Where to put product and process characteristic in PFMEA (AIAG Manual 4th edition)?
K
kemble
In the PFMEA(4th Edition) table, I'm confused about where to put the product characteristic and process characteristic?:(
Could someone give me a detail description?
Thanks a lot!
Re: Where to put product and process characteristic in PFMEA(4th edition)?
Thanks a lot!
The PFMEA form (what I assume you're referring to as the "table" has columns on the left for product and process requirements, and further to the right there are columns for current process controls (prevention) and current process controls (detection). What else do you need to know?
K
kemble
Besides what you mentioned, the potential causes column on which maybe fill the process characteristic?
Please give me a detail description about the characteristic on the PFMEA, thanks a lot!
If I'm understanding you correctly, there is a potential for aspects of the process (process characteristics) to fail, so it's possible to use the failure of process characteristics as potential causes of product failures.
Comprehensive descriptions are a bit beyond the scope of what we do here, and it's not clear what you're trying to find out. Do you have a copy of the AIAG FMEA manual (or SAE J1739)?
K
kemble
The reason why I ask where to put the product and process characteristic in PFMEA(4th edition) is the linkage between PFMEA and Control Plan, I think that the linkage should contain the characteristic(product/process).
<FMEA 2008 AIAG.pdf>,on the page of 112(bottom of paper):
In addition to the list of Recommended Actions and their subsequent follow-up as a result of the PFMEA activity, a Control Plan should be developed13. Some organizations may elect not to specifically identify the related product and process characteristics” in the PFMEA. In this situation, the “Product Characteristics” portion of the Control Plan may be derived from the “Requirements” portion of the “Process Function/Requirements” column and the “Process Characteristics” portion may be derived from the “Potential Cause(s) of Failure Mode” column. When the team develops the Control Plan, they need to assure that the PFMEA current controls are consistent with the control methods specified in the Control Plan.
If the product characteristic was put on the "Requirements" column of PFMEA,and the correlative process characteristics were put on the "Potential Cause(s) of Failure Mode" column,where the control methods should be put,"Current Process Control Prevention" or "Current Process Control Detection"?
Could you please give me the detail explanation about the following points:
1.The linkage of PFMEA and Control Plan.
2.The perfect place(PFMEA Column) to put the product and process characteristics in the PFMEA.
Thanks a lot!
Thanks a lot!
Let's back up a step--you're neglecting to consider the process flow diagram (PFD), which is where you should be starting. The PFD should list the process steps or operations in the order they occur. Those process operations should go in the leftmost column on the PFMEA form (Process Step/Function). For each step there is a "Requirements" column--one for Product and one for Process. Ideally there should be an entry for each category. The "Product" characteristic is about specifications--the characteristic of the product affected by the current operation. The "Process" characteristic is about the feature of the process that controls the product characteristic in question--something that can be controlled in the process such that the product characteristic will conform to requirements.
The potential cause(s) of failure modes will almost always relate to process characteristics.
In the Current Process Controls columns (one each for prevention and detection) the current controls are listed (if there are any)--what's currently done to prevent the failure mode in question, and what's done to detect it if the prevention control fails (or doesn't exist).
The process control plan (PCP) should show the same operations as the PFMEA, in the same order. The current process controls on the PFMEA should be transferred to the PCP for each operation, unless there are PFMEA Recommended Actions that have been completed and result in new control methods.
I hope this answers your questions.
K
kemble
Re: Where to put product and process characteristic in PFMEA (AIAG Manual 4th edition
Thanks for your timely reply.
Now "process operations" is okey,it is consistent in PFD,FMEA,CP.
But I'm still confused about how to keep the consistency of characteristics(Process/Process) in PFD,FMEA,CP.
Please give me some detail explanation.(please refer to the attached file)
Thanks a lot!
K Where to put Product and Process Characteristics on the Control Plan. FMEA and Control Plans 1
K Where in the quality manual do I put our Quality Objectives and our Quality Policy Quality Management System (QMS) Manuals 19
I ISO 9001:2008 4.2 Documentation - Where to put a Procedure Quality Manager and Management Related Issues 7
E Where to put QMS Definitions, e.g. forms, policies, etc ISO 13485:2016 - Medical Device Quality Management Systems 8
T Control Plan - Automotive - What To Put Where FMEA and Control Plans 14
P Control Plans - Is it acceptable to put n/a's on a Control Plan where data is taken? Statistical Analysis Tools, Techniques and SPC 2
J Purchasing Procedure - Where to put Material Request in the Procedure QS-9000 - American Automotive Manufacturers Standard 3
J UDI - Where to document it? EU Medical Device Regulations 8
J Where to get a Black belt certification ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 13
D Any recommendations on where to find experienced quality hires in Chicago area? Job Openings, Consulting and Employment Opportunities 3
J Where is the definition of a critical supplier? ISO 13485:2016 - Medical Device Quality Management Systems 5
W Where does a coatings and paint company fall in IATF? IATF 16949 - Automotive Quality Systems Standard 5
B When Travel is allowed - Where are you going? Travel - Hotels, Motels, Planes and Trains 16
G Where to buy Template / sample SCSMS Manual, checklist Supply Chain Security Management Systems 1
M Quality Manual - Where does Revision History Section go? Document Control Systems, Procedures, Forms and Templates 8
C Where to draw the line for "sufficient evidence" to verify safety/performance of a device? CE Marking (Conformité Européene) / CB Scheme 2
L Where to place the what/when/how/who/where procedures in a multi-regulation AS9110C organisation AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
B Where to acquire EN 868-5 required dye (Amaranth red)? Other Medical Device Related Standards 2
N Where to find Regulations for Reprocessing and Reuse of Single-Use Devices Other Medical Device Related Standards 2
H Where to get EK MED 1927/16 Other Medical Device Regulations World-Wide 3
D Where to find Guidance Class II Amendment Canada Medical Device Regulations 1
O EN 301 489-1 and EN 301 489-17 - Where do we get the information of the Published versions? CE Marking (Conformité Européene) / CB Scheme 1
A AS9100 Training - Where do I start? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 14
qualprod Records where apply and stop recording everything? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
C Where to place CE/label in Sterile IVD EU Medical Device Regulations 1
G New to ISO 9001 - Where to begin? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
BeaBea Interesting Discussion Where Does Marketing/ Advertisement of Products fit in to ISO 9001? Process Maps, Process Mapping and Turtle Diagrams 39
K No IFU, where the requirements would go? EU Medical Device Regulations 5
T Assessing Hazard-Related Use Scenarios where control measures exist through standards IEC 62366 - Medical Device Usability Engineering 32
J Where to Place Process Maps in our Documentation? Process Maps, Process Mapping and Turtle Diagrams 4
GreatNate Where to get a KPI dashboard for QMS processes Quality Tools, Improvement and Analysis 5
A Implementing ISO 20000-1 - Where to start Other ISO and International Standards and European Regulations 2
D Where does "as far as possible" stop? FMEA - EN 14971 ISO 14971 - Medical Device Risk Management 29
qualprod Statistics - Where to start in ISO 9001? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
H Calibration of InfraRan Vapor Analyzer - where to get calibration for SF6 General Measurement Device and Calibration Topics 2
M Where can I find examples of PPAP? APQP and PPAP 6
A What if Contract Manufacturers does not have an ISO 13485 certificate? Where will the NB audit take place, at legal mfg. site or contract mfg. site? Other Medical Device Regulations World-Wide 3
J Where can I find the latest update to Reach and ROHS? REACH and RoHS Conversations 9
D Where (in US) can I get the VDA Auditor Edition book? VDA Standards - Germany's Automotive Standards 3
S Where to get online AS standard audit certification classes? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
J Where I can get a copy of either the 3rd or 4th edition of UL544? Other Medical Device Regulations World-Wide 7
G Where to find Proficiency Test provider for photometrics (spectral %R, %T, photo density) General Measurement Device and Calibration Topics 9
Marc Quiz - Where did the idea of an assembly line come from? Coffee Break and Water Cooler Discussions 4
F Quality Objectives - Where in the QMS Quality Objectives should be located ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
M Where to obtain a calibrated DICOM image? ISO 13485:2016 - Medical Device Quality Management Systems 1
