Which Anova dropdown to use for R&R in Minitab?
Minitab and Anova MSA... we are a first tier supplier to Ford and GM. I have 20 yrs experience with MSA, and 20 minutes experience with Minitab. Under the Anova dropdown, which is the best test to use?
say for hand held gage and maybe a in-line automated gage?
MSA is not under the ANOVA dropdown. Try Stat > Quality Tools > Gage Study > Gage R&R Study (Crossed) for the most common type of study (i.e., hand held gages).
For the in-line automated gage, I need more information. Many automated gages do not have the equivalent of operator for reproducibility, but some do. For example, multiple nests or multiple test stations provide an equivalent to reproducibility and can use the standard R&R study. Otherwise, you would use a repeatability study instead of an R&R study.
F Minitab 19 Anova or X bar # of distinct catagories Using Minitab Software 1
E Input to ANOVA 1-WAY - How can I perform this analysis in minitab? Using Minitab Software 2
B WEDM Taguchi and Anova Analysis - L16 array with 5 parameters at 4 levels Manufacturing and Related Processes 5
F How to make an ANOVA of a design with repeats (not replicates) in Minitab? Using Minitab Software 18
H Taguchi mixed model DoE [L16 (4^3 2^6): factors interaction and ANOVA calculation Using Minitab Software 3
S Taguchi Design with ANOVA - 3 factors each with 3 levels Quality Assurance and Compliance Software Tools and Solutions 13
B How to perform a MSA - GRR (Gage R&R) A&R/ANOVA Vs GUM/VDA Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
E GR&R ANOVA 3rd Factor for Fixture Nests Using Minitab Software 3
N ANOVA vs 2 sample t-test Statistical Analysis Tools, Techniques and SPC 6
F Help me understand the ANOVA Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
F Post Hoc test for two way ANOVA Using Minitab Software 9
E ANOVA for Taguchi method - Four factors and three levels and nine runs (Minitab) Using Minitab Software 6
M ANOVA for S/N ratio gives different results Statistical Analysis Tools, Techniques and SPC 5
T Minitab Two-way Anova example (EXH_AOV.MTB) Quality Assurance and Compliance Software Tools and Solutions 1
S ANOVA/Regression - Analyzing a Dataset which contains over 4500 Points Using Minitab Software 3
P Taguchi Anova Error with Minitab Using Minitab Software 9
J Why doesn't ANOVA Method take the specification into account when determining GR&R % Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 11
F Fully nested ANOVA: A missing p-values (Minitab) Using Minitab Software 11
S Regression Analysis / ANOVA using Excel Excel .xls Spreadsheet Templates and Tools 2
C GR&R MSA-4 ANOVA Excel Template Verification Check wanted Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
R P-value and interpretation of ANOVA Gage R & R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 11
L What is the the difference between the Gage R&R Nested Anova and ISO/REMCO N263? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
S ANOVA and Test Method Validation for a Drug Delivery Device Statistical Analysis Tools, Techniques and SPC 4
L How is the interaction physically happening while performing ANOVA GR&R? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
E Using ANOVA during the PQ Validation Run to evaluate Statistical Differences Statistical Analysis Tools, Techniques and SPC 4
M Understanding of Regression and ANOVA in Minitab Statistical Analysis Tools, Techniques and SPC 8
J Minitab Error - * ERROR * Unbalanced Design - Unbalanced Anova Using Minitab Software 9
V Sample Range for a valid GRR using ANOVA in Minitab Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
S Anova Gage R&R Calculations for 4 Operators Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
M Multi-factor Anova with Minitab Using Minitab Software 1
R New to MSA - I was told to use ANOVA for the GRR's Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
G GR&R (Gage R&R) Anova versus Xbar Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
S Strange PT Ratio on an Excel spreadsheet for variable GRR ANOVA Method Excel .xls Spreadsheet Templates and Tools 2
J Variation (using ANOVA method) Required for Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
A Minitab ANOVA Error Message - *ERROR* No data in column. Using Minitab Software 3
I Choosing the alpha level in an ANOVA Study Statistical Analysis Tools, Techniques and SPC 3
I Minitab ANOVA Gage R&R Error (vs. EXCEL ANOVA GRR Calculation) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
P Multi-factor Anova with Minitab Using Minitab Software 11
V Identifying Significant Factors - Regression Analysis vs Correlation vs ANOVA vs DOE Quality Tools, Improvement and Analysis 7
Rameshwar25 GRR (Gage R&R) Nested Anova Method Example Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 40
L Good Excel .xls sheet for Gage R&R that calculates both Anova and Range Excel .xls Spreadsheet Templates and Tools 9
optomist1 Generic question regarding Two Way ANOVA Results Statistical Analysis Tools, Techniques and SPC 8
D ANOVA vs. X bar & R - MSA Study in Mintab - Which to use and why? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
optomist1 Two Way ANOVA Test For Equal Variances Using Minitab Software 10
K Error in ANOVA table in the AIAG MSA manual? Table A4 Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
Rameshwar25 Gage R&R Anova - With Interaction or without Interaction? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
M Calculating P-value for one way Anova test Statistical Analysis Tools, Techniques and SPC 3
J ANOVA vs. X-bar/R Calculations Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
