Re: Where to Start to Implement ISO9001
I agree with this
although it is important for each key process to have an objective (see 4.1c).
As you analyze the key processes with the process owners you record each nonconformity as you go; another benefit of becoming a competent systems auditor first. I also describe the nonconformity in a blue note attached to the flowcharted procedure. This enables you and the process owner to resist the temptation of pretending the process fulfills all of the applicable requirements. It also quickly informs management of what they or others must change and implement (includes training) to bring the process into conformity. It also helps remove the fear of a probably new word: "nonconformity".
Employees can see managers taking responsibility for the system and the nonconformity it causes.
The certification bonus is that you start building the records early as evidence of having used the new processes, from the beginning of the system development project, for removing the root causes of both future and current nonconformity in process and product.
Your next problem will be how to get the operators, supervisors and managers to monitor and correct processes while under their control instead of waiting for an auditor to tell them it is wrong.
I liked what John has written about the general strategy in implementing QMS. I would like to add my little bit to this thread as follows:
My experience shows that the weakest area in an orgn. vis a vis requirements of ISO 9001 is those related to clauses 8.3 and 8.5 whereas maximum benefits through QMS to an orgn. may accrue from implementation of these clauses. So I suggest that while you plan your project, please give equal or priority status to following actions:
1. Advising process owners to identify nonconformities they come across in their processes and record how they correct them (cl 8.3) and how they take corrective action(cl 8.5.2) if they are already doing it. If they are not used to corrective action, you may have to guide them in the corrective action process in their respective areas.
2. You can also devise a nonconformity reporting proforma which could also be used to record correction of nonconformity(disposal of nonconforming product as per cl 8.3);analysis of root cause of nonconformity; and recording of corrective action including verification of effectiveness of corrective action. You can see to it that this proforma is put into use at the first stage of implemenation itself.
3. An action that deserves equal importance is to guide process owners in identifying process performance indicators(cl 8.2.3) in their respective areas and also encourage them to collect data on actual performance in terms of these indicators. This step will faciltate them to analyse data collected, define present level of performance in their respective functional areas and also subsequently arrive at measurable quality objectives(cl 5.4.1) with respect to these areas.
