose and have beaten to death over the years here in the Cove.
We need to press the OP a little more for the root cause of his quest.
Stijloor
#22
<snip> We need to press the OP a little more for the root cause of his quest.
That, I believe is irrelevant to the OP's request. Actually what he will do with it (or not do) should not be of our concern. I believe that the copyright issue has been adequately responded to.
Stijloor.
Wes Bucey
Prophet of Profit
#23
Stijloor.
Aah! There I think you are wrong! As Quality professionals, our job is to educate others to seek the solutions to the real problem they face, not stop part-way.
As you, yourself, have doubtless helped countless others learn, the quest for a root cause does not stop with the answer to the first WHY? In fact, many quality folk have codified the search for a true solution to something they call the "5 whys" and here in the Cove, you have directed others to many of the attachments on the subject stored here in the Cove (http://elsmar.com/Forums/showpost.php?p=266457&postcount=2) - if you didn't believe or practice the 5 whys yourself, would you have referred someone to the list? Probably not, for the same reason you didn't refer the OP here to a Word copy of the ISO Standard, even though a really diligent use of search engines would have turned one up - it would not have been the correct thing for a Quality professional to do.
Stijloor
#24
Wes,
Excellent points!
Stijloor.
JaneB
#25
Wes, you raised an interesting point. And re. this statement, I agree with you in some cases. But not all and not this particular one.
I think it's second-guessing to make the assumption you made here about exactly why the OP was looking for a copy. (I can think of various other reasons why someone might do it, none of which included yours.)
I don't think in every single case 'we' should assume that 'we' know better than the person asking a question and that it is 'our job to educate others', particularly where they have simply asked a factual question (where can I get x?) and have not requested or sought enlightenment, guidance or further input.
To assume that we should set out to educate in every single case I think could be a patronising and somewhat arrogant point of view.
Wes Bucey
Prophet of Profit
#26
I'm certainly arrogant. After nearly six years of fielding questions and over 6,000 responses, I do tend to see a pattern to questions and my batting average on "inferring" what a poster is really going through and really needs is pretty high. I readily admit it is not 1000, but all we need is the original poster to return and elucidate and clarify his situation rather than leaping at each other's throats to become top gun.
For years, I've had the reputation of telling folks how to build a watch when all they want is to know the time, but I've always been particularly conscious of the fact my posts hang around for years and I figure I have a responsibility to make them usable for other readers, not just the original poster.
Deming was an early proponent of the System of Profound Knowledge - I'm merely carrying on the tradition.
JaneB
#27
:lol:
Hold up there, Wes. I did not intend any leaping at your throat (metaphorical or otherwise), and certainly hope you aren't leaping at mine. :D
As for a mantle going around with 'top gun' written on it, if there is such a one, then be my guest, because I'm not competing for that or any other. :nope:
But I reserve the right to speak on something when I choose, as I did here. Did I say something too bluntly, and perhaps offend you? If so, I apologise. It was a/the point of view that I was addressing, not you personally.
Wes Bucey
Prophet of Profit
#28
:lol:
If I ever am offended, all I will do (and what everyone else should do if offended by content of a post) is click the report post button and let the moderators sort it out. I haven't EVER clicked "report post" in 6 years for personal offense - that goes back to being arrogant, I guess.:lmao:
#29
ar·ro·gant (
r
-g
nt)adj.1. Having or displaying a sense of overbearing self-worth or self-importance.
2. Marked by or arising from a feeling or assumption of one's superiority toward others: an arrogant contempt for the weak.
Now may we return to the topic at hand?
T Where to purchase ISO 9001:2008 and ISO 9000:2005? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
L Where to purchase ISO/IEC 27001:2013 IEC 27001 - Information Security Management Systems (ISMS) 3
A Where can I purchase VDA Standards (VDA 2, VDA 4902 Version 2&3, VDA 6) IATF 16949 - Automotive Quality Systems Standard 2
Q Where to purchase the AQL Slide Ruler AQL - Acceptable Quality Level 2
A From where can I purchase OHSAS 18002:2008? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
S Where and What Template to Purchase for implementing ISO 9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
L Where to purchase ISO/TS 16949 Training Handbook IATF 16949 - Automotive Quality Systems Standard 6
Q AIAG Manuals - Where to purchase electronic copies of AIAG Manuals APQP and PPAP 3
O Where to purchase Go/NO GO Block gage needed to measure width General Measurement Device and Calibration Topics 5
M Where can I buy (purchase) copies of the ISO/TS 16949:2002 Standard fast? IATF 16949 - Automotive Quality Systems Standard 3
A Is there a place where I can purchase ISO 9001:2000 posters? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
M Data Measurement - Where can I purchase a data recording system? Records and Data - Quality, Legal and Other Evidence 2
M Where can I purchase OHSAS 18001? Occupational Health & Safety Management Standards 27
R ISO Publications - Where the best place to purchase ISO 9001 publications? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
J Where can I purchase VDA 6.1 VDA Standards - Germany's Automotive Standards 10
J Where can I purchase VDA 6.1? VDA Standards - Germany's Automotive Standards 11
M Testing criteria - where to place Design and Development of Products and Processes 1
J UDI - Where to document it? EU Medical Device Regulations 8
J Where to get a Black belt certification ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 13
D Any recommendations on where to find experienced quality hires in Chicago area? Job Openings, Consulting and Employment Opportunities 3
J Where is the definition of a critical supplier? ISO 13485:2016 - Medical Device Quality Management Systems 5
W Where does a coatings and paint company fall in IATF? IATF 16949 - Automotive Quality Systems Standard 5
B When Travel is allowed - Where are you going? Travel - Hotels, Motels, Planes and Trains 16
G Where to buy Template / sample SCSMS Manual, checklist Supply Chain Security Management Systems 1
M Quality Manual - Where does Revision History Section go? Document Control Systems, Procedures, Forms and Templates 8
C Where to draw the line for "sufficient evidence" to verify safety/performance of a device? CE Marking (Conformité Européene) / CB Scheme 2
L Where to place the what/when/how/who/where procedures in a multi-regulation AS9110C organisation AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
B Where to acquire EN 868-5 required dye (Amaranth red)? Other Medical Device Related Standards 2
N Where to find Regulations for Reprocessing and Reuse of Single-Use Devices Other Medical Device Related Standards 2
H Where to get EK MED 1927/16 Other Medical Device Regulations World-Wide 3
D Where to find Guidance Class II Amendment Canada Medical Device Regulations 1
O EN 301 489-1 and EN 301 489-17 - Where do we get the information of the Published versions? CE Marking (Conformité Européene) / CB Scheme 1
A AS9100 Training - Where do I start? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 14
qualprod Records where apply and stop recording everything? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
C Where to place CE/label in Sterile IVD EU Medical Device Regulations 1
G New to ISO 9001 - Where to begin? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
BeaBea Interesting Discussion Where Does Marketing/ Advertisement of Products fit in to ISO 9001? Process Maps, Process Mapping and Turtle Diagrams 39
K No IFU, where the requirements would go? EU Medical Device Regulations 5
T Assessing Hazard-Related Use Scenarios where control measures exist through standards IEC 62366 - Medical Device Usability Engineering 32
J Where to Place Process Maps in our Documentation? Process Maps, Process Mapping and Turtle Diagrams 4
GreatNate Where to get a KPI dashboard for QMS processes Quality Tools, Improvement and Analysis 5
A Implementing ISO 20000-1 - Where to start Other ISO and International Standards and European Regulations 2
D Where does "as far as possible" stop? FMEA - EN 14971 ISO 14971 - Medical Device Risk Management 29
qualprod Statistics - Where to start in ISO 9001? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
H Calibration of InfraRan Vapor Analyzer - where to get calibration for SF6 General Measurement Device and Calibration Topics 2
